Question about Dishwashers
Whirlpool dish washer du931scgb1
The only buttons that work are the heavy duty cycle and the time delay. none of the other buttons work. then if you turn it on with the heavy duty button, the washer runs for 10 seconds and then all the buttons flash and the washer restarts at the begining of the cycle. over and over and over.
  • 2,071 Answers
This is the symptom of defected timer motor is need to replaced..
Hope this may help;
Regards,
VOTIT
Posted on Aug 01, 2008
Cae2743bq will not turn on all lights on and lid lock is lit up
Try this, worked for me! :)
New WHIRLPOOL Top Load Washer
Model #'s CAE2743BQ, CAE2763BQ
Cycle Selector Knob key dance: [CCW=Counter Clockwise and CW = Clockwise]
Start On "NORMAL"
1 step CCW (Left)
2 steps CW (Right, Right)
1 step CCW (Left)
1 step CW (Right)
Stay on "HEAVY DUTY"
(If unsuccessful LEDs will not flash, and you must return the selector to the Normal Cycle position and
wait 4-5 seconds before retrying. )
If you are successful in the process, all LEDs will be flashing
Toggle between HEAVY DUTY and NORMAL until ONLY the RINSE light is on, then press the
START button for about 30 seconds. Machine will then enter CALIBRATION mode for about 2 - 4
minutes. DO NOT RAISE THE LID
Sep 01, 2013 | Whirlpool Washing Machines
My whirlpool du931scgb1 dishwasher.on the front panel only the delay button and the heavy load button works. and if you use the heavy load button the washer restarts it's self every 10 seconds. thanks
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Aug 01, 2008 | Whirlpool Dishwashers
Replaced lid switch a year ago, and the heavy duty cycle works fine. However, the permanent press/delicate and normal cycles do not work (tub just keeps filling/emptying water). My research indicates that...
I agree, it is most likely a timer problem. Possibly "rust" build-up.
See the Whirlpool / Kenmore Service manual for top load, direct drive washer for troubleshooting and diagnostics procedures.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Nov 18, 2010 | Kenmore 24032\24036 Top Load Washer
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Kenmore series 80 washer only works on heavy duty cycle.
bad transmission,,check voltage...below 110 with load and water pressure switch or hose defective..
Dec 24, 2008 | Kenmore 24902 Top Load Washer
Cycle selection
this sounds as though your having a communication problem with your motor control unit and central control unit.check wire harness to both components.making sure that connections are secure.
Jun 16, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashers Logo
157 people viewed this question
Top Dishwashers Experts
