Question about Karcher 2500 PSI Pressure Washer
My honda gcv 160 pressure washer won't start. change the spark plug and drain the fuel in carb, still won's start. any help?
I have a ryobi pressure washer with the honda gcv 190 and it wont start i got fuel and spark and the switch is on it just dont want to start
Is this a brand new unit or one that you've had awhile? If one you've owned awhile, when is the last time you used it? Did you use a fuel stabilizer or drain the tank and let the engine run until it stalled?
One thing you might try would be to remove the spark plug and give a little spray of carb cleaner in to the plug hole, then reinstall the plug and try to start it. If there's just not enough vacuum to get fuel to the cylinder, getting the engine to fire off the cleaner may provide enough oomph to get the engine started and running.
Oct 08, 2016 | Garden
I have a troy-bilt model 020296 power washer. what type of replacement spark plug does it take?
Tom, NGK BRP6ES ,Champion RN9YC,Torch F6RTC are replacement sparkplugs for Honda GCV 160 pressure washer engine. This info should be in your pressure washer engine manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.bsppwebtools.com/data/manuals/020296_0esAw.pdf
Troy Bilt 020296 Pressure Washer Relacement Parts
Spark plug cross reference
Jul 02, 2016 | Troy-Bilt Garden
Honda Pressure Washer won't start
Blue smoke is def oil burning so I would guess that is the ain cause of the non running. It is possible that oil has got into the carb and jet . Turn fuel off and unscrew the slightly off set 10mm bolt on the bottom of the carb bowl to drain the fuel. If oil came out with the fuel then you should undo the other 10mm bolt and remove the bowl. Spray some carb cleaner around the floet and jet and also up the post that the bowl was fixed to as the jet is up there. Also, remove spark plug and pull over a few time to get rid of anything in the cylinder. Refit all back together and try again (don't forget to turn fuel back on).If it tarts it may run smokey for a few minutes while any oil residue burns off.
Jun 27, 2012 | Garden
I cannot get my honda 2500psi pressure washer to start at all i have changed spark plug and do have spark it has good gas in it and plenty of oil but will not start?
Three things needed for engine to run. Fresh fuel, good spark and good compression. I am assuming that water supply is disconnected for now and that you feel good resistance when you pull the rope indicating that there is compession. For now remove/unplug the low oil alert wire (if your model has one). Use carburator cleaner as fuel for now by spraying fuel directly into carb with air filter removed and choke off (do not flood just spray a little then little more if needed, the engine will only begin to run then stop unless you contine to spray fuel). If the engine does not respond most likely timing belt or plastic cam is cause. GCV series honda engines use timing belt with plastic cam gear. Gx series use metal gear. If the engine responds clean carb. Good luck
Jul 08, 2011 | Honda Garden
Hi my name is Garry, My Karcher pressure washer is not getting gas and won't start. If I pour gas directly down the carburetor it will start. What could this be I replaced the spark plug and cleaned...
Hi Gary,
Looking at your owners manual I see this is a Honda GCV 160 engine. (owners manual)
http://www.karcherresidential.com/support/downloads/pdfs/usermanuals/9139-1650.pdf
Download this carb check sheet and follow the steps:
http://www.honda-engines-eu.com/en/images/59139.pdf
You have debris in the main orfice jet or tube. These are removed from the threaded area of the float bowl nut with a screwdriver that fits EXACTLY into the brass slots of the orifice and after orifice removal the main fuel tube. IF you damage these during removal i..e you use the wrong screwdriver or damage the thread slots you can end up having to change the carb. Just make sure the screw driver engages the orifice and fuel tube slots fully.
After cleaning the main fuel orifice and fuel tube check fuel flow into he float bowl. It should fill a spray paint can lid in around 10 seconds. If you do not have this kind of fuel flow.. investigate from the float needle back to the fuel tank outlet for restricions.
Thanks for choosing FixYa,
Kelly
Jun 18, 2011 | Karcher 2500 PSI Pressure Washer
Press. Washer Honda engine gx 390 will not start
did you leave fuel in it from last year, if so remove all fuel from tank, drain carb. (remove float bowl if it doesn't have a drain bolt) put in fresh fuel, check your oil level and you should be good to go. if not, please take it to a qualified tech. for carb. cleaning.
Doc
May 17, 2010 | Karcher G3025OH Pressure Washer
My almost new Honda GCV 160 engine will not start.
Hi , I think you need someone to remind you these engins are not made by god and they work by obeying three simple rules ,
1.Spark , Can you see a very good blue spark
2.compression,,can you feel strong compression ,
3.fuel , is the right amount of fuel getting in , is the air mixture good ,
Now try these things
Find the manual and PROPPER set the gap in the spark plug ,
clean and check the air filter ,
remove all fuel and replace with brand new,
check the fuel filter,even in the tank tap?
undo the screw at the carb bowl , can you see petrol leaking ,
If everything checks out then try this to get it started,,
spray "easystart" in the carb , bypassing the air filter ,
if it wants to start but cant for long then its a carb problem
check float hight , float needle,jets and pins ,too much air getting in
find someone thats good on motorbikes , They like me know all the tricks to get things to start ,
Aug 16, 2009 | Karcher 2500 PSI Pressure Washer
Fuel mix for a excell VR2522
should be a honda gcv 160 5,5 horsepower engine.
do a search for honda engine carburretor adjustment, plenty of pages on the internet detailing how to adjust carbs, mixture etc.
Excell Pressure Washer Model VR2522 Replacement Parts repair kits ...
lok at this site , parts breakdown of engine etc
Jul 18, 2009 | Karcher 2500 PSI Pressure Washer
Honda gvc 160 not starting. cleaned the ventui & plug
Check the fuel.
Drain some of the fuel into a white contain...I use a paint can lid. If it yellow to orange in color it's bad. You can pour the fuel into your car to get rid of it. A car has electronics that will compensate for poor fuel quality, small engines don't.
Check spark.
Remove the spark plug and reinstall the wire. Lay plug on the engine block where it can contact it. Pull over the engine. You should see spark. If not change the plug. If still no, I give you further instructions.
Mar 31, 2009 | Campbell Hausfeld PW2102 Gas Pressure...
Karcher 2500 PSI Pressure Washer Logo
916 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
