Question about PANDIGITAL Office Equipment & Supplies
When I scan a picture, there are 2 lines down the middle of the them.
  • 86 Answers
Clean your scanner and check the connection between your scanner and computer. Try a different cable if needed.
Posted on Mar 12, 2011
I have a big black line down the middle of my scans
If dirt sticks to the scan module, it will be scanned continuously and appear as a line in the output. Clean the glass with Isopropyl Alcohol. Dont use any other solvent.
S. Mohan, India
Mar 12, 2013 | Canon DR-5010C Scanner
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Hen I scan a picture on my brookstone iconvert scanner there are white lines through the middle of the picture. Already tried recalibrating and cleaning.
Jun 12, 2010 | Office Equipment & Supplies
Fax has stipe down middle
When you open the topt cover, there are 2 scanner glasses. A small one a and a big one, the small one is used when using the feeder. Spray some windex direclty on soft cloth and clean the 2 scanner glasses as well as the white reference above( there are 2 small and big). You may even see it, a mark it the middle of the glass.
This should resolve the issue
Apr 05, 2010 | Brother MFC 420CN All-In-One InkJet...
SONY TV PICTURE WENT BLANK WITH A STRAIGHT LINE THRU IT
want to know wat straight line. 1.white line in the middle from left to right or 2.white line from bottom to top there is a big diffrence in these two lines if 1 then u have to check the cvertical section ,the o/put may gone bad if 2 then u have to check the scanning coil
Jan 09, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
2 lines goin down my telly
Those lines are indicative that the scan circuitry for the panel itself are having issues. Not a very difficult fix if you happen to have a donor. Otherwise, cost prohibitive if not in warranty.
Nov 02, 2009 | Panasonic Televison & Video
Screen has black line down the middle.
it sounds like a setting in the progressive scan or screen ratio menu.
May 04, 2009 | Video Game Consoles & Games
While scanning picture has black line in middle of picture
my copies have a black line in the middle. What could be the cause
Apr 15, 2009 | HP Office Equipment & Supplies
Whenever I scan a picture or document I get a line going down the middle of the page. When I print the same document the line prints down the page. THIS only happens on the scan not when I print from the...
first of all try to make a copy..when you make a copy if you get lines..then clean the scanner glass and the rollers..if its still the same..connect the printer directlu to the wall outlet and then check
Mar 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Yellow line
if you turn off the set can you still see the line in the screen if so you have burn from loss of scan
Mar 03, 2008 | Toshiba 32AF43 32" TV
455 people viewed this question
Top PANDIGITAL Office Equipment & Supplies Experts
Mike
LP
Are you a PANDIGITAL Office Equipment and Supply Expert? Answer questions, earn points and help others
