Question about RCA HD50LPW175 50" HDTV
My tv made a loud pop and then started shutting its self on and off and makes a kind of sizziling sound in the left front side. So I turned it off unplugged it and then tried to turn it on again and it made that sizziling sound again.
    Scholar:
  • 155 Answers
Sorry to give you a bad news but probably an electrolitic capacitor on the power supply section went bad. You will need to bring your TV to a repair center, hopefully is still under warranty.
Best regards
Posted on Mar 12, 2011
Loud thumping from under drivers side that started with a squeal.
16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - ‎10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
Feb 03, 2016 | Cars & Trucks
2003 Isuzu Rodeo right front tire making noise when going over speed bump and loud popping noise when turning to the left
Two faults here ,one is the drive shaft universal on the end of the drive shaft and the other noise ? well could be anything and without a good look and a wiggle with a 4ft crow bar i honestly couldnt say
Jul 05, 2013 | 2003 Isuzu Rodeo
Loud noise in front/side. When make a sharp turn
most likely a cv axle if it makes popping noise in turns
Jul 07, 2010 | 1991 Subaru Legacy
LG Plasma 42pc3d turns on, pops, then turns off
The first thing you should look into is the Z-SUS board, the one situated on the right side viewed from the rear. This board develops a high voltage during operation that might be the source of the popping sound. It is also responsible in refreshing the panel for proper picture display. The weird colors on your TV indicates a faulty Z-SUS board.
Note: Unplug the TV and wait for at least five minutes in order to allow the voltages to drain before you disconnect or reconnect any connector.
  • Disconnect the Z-SUS board from the Y-SUS board. The Z-SUS board is situated on the right side viewed from the rear of the TV while the Y-SUS is on the left.
  • Plug the TV back and turn it on.
  • You will still be able to see the weird colors the moment the TV shut off but do not flash. If it does not pop and stays on and there's a sound, you are pretty sure the Z-SUS board is faulty. Replace it.
  • If it still pops and shuts off, disconnect the Y-SUS board from the power supply. The Y-SUS board also develops a high voltage during operation. The power supply is the one right between the Z and Y-SUS boards.
  • Re-apply AC power then turn the TV on.
  • You'll not be able to see any color or video. If it does not pop and stays on with sound, you have a faulty Y-SUS board, replace it.
  • If it still pops and shuts off, please let me know.
Feel free to update me of the result and your own findings.
Dec 03, 2009 | LG 42PC3D 42 in. Plasma Television
Loud popping sound when turning left
I recently had the same problem, it ended up being the front stabilizers and the drive shaft.
Oct 26, 2009 | 1999 Chevrolet Tracker
It shuts its self off picture is still great everything works great it just makes a loud pop and shuts its self off i can turn it back on after a few minutes sometimes it shuts off again minutes later and...
saw a similar problem w/a Samsung and eventually the Focus Transformer gave out w/a big electric pop sound and all power went out. So it's probably related to a problem with high voltage and Flyback issue. Hope that helps a little.
Oct 02, 2009 | Televison & Video
Pop sound then no picture, just sound
I assume this is a plasma TV? You will have a fuse blown on either the Y or Z sutain board, there is also a possibility one of the driver IC's has blown on the buffer board, this will shut down the screen & leave the audio working normally. You can check these boards which sit on the left & right hand sides of the screen.
Sep 23, 2009 | Televison & Video
3 lights blink and a loud buzzing sound.
Color wheel you can get one at the following link with instructions on how to replace it
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Tv would not turn on and kept turning it's self off when it finally did load was on for 3 mins then a loud pop was heard,TV went black then continued to turn it's self on and off again this did not stop...
The tv has a little door at the right or left side. that is the lamp place (refer to the user's manual to replace the lamp of the unit). make sure you replace the lamp when the tv is unppluged of the power. safety always first.
Apr 08, 2009 | Samsung HLN5065W 50" Rear Projection...
TV made popping sound and then shut off
You need to look in your owners manual for the telephone number and order a new bulb. It should cost about $200, but they will ship it overnight and minimize your downtime.
I've replaced 2 in my WD-52525 in the last 3 years, the first one went like yours did, very suddenly, with an audible POP!! The second one was preceded by an orange warning light, which the book says is a warning that the bulb has about 20 hours left on it.
To replace the bulb, UNPLUG THE TV, remove the left speaker screen, with a philips screw driver unscrew the bulb, pull it out by the handle, then replace it with the same type, in reverse order. This is a very easy replacement that does NOT need to be done by a service technician to complete.
Dec 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
RCA HD50LPW175 50" HDTV Logo
44 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
