Question about Breville BKC700XL Stainless Steel
Water not coming out. How do I clean the machine?
    Genius:
  • 1,739 Answers
The Instruction Booklet for the Breville Gourmet Single Cup Brewer for the BKC600XL / BKC700XL can be found here:
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/Breville_BKC700XL.ashx
The booklet has an extensive section on cleaning.
Posted on Mar 20, 2011
  • burton787 Apr 10, 2014
    prim it with a serenge, need to push the water to the pump.
No express/water comes out. Powder coffee works well ??
Need the model you are using. You have done alot but some unit need more cleaning an checking.
Jan 29, 2015 | Coffee Makers & Espresso Machines
Astoria sae 2n . the lights stay on. They do not flash. Nothing comes out of the heads but water did come out of spouts that are located directly behind panels. There seems to be one for each espresso head...
Has the machine been cleaned / descaled? Coffee machines become clogged with mineral scale deposits from the water. Some folks use citric acid , about two tablespoons /qt of water, and some folks use white vinegar, 1/2 & 1/2. Place the solution in the machine as if you were making coffee. It may take a few cleanings if there is a lot of deposits. After cleaning dissolve two tbsp of baking soda in a quart of water and run through machine to neutralize the acid.
May 13, 2014 | Coffee Makers & Espresso Machines
Why is no water coming through for coffee
What do you use to clean the machine? White vinegar s a good cleaner for coffee machines. I suggest you place half vinigar and half water in machine and run it as usual- maybe a few times with the vinegar and water. Then place some baking soda with water to neutralize the vinegar.
May 05, 2014 | DeLonghi Magnifica Coffee Makers &...
WATER COMING INTO THE MACHINE IS VERY SLOW. HOW
Most machines have an inlet filter which requires periodic cleaning. If the water hose connection screws onto the rear of the machine, unscrew the hose at the washing machine, remove the filter, rinse, clean and replace.
Apr 06, 2010 | Washing Machines
Gaggia baby 18 momths old water coming through steam bit but no water coming through coffe bit any suggestions libby
HI
If you have a pre-grind button on your machine, push it but don't put any coffee in the brew unit. Push any of the coffee buttons, and see if water will come out then. If it does not, then you have a plugged brew unit and the brew head needs cleaning. I have directions for cleaning.
Jul 13, 2009 | Gaggia Syncrony Compact Coffee...
Cold water button pressed but warm water comes out
Try cleaning the screens in the inlet tubes on the back of the machine and clean out any foreign object in the screens and clean the valves where the water hose hooks up. Do this fist and leave a responce for more help.
Jun 14, 2009 | Maytag MAV7600 Top Load Washer
Aw850 washing machine
Hi, Is the water clean or dirty? If it is clean then your water valve in side the machine is letting by and will need replacing. If it is dirty water then it is coming in from the sink trap if it is connected by this method, Or it is to far down the stand pipe and is coming back in via it.
Let me know....
Jan 26, 2009 | Tricity Bendix AW850W Front Load Washer
Cold water doesn't work in my washer
There's no cold water Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
    if this helps please vote me a fix ya
Jul 18, 2008 | Washing Machines
No coffee coming out of the machine!
First step, increase the grinder size. Note: only change grinder setting while the grinder is spinning. If that does not work, look into cleaning your brew group screens. The machine should have came with a key to remove the screen. If your machine as a preground option try making a preground coffee without inserting coffee to see if only water will come out. If water comes out then you know its your grinder. Usually too small of grinder sizes will stop water flow.
If you need a brew group key:
http://cerinicoffee.com/Saeco_Brew_Group_key.asp
Espresso machine Cleaning supplies:
http://cerinicoffee.com/Coffee_cleaning_supplies.asp
Dec 01, 2007 | Saeco Incanto Classic Espresso Machine
Breville BKC700XL Stainless Steel Logo
881 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Delierious
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
