Question about GN Netcom GN Jabra BT620s Bluetooth Stereo Headset - Wireless, Cable - Stereo Output - Behind-the-neck Headset
My Jabra BT620s doesn't seem to be charging. The red LED on the right side light up indicating charging but the left side wont. The right side will remain lighted for about 30 minutes and then no LEDs will be displayed. I have tried charging through different USBs including the offical Jabra wall charger
Jabra wave battery suddenly won't charge
The battery may be shot and incapable of charging. The red light could be merely indicating that the charger is working.
Jan 13, 2014 | Jabra Wave Bluetooth Headset
Jabra sport will not charge
Same problem did you call the 800 number?
Dec 09, 2011 | Jabra Radio Communications
Hello my jabra wont light up when it is fullcharge? can you help me?
The headset light turns off when it is at full charge. If it is not charged yet it will be illuminated red.
Found this in the online manual:
http://img5.jabra.com/sites/Jabra/GNimages/Products/Stone_Manual_EN_NA_8404.pdf
Feb 28, 2011 | Jabra Stone Bluetooth Headset
My jabra BT160 won't charge
i had the same problem with mine. the problem is with the completely empty battery.
solution is to disassemble it and force charge the battery inside.
you have to cut any usb cable leaving the side which connects to pc and remove the insolation from red and black wires. connect them for few seconds to battery soldering points on jabra board (red to red, black to black, sometimes you have to scratch the solder a bit if it oxidized a bit). once you see the light you can start charging it normally.
Sep 23, 2009 | Jabra BT160 Wireless Headset
Jabra bt2020 will not charge/function
I don't know how long you have had the headset but it sounds like it isn't holding a charge.  Contact Jabra to find out what the warranty is on the headset.
Nov 12, 2008 | Jabra BT2020 Bluetooth Headset
Jabra JX10 Bluetooth doesn't/won't charge
Not sure if this is a solution or if it occurred by chance. Like many on here, I put my Jabra JX10 away for a few months while not using it. The time come for me to need it once again and found that it was dead. Made an attempt to charge the unit with negative results. The unit would only show a green "charged" LED indicator as if the unit was fully charged. I tried plugging the unit into the charger multiple times, and took the cradle out of the loop and just used the AC cord alone. Still with the same results. I pulled the outside cover off (slowly), to be sure not to break the small fragile tabs that hold it in place. The battery takes up majority of the space. Removed the battery but DID NOT disconnect from unit. Plugged the charge cord into the unit and immediately got a red LED charging indicator. While charging, placed the battery back inside and put the outside cover back on. The unit continued to charge for a little over an hour before the green LED "charged" indicator came on. I used the unit throughout the day to test it with no problems. Not sure what removing the battery from unit did, especially when it was not disconnected, but it worked. I hope to see similar results.
Aug 22, 2008 | Jabra JX10 Bluetooth Headset Headset
How to pair Jabra BT620s Bluetooth headphone with HP Laptop?
Hi
• At your computer Right click on the Bluetooth icon on the task bar.
• Select “Explore my Bluetooth places”.
• Click on “View devices in range” to see all available devices.
• Right click on the Jabra BT620s and select “Pair device”.
• Enter the four digit passkey: 0000 (4 zeros).
• Right click on the Jabra BT620s and select “connect”.
• The connection will be established automatically, otherwise if the Jabra BT620s is ringing,
press the answer/end button to confirm the connection.
Good Luck
Aug 10, 2008 | Computers & Internet
My M1 from Sayno and my jabra b260s
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Dec 31, 2007 | GN Netcom GN Jabra BT620s Bluetooth Stereo...
BT500V won't charge
This happens because the battery gets too low to take a charge.
To jump start the headset, connect the power lead and the LED will be flashing red. now press and hold the power and BT pairing buttons. The LED should change to solid red.
I found that holding both buttons for about 3-5 minutes allowed the battery to get enough charge to start charging and you can release the buttons and the headset will continue to charge.
If the led starts flashing again, just repeat the process again.
Hope this helps...
Baz
Dec 16, 2007 | Jabra BT500V Wireless Headset
Open Questions:
GN Netcom GN Jabra BT620s Bluetooth Stereo Headset - Wireless, Cable - Stereo Output - Behind-the-neck Headset Logo
35 people viewed this question
Top GN Netcom Radio Communications Experts
TO Lady
bigdawg7299
Tom Chichester
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
