Question about Whirlpool Calypso GVW9959K Top Load Washer
EP calypso SN cm09034 washing badly clothes often have a sandy residue water only fills to maybe 4 inches or less even when abulky wash. Would appreciate your help thoughts txs Lynne
  • lynneonflute Mar 12, 2011
    Ok have no manual. Where are those two items? Pictures? Again thank also can't lift more than about 6 to 8 oz right now. Lynnette
  • 4,066 Answers
You may have a problem with your pressure switch cutting the water off too soon.
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to "make the switch" stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Posted on Mar 12, 2011
  • Charles T Nevin
    Charles T Nevin Mar 12, 2011
    Part 2 in this Diagram and parts list is you water level switch.
I have a Kenmore series 600 washer which leaves white residue on laundry. I've tried using less detergent (only use liquid detergent) but it still happens. Using Tide detergent.
There are a lot of causes for that issue. Overloading, too much softener, bad drain pump, dirty drum, hard water are some of the more common ones.
Jan 11, 2017 | Kenmore Washing Machines
How do I get more water to fill up in my wash cycle kenmore front loading washing machine?
You can choose second rinse or use less HE detergent. If you are using liquid no more than 1/4 cup for large load.and a little less for smaller load
Aug 08, 2014 | Kenmore Washing Machines
Black type residue being left on clothes
This is a common problem on washing machines, if you predominantly do cold washes.
Over a period of time, a washing machine will accumulate a buildup of Soap Scum (excess soap & softener residue) which can stick to the inside of the drum.
This black coloured soap scum occasionally breaks away from the drum, and attaches to the clothing fabric during the wash cycle.
You can rectify this, by doing the following:
Firstly, purchase a packet of CITRIC ACID from your local grocery store (usually found in the baking isle).
Do the following procedure before going to bed:
1) Do a HOT WASH without clothes (Hi water level, with HOT water) - allow machine to fill with hot water, then add the CITRIC ACID to the water. Allow the machine to complete a FULL wash cycle (i.e. allow machine to agitate for 30 mins or so, then drain).
2) Fill the machine again with the HOT water / CITRIC ACID solution, but this time allow it to sit in the bowl overnight (no cycle).
3) Next morning, set machine to spin & drain (i.e. to empty the solution)
4) Set machine to fill with FRESH HOT WATER ONLY (no citric acid), then set machine to spin & drain. This will flush all remaining residue left in the bowl.
Note: Soap scum residue is caused by using excess detergent/fabric softener. Hot Water flushing should be done every 6 months.
Contrary to what the detergent manufacturers state, you should follow Samsung's instructions by using HALF the recommended detergent.
Samsung machines prefer LOW SUDS, and you may find by reducing the amount of detergent used, you may even eliminate the buildup of soap scum.
"If this has helped resolve your issue, please rate this solution"
Oct 31, 2009 | Samsung SW62ASP Top Load Washer
Whirlpool Calypso stops at 26 minutes and throws ob code
first you need to clean your washer
run the washer with no clothes; add 1 cup vinegar, that will cut the soap residue from the hoses do this on hot wash hot rinse
then when you wash your next load of clothes; fill the tub about 1/4 full, add the soap, turn the agitator to disolve the soap, then add the clothes
this problem happens also if you are using too much soap or a heavy duty soap such as Tide.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer calypso
Unplug your machine for 5 min then turn on spin to remove water. If water won't go you have a bad water pump. Code FL refers to a low water flow problem ( won't fill fast enough ) or old water still in tub.
Next you need to turn off the water ot the unit and remove the water lines. Look into the water inlets on the washer to see if the dirt screens are clogged and not letting water into you unit at a fast enough pace.
Your unit has a water level sensor and should agitate when full, but I believe your machine might be "timing out" i.e. not filling as fast as your unit expects so even though it doesn't fill all the way it begins agitating because it has taken too long to fill. Good Luck!
barneyluc
Oct 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Our Kenmore Elite Calypso was running great. Put in a load to wash and turn it on as usual. Upon returning the basin was full of water and soap. Tried to get it to spin and it did nothing. We have removed...
remove as much water as possible lean washer back against wall remove bottom cover if pump has screws in bottom remove them and try cleaning pump HAVE TOWELS HANDY..if no screws probably older version they were bad for having stripped drive splines only fix was to replace pump
Sep 09, 2008 | Washing Machines
No water?
Calypso's use very little water. The only way to change how much goes in is by the pressure switch located in the console. It tells the machine when to stop filling. A replacment is availible from a local appliance parts provider or online from the manufactures web site. But I can tell you from experience, when you fill one of these machines without a load of laundry inside, it won't even cover the top of the bottom plate. Even with clothes in it, there is still not very much that will go in. More water will be added durring the course of the cycle as the clothes absorb the water (there is less pressure going to the switch and it tells it to fill again). But again, the pressure switch determines how much water goes in. You can access it by removing the 1/4" screws in the back of the console. It is the white circle with the clear tube going to it. Yes, there are 2 that look almost identical. One is for incoming water level and 1 is for recirculation water. The matching part number will be stamped on top of the one you are replacing. Just remove the wire connector, pull the clear tube off, and press the tab while rotating the switch assembly. It will come right out. Instalation is just the reverse.
Jul 11, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Lint or soap residue
Sounds more like a build-up of particles that may very well be in the water supply. There is something that you can try to get rid of these particles.
1. With the machine empty start it in normal eash mode and let it fill. Add 1/2 cup bleach to the water and let the machine run completely through the wash cycle. This will help remove any unseen stains or build-up.
2. When the machine drains and begins to refill on the next cycle, add 1/2-1 cup of white vinegar and again, let the machine finish its' cycle.
3. Run the machine through the wash cycle one more time to remove any vinegar that may have been left behind.
This is not a guaranteed method but I have had some success.
Dec 03, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
