Question about Sony PSP (Piano Black)
My psp 1000 keeps turning itself on when not in use, and after i use it for a while it will automatically turn off. My battery seems to work as normal and i dont see a problem with my charger. ive had it ever since it was first released in uk
Two things I can suggest other then trying a new batter. 1. Pull out the battery for a day or two and let it completely die. Put it back in, and then recharge if fully. 2. Reformat your PSP by holding the R-Trigger. A recovery menu should then pop up and a reset command should appear. The PSP should then restart itself and being trying to repair itself.
Posted on Mar 13, 2011
My psp wont charge
remove the battery try switching it on with only the charger plugged in , if it works , then your battery is dead and you need to purchase a new one :)
Jan 24, 2013 | Sony PSP 1000 Black Console
Psp turning itself on and off automatically
try putting it in the charger and turn it on and see if it stays on and if it does get a new battery
Jan 14, 2012 | Sony PlayStation Portable (PSP) Slim...
My PSP 1000 still turns on and display the "Save
try to use another memory card if the problem with still appear if yes turn on the PSP with out any memory card or UMD then try to reset the settings
Feb 08, 2011 | Sony PlayStation Portable (PSP) Console
I charged my psp for atleast 5 hours.....but charge ended within 1 hour......what to do??
I'm just restating what you said here first...
You plugged in your psp for 5 hours.
You took it out.
You played it for 1 hour before it turned off...
If this is true, it seems that your battery just can't hold a charge. One solution would be to just buy a replacement battery, but you could try this...
Drain your psp completely. This means keeping it on until it turns off, then turn it on again, leave until off and so on. Just keep turning it on until it stays on for less than a minute.
Charge your battery overnight.
Hope this helps!!!
Oct 07, 2010 | Sony PlayStation Portable (PSP) Console
Pc driver for sony psp-1000
It's not so easy to erase PSP OS and if even you do it you wil brick your PSP(Your screen will be black when you will turn on it and only green light will flash few times.) I think you have bad memory stick or something like that. Because you are browsing memory stick and not PSP when you connect PSP to computer. Check if you have memory stick inside your PSP. Try to format memory stick in PSP. You can also try to restore PSP deafult settings. If you have Card Reader try to read and format card on computer. If nothing helps buy new memory stick.
Jul 11, 2010 | Sony PlayStation Portable (PSP) Console
Not working unless plugged in at the mains? PSP 1000
Maybe you accidentally made a pandora battery..
plug in the mains.. hold left shoulder and turn on your psp.. you should be in recovery mode after doing that.. go to advance.. then.. insert the batt. your psp. then select "make normal battery".. then exit recovery..
hope it works.. Goodluck :)
Jan 31, 2010 | Sony PlayStation Portable (PSP) Console
Psp turns on and off
Hi-did you ever get an answer to your problem? My son's PSP turns off while he is playing. Will go back on but just keeps turning off.
Oct 25, 2008 | Sony PlayStation Portable (PSP) Console
Rebooting my psp
well to reboot it just turn it off and then back on again.
during the update i got for it a day ago it asked if i wanted to reboot and it automaticly reboot itself. if you can't turn your psp off or on, check the battery or get a new one.
hope i helped a little... good luck :)
Jun 08, 2008 | Sony PlayStation Portable (PSP) Console
Sony psp problem
Remove the battery for 15 minutes, connect the AC Adapter and install the battery again.
It that doesn't work, remove the battery again, wait 15 minutes, install it and plug the AC Adapter.
It's a weird problem but in my PSP i get around that way.
Feb 07, 2008 | Sony PlayStation Portable (PSP) Console
My PSP is Acting Up
1. go to settings in your psp and turn off the intelligent volume function.
2.psp has automatic updating depending on what is typed. play with the config to turn this function off.
Jan 08, 2008 | Sony PlayStation Portable (PSP) Console
Sony PSP (Piano Black) Logo
161 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
