Question about Frigidaire AEQ6000ES Electric Dryer
Aeq6000es2 wont heat - no error code displaying
  • 3 more comments
  • tendisch Mar 12, 2011
    Hey Daniel -
    Thanks btw... any helpful hints on getting the back panel off?
    Daniel - the inside of the back of my dryer doesn't look anything like the one in the video. I did find a Tech Data Sheet inside of the dryer however, and when I ran the test I came up with an error code of E93 004. Thoughts??
  • tendisch Mar 13, 2011
    Daniel - sorry for the delay but had to leave the house for a while. This video doesn't look ANYTHING like the back of my dryer. The back panel on my dryer does not separate from the unit like this one. My back panel has all the wiring harnesses and everything attached to it (including the drum). I can pull off the vent cover to look inside but I can't see anything that resembles this Thermal Fuse like the video shows. Are you sure we have the right Model #?
  • tendisch Mar 19, 2011
    Tried replacing both parts during the week... still no heat. ???
  • tendisch Mar 20, 2011
    Tried that part as well... as recommended by the parts store personnel. No difference...
  • 4,323 Answers
Hi
I believe that everything else is fine rather it is the thermostat that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. If the fuse is fine then check the dryer belt and idler pulley...Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 12, 2011
  • 3 more comments
  • Daniel Scott
    Daniel Scott Mar 12, 2011
    Check this video...just an example on how its done:
  • Daniel Scott
    E93 error means no line voltage which is caused either by blockage in the lint filter or when the thermostat goes bad....and the video was an example on how its done...you can also check this video:
  • Daniel Scott
    Daniel Scott Mar 13, 2011
    Hi
    The videos were example how to check the thermal fuse and thermostat. Please check part#F36 (Thermal fuse) and F33 (High limit Thermostat)---
    Unplug the dryer, pop up the top and take it off. Unplug the 2 plugs, take 2 screws out that hold the front door, take out the door. Get the belt loose from the back roller, pull out the entire drum. Check for the thermostat at locations mentioned in the above schematic.
    Daniel
  • Daniel Scott
    Daniel Scott Mar 19, 2011
    Please check part #F15 (thermistor) in below link--
    Use a multimeter to check the continuity of the thermistor. Hope this helps... Please post back if you need more information.
    Daniel
  • Daniel Scott
    Daniel Scott Mar 20, 2011
    Check the door lock-switch assembly
What does area Error code E-05 mean on a Frigidaire front load dryer model # AEQ6000ES2
model aeq6000es2: the "e05" error code normally indicates that control board may need to be replaced or a stuck relay on the control panel. you can reset the unit by unplugging the dryer power cord for 5 minutes and then reapplying the power. if the problem persists then the control board or the control panel may need to be at fault.
Good Luck & All The Best, Justin McCartney
Dec 26, 2015 | Frigidaire Dryers
Affinity aeq6000es2. After two cycles of the
sounds like your heating element opened up,as it was running and when the element broke it arced and these were the sparks you saw,you will need a new heater element
Jul 19, 2010 | Frigidaire Dryers
Getting code PF, resetting breaker did not fix the problem. Dryer model Aeq6000es2.
PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display.
Feb 22, 2010 | Frigidaire AEQ6000ES Electric Dryer
My Frigidaire Dryer (AEQ6000ES2) won't heat. Did
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the dryer ID doesn't mean
anything to me. Over the years, I haven't had much trouble with my dryers. The E56 error code means high motor current. To help you find out why, I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair information on dryers and other appliances. I think you'll find what you need there. You can probably verify the meaning of the error code there. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 26, 2009 | Frigidaire AEQ6000ES Electric Dryer
Frigidaire Dryer Error E 04
I have the same problem. Does anyone have an answer?
Jul 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
Help with correcting fault code f-5
F-05 error means:-- Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
TO RESOLVE THE PROBLEM:--
Check the Water Temperature Sensor, Heating Element and Element Relay globul1a.gif Check connections to the Sensor, Heating Element and Relay
May 07, 2009 | Washing Machines
Aeq6000es2 dryer getting error message PF
power failure...reset breaker for dryer restart cycle then it should be g00d!!!!!!
Mar 31, 2009 | Frigidaire AEQ6000ES Electric Dryer
Frigidaire affinity dryer problem
the thermistor in air outlet duct is very common for these. with front panel off find plastic duct from blower at bottom. pull out thermistor and look at inner side. it has triangular shape and if you can see shiny redish color at tip instead of all black then its worn. this causes numerous heat and control issues.
Mar 29, 2009 | Frigidaire AEQ6000ES Electric Dryer
My Frigidaire Electric Dryer keeps giving an error code
If your dryer is the same or similar to mine (Model AEQ6000ES2) then error E68 is a stuck key on the keypad. This may be mechanically stuck or the membrane contacts. The simple solution is to replace the keypad.
I found this information by searching for "Frigidaire Model AEQ6000ES2"
Mar 23, 2009 | Frigidaire Electric Dryer
Dryers Logo
116 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
