Question about Sony DVP-FX810 Portable DVD Player
I Used wrong plug in on accident and it sparked and did not come back on. What can I do?
    Scholar:
  • 146 Answers
Might be a fuse in the plug you were using and if you replace it that will solve your problem
can you be more specific if you need more help
does it work on battery
is it attached to car or to plug in house
Posted on Mar 12, 2011
Pulled starter rope, it's now stuck and won't recoil
Cool!
A Project.
Remove the spark plug lead just so you can't have it accidently fire.
Remove engine cowlings as necessary to get at recoil starter.
Remove recoil starter (that's the bit that the pull rope is attached to.
Dis-mantle it until you can find what is wrong. Fix or replace.
Put it all back together.
or
Take it to a small engine repair shop and pay a bunch.
Mar 06, 2016 | Bolens 31cc 2-Cycle Gas Cultivator BL410
What do these codes mean P0102,P0030,P0036 and P0443?
Type: OBD PO443
That is how you look up codes
Spark Plugs get replaced every 3 years
Nothing to do with the codes
Would appear you don't do any Preventative Maintenance
or know when parts are due to be replaced
Vehicles have to go to the shop, even when they work okey,
to keep abreast of the data & how they are working
May 16, 2014 | 2006 Chevrolet Cobalt LT
2004 mercury 150hp,v6,2stroke,spark plug gap
Good Morning Joe,
Please Send Serial No Of Your Motor So I Can Give You Correct Spark Plug For That Engine.
There Are Two Different Plugs Used On Different Models and The Engine Won;t Run Correctly If The Wrong Plug Is Used.
Cheers
Gordon
Apr 08, 2014 | Boating
I am trying to change the spark plugs on a 2002 Kia rio what socket do I use to get them out?
Your standard spark plug socket size is a 5/8. Make sure that you buy one that is used for spark plug removal, these have a special rubber boot on the inside so that you don't accidently break the old plugs in half. Any auto parts store sells this socket.
Aug 25, 2011 | 2002 Kia Rio
Hello, I just replace the spark plugs on my 2005 Cadillac CTS. After everything was installed and I powered up the car it began to idle very high. I double checked my work and couldn't figure out what...
High rpms could be caused by an intake leak or vacume leak check your vacume lines maybe in the process of replacing your plugs you might have accidently damaged a vacume line.
Jan 11, 2011 | Cadillac CTS Cars & Trucks
Changed spark plugs myself and now the check engine light is on?
1. Wires aren't on the plugs correctly.
2. Plugs aren't gapped properly.
3. Wires are on the wrong plugs.
4. A plug isn't in properly.
5. Accidently knocked something loose while changing plugs.
Aug 19, 2010 | 2005 Saturn VUE
Seized engine
Take the spark plug out and fill the cylinder with oil. Place a piece of electrical tape over the spark plug wire opening. Let it set for an hour or so, leave the plug out and try to pull the cord to see if the piston will move freely. If it does, remove the electrical tape, install the plug, connect the plug wire, fill with the correct mixture of fuel, and attempt to start. Note: cover the spark plug hole with a cloth or shop rag to catch any excess oil that will be expelled when you pull the cord through. If it is still frozen.... may be time for a new one.
Jun 15, 2010 | Husqvarna 28cc Gas Line Trimmer
I accidently plugged something into the Service UART and now my TV doesn't work. What can I do to fix it?
The Service UART is used to make internal adjustments or updates to your tv. It is intended to be used by service technicians only.
Since you accidently plugged something into it, it's possible that an internal component has been damaged. Your best option is to call a tv repair shop have have a technician check out your tv.
Hopefully, your tv hasn't been damaged and the tech can get it working again. At the very least, the tech will be able to tell you exactly what's wrong with it and what it will cost to repair it.
Aug 14, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
When changing the spark plugs in my 2000 Ford ZX2 i accidently put escort plugs in the car sounds like it was studdering. i changed them back but it didn't solve the problem still studdering.
if they weren't the right plugs they may have been too long and a piston may have hit it.if thats the case it may be cheaper to replace the engine. look at the wrong plugs that u took out, if they are damaged there is a good chance you have don internal engine damage
May 17, 2009 | 2000 Ford Escort
Replace spark plug 2003 dodge caravan v6
hi the front ones are not bad but the back ones you will have to get from under the van.( do them one at a time)
Jan 31, 2009 | 2003 Dodge Caravan
Sony DVP-FX810 Portable DVD Player Logo
42 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
