Question about Apple MacBook Pro Notebook
Just bought a 4gb attache, plugged it into the usb on macbook pro and nothing happens
    Novelist:
  • 147 Answers
You can try going to the Disk Utility (which is under Applications > Utilities > Disk Utility), selecting the drive (if it appears) and click "Mount". If it doesn't show up in the Disk utility, then the device may not be connected properly, the USB port may not be functioning, or the device may be malfunctioning. You may try reformatting the drive with the Disk Utility if it is blank and you are just using it for the first time.
Posted on Mar 12, 2011
Maxell 4gB stick - no response
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Mar 19, 2012 | SanDisk 4GB Memory Stick Micro M2 Memory...
Just purchased a pny 4gb fashdrive for a MacBook. It is noy recognized on either USB port
is it compatible to the USB technology ? as in USB 2.0 vs. USB 1.0
try the flash drive on another computer , sometimes if you format the flash drive (Insert into USB connection, right click and press format) -- that may work
let me know please.
Nov 03, 2010 | Apple MacBook Pro Notebook
Can I upgrade my Macbook Pro to more than 4GB ram?
4GB is the MAX but only 3GB is utilized.
What Os are you running. Tiger Leopard Snow Leopard?
Nov 23, 2009 | Apple MacBook Pro Laptop Computer with...
4GB Attache flash drive says it's locked.
Plug in the stick. wait for it to come up on the desktop then click on it once. (do not open it).
From the file menu select "Get Info"
In the panel that opens up you will see a row of coloured squares. Underneath is a checkbox marked "Locked"
Is it empty or ticked?
If it's ticked, untick and see what happens in disk utility. If it's not ticked that then would appear to be a problem with the stick.
For what it's worth, I did a google on this stick and found that there are numerous posts about it becoming read only on Vista, so it may well be a problem with the manufacturer.
Sep 07, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Macbook Pro mouse working temperamentally
Hello, it seems that the problem comes from your mouse: can you test your mouse on another computer and check if it does the same? If yes, you'll have to change the mouse
Jul 04, 2009 | Apple 15.4 MacBook Pro - Intel Core 2 Duo...
I have a new Macbook, but it doesn't have a
Buy a USB card reader, this will show your card (which you used in the camera) as a normal disk in finder
Jul 02, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
USB flash drive not recognized by Macbook Pro
hi im josh in cebu phils. if that happened that the usb port don't detect your usb drive then there maybe some problem in your pc. friend all you have to do is check first the usb connections of your pc.you can browse the my computer device manager then click the usb icons and see if marked + or 2nd you reboot your pc then go to bios setup utility then go to peripherals then check wether it is enable.if disable usb on board you enable it. and don't forget to save the changes you made before you exit. then reboot your pc. then problem will be solved. good luck please vote me so that i will know if i helped you.thnks
Feb 23, 2009 | Apple MacBook Pro Notebook
MACBOOK PRO DAMAGED USB PORT
Hardware. Had a bad spill with a drop? Very unlikely you can have it fixed cheaply, but go to your local mac store and see if you can get it fixed.
Jan 27, 2009 | Apple MacBook Pro PC Notebook
Apple MacBook Pro Notebook Logo
184 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
