Question about Garden
Nothing happens when I turn on the key to start it. Battery is at full charge.
    President:
  • 3,074 Answers
Fuse may be blown, PTO may be engaged or parking brake not engaged. hope this helped Tim
Posted on Mar 12, 2011
Turn key to start my 753 bobcat and nothing happens battery has full charge
This could be a neutral switch on the transmission, clutch etc or it could be the ignition switch itself.
Feb 28, 2017 | Cars & Trucks
Have a 2005 Chevrolet Avalanche it won't start we replaced alternator and had battery tested. The lights everything works just won't start
You have to be sure the battery has a full charge, if the battery is down, you can't do any testing. Use a digital multimeter across battery posts everything off, the generic spec for a full charge is around 12.6 volts, if it needs charging, get it charged.
Test the charging system? Even if the generator is new, if a problem on the wiring circuit, it may not work.
If starter motor won't even crank have to check starter motor wiring circuits. When testing make sure tranny is in park or neutral and parking is set. Safety is your responsibility.
If it cranks good but won't start, check spark--fuel--compression. What about your security system?
Oct 18, 2016 | 2005 Chevrolet Chevrolet Avalanche 1500 LS
Keys turns on but wont start the engine
check:
battery good 11 v min
battery conecctions cables, all clean
if automatic trans, in park or neutral selector
if standar trans, press the clutch pedal full down, check switch in pedal
the dash lights all on in switch on, check for antiefth extra
alarm disabled
and doors closed, seat belts
or crank start but engine no start need a full diagnosis for qualificated personal.
Sep 09, 2014 | Cars & Trucks
Turn the key nothing happens, total loss of electrical
Please check all connections. Are lights/horn workings?
Aug 26, 2014 | 1995 Nissan Pathfinder
When turn key nothing happens
check connection and wires at battery for damage or corrosion if good check for power to ignition switch if no power check for damaged or shorted wiring if good turn key and check if power going to relays or accessory's at fuse panel if no power switch may be bad
Apr 08, 2014 | 2002 Saturn S-Series
Wont start, wont turn over, no sound what so ever
check that the battery posts and terminals are shiny clean and tight.. Batteries can read 12.5v on a multimeter but under load they die to virtually nothing. have a load test done on the battery as the indications are a bad cell
Dec 30, 2013 | 2001 Pontiac Grand Prix
My '95 Oldsmobile Achieva is not starting!
have battery and relays tested --leaning toward battery fault
Apr 13, 2017 | 1995 Oldsmobile Achieva
Possible Alternator
have battery and charging system checked. you may have a bad starter.hope this helps.
Oct 14, 2009 | 1997 Buick LeSabre
I have a 1997 Grand Am 2.4 SE that won't start
Check battery full charge, battery terminals are clean, cables aren't cracked, broken or corroded and alternator first.
Which your having replaced your starter with new already. If you're still getting nothing it sounds like a bad ignition switch.
They wear normally and need to be replaced. But as a helpful hint don't place excess keys or weighty trinkets on your ignition keys.
They wear on the seating of the key in the ignition and often promote failure in the ignition from bearing the dangling weight.
Jul 27, 2009 | 1997 Pontiac Grand Am
Battery shows good, nothing happens when turn
Try to boost the car with another.If that works charge the battery and check the charging system, if it doesn't then you may need a starter.
Jun 27, 2009 | 2000 Mercury Grand Marquis
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
