Question about Franke Plumbing
I have a Franke ATO 400. It leaks. How is the valve accessed
I need to find my tax file number
Can't find your TFN?
  • Look on your income tax notice of assessment or other letters from ATO
  • Look on a payment summary (provided by your employer) or your super statement
  • If you have a myGov account linked to the ATO, you can access your TFN online
  • Ask your tax agent (if you use one)
If you still can't find it, phone the ATO on 13 28 61, 8.00am to 6.00pm, Monday to Friday.
https://www.ato.gov.au/Individuals/Tax-file-number/
Jun 14, 2017 | Computers & Internet
I also have a Franke 200 series faucet and it's leaking where pullout spray attaches to supply tube after replacing washer....is it possible for sprayer hose to leak...its silver not just a nylon hose
Although I am unfamiliar with the name "Franke", I am more than familiar with this problem.
I have had it too many times to count.
I have discovered it takes an assortment of black rubber/plastic washers to fix this.
I even have them in my tool box for this very problem.
Not enough washers will cause a leak, too many and the hose will not ***** on.
I have had to experiment with different washers to get the fix.
God bless your efforts.
Apr 04, 2016 | Franke Plumbing
Franke flair trips the electric when turned on
It might be good idea to disconnect the coffee valve and switch on machine as it's 230v and might be shorted and tripping and blows fuses.If it is then replace brew valve.
Apr 13, 2014 | Franke Saphira Espresso & Coffee Maker
Replace Neopreme Hose on Franke FH160?
Take the whole valve and hose out and go to hardware store etc. That undersink unit is discontinued
Jul 09, 2013 | Franke LB1100 the Little Butler Series...
Hello i have a franke kitchen faucet #fff303 and the spray head is not working is there a replacment head you can send me?
There are websites that give instructions for disassembling the Franke faucets. Also, some have a valve cartridge ($20-50) that can be replaced (you take the handle off, the catridge is inside)/
Jun 15, 2011 | Franke FF-303 Kitchen Faucet with...
Hi, Franke Saphira. 'Empty Drip Tray' message doesn't shift when in descale mode - not in any other mode though, only when trying to descale. Any ideas? Cheers
If you keep the empty drip tray message, especially after making a drink or cleaning operation this points to a leak internally on to the drip tray contacts. or from the thermoblock leaking onto the wiring loom behind the front door panel. An engineer will be required to fix this as the correct seals will be needed. I have been a Franke Service Engineer for 15 Years.
Sep 29, 2010 | Franke Saphira Espresso & Coffee Maker
Franke saphira will not exit rinse unit, will not rinse the coffee head but will supply hot water and steam. but will not depense any coffee. help please. I have had a Franke Man out and he has no clue he...
The machine has two pumps - one for each boiler. Did the Franke man check both pumps were working. If the main boiler pump has failed, the machine will know that the rinse hasn't occurred and won't go any further.
Feb 16, 2010 | Franke Saphira Espresso & Coffee Maker
Hi, I have a Franke FF600 with a serious low flow problem. Thanks
The undersink flow restrictor, attached at the end of the flexible "hose", was clogged. Verified this problem with Franke USA. In support of their product they are sending out a replacement flow restrictor for FREE!
Aug 25, 2009 | Franke PF3000Series Deck Mounted Pot...
I need a new franke sink basket strainer for my franke sink model PRX11021 - stainless steel. What is the model number that will fit this sink and can I order it online or go to a local store?
You should purchase a complete basket strainer assembly. Home Depot or Lowes have some very nice ones. They are a standard size.
Tell them it's for your kitchen sink.
Jan 28, 2009 | Plumbing
Plumbing Logo
97 people viewed this question
Top Franke Plumbing Experts
Donni Steen
ray gallant
William Wurtinger
Are you a Franke Plumbing Expert? Answer questions, earn points and help others
