Question about Garden
Just bought a brnad new GCV 190. pulled th ecord once and released it. Now the flywheel will not move.
  • Brian Powers Mar 13, 2011
    It worked! Many thanks! Well worth the money! Your rating of "guru" is well deserved! This is the first time to is focus and we will be back!
2 Suggested Answers
SOURCE: just bought gcv 50 300
You offer much opportunity for research and discussion.
This would be a good topic for the Tank forum as there are professional plumbers with specific and general expertise on different model numbers.
http://www.waterheaterrescue.com/TheTank.html
Fixya is not a forum since we parcel an answer, then move to next question.
Discussion is not common, and typically one person answers this question, and then that question is removed off the question board.
If you are wishing to diagnose pilot light yourself, assuming product is not defective, and you are not already professional in the field, then following links offer resource:
http://waterheatertimer.org/images/Negative-pressure.jpg
http://waterheatertimer.org/pdf/Gas-venting-specs.pdf
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Aug 31, 2011
I need a Honda GCV 190 operation manual that is on a Ryobi 3100 psi power washer
Please click on the link for the operators manual for your engine a Honds GCV190
Hope this helps
Brad
http://cdn.powerequipment.honda.com/engines/pdf/manuals/00X31Z8B0240.pdf
Jul 29, 2014 | Garden
How honda gcv 190 rpm adjust
you need govnor adjusted take to shop govenors are tricky
Jul 27, 2014 | Honda Garden
Husqvarna problems
Follow the cable to make sure it isn't stuck. If the cable moves freely, check that the flywheel brake and any attached springs are connected properly. These are usually under the pull start cover.
Jul 19, 2014 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Pull cord won't engage
remove the sparkplug and try to turn the flywheel if it turns freely then the engine is most likely ok. if it does not turn you have a locked engine that means its toast. If it does turn then you have to look closely at th pull recoil that it is engaging the flywheel.
May 04, 2014 | Echo Blower Nozzle Es 2400 Pb 200 201 2100...
Broken Flywheel?
if you have aspare flywheel take the old one off take hood off and then take the nut out off the center of the old flywheel and push the break in so the flywheel dosent magitize to the coil once you do that take olld flywheel off but make shure you dont forget that little key goes in the grove when you put the new flywheel on also make shure that key is as close to the top as you can get it the tighten down ne flywheel put your hood back on and it will start just fine
May 02, 2013 | Mtd 22" Yard Machine Push Mower
Oil runs out under flywheel when motor starts honda GCV 160
Your top seal on the mower motor is faulty...replace with new seal...
Mar 25, 2013 | Homelite For Husky - Pressure Washer Pump...
How to replace starter abendix on 1997 saturn l2
pull out the starter, put a new one in. the bendix is the lever contraption on top which moves the gear forward to engage the teeth on the ring gear or flywheel and which retracts it, like a turtle head, when the starter switch is released. i think the days of replacing the bendix only are gone, and the hassle involved in pulling a saturn starter on a 91-99 1.9L means you do it once.
Dec 03, 2010 | 1997 Saturn SL
My almost new Honda GCV 160 engine will not start.
Hi , I think you need someone to remind you these engins are not made by god and they work by obeying three simple rules ,
1.Spark , Can you see a very good blue spark
2.compression,,can you feel strong compression ,
3.fuel , is the right amount of fuel getting in , is the air mixture good ,
Now try these things
Find the manual and PROPPER set the gap in the spark plug ,
clean and check the air filter ,
remove all fuel and replace with brand new,
check the fuel filter,even in the tank tap?
undo the screw at the carb bowl , can you see petrol leaking ,
If everything checks out then try this to get it started,,
spray "easystart" in the carb , bypassing the air filter ,
if it wants to start but cant for long then its a carb problem
check float hight , float needle,jets and pins ,too much air getting in
find someone thats good on motorbikes , They like me know all the tricks to get things to start ,
Aug 16, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
644 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
