Question about Imperial IFS40 Deep Fryer
Flames will not come on
The pilot flame is on, it has gas supply but It will flame up nor I feel the gas comming out of the heads.
I disconnected the hose and test the gas line, it has gas comming out of it. But not from the heads.
  • Anonymous Oct 17, 2008
    how do you adjust the air
    Problem Solver:
  • 10 Answers
U must check the orfuse if the gas come out of that and u dont have flame u must adjest the air
Posted on Aug 14, 2008
Pitco deep fryer flames coming out the fryer
Hi there.
The soot or carbon have probably build up inside the fire tubes, better check and have an authorized service technician clean them.
Make sure that the fryer is receiving the rated gas pressure and correct gas type as stated on the nameplate, this way, carbon or soot formation on fire tubes can be prevented
Regards.
Sep 12, 2011 | Pitco Frialator SG14 Deep Fryer
Yellow pilot flame
pilot is yellow cause its air mixture hole is blocked or you have something in pilot stem like a spider web i have had this problem on flame effect gas heaters during thier off months spiders get into pilot stem and create webs which can cause this the other reason is that the air mixture hole is blocked with carbon or something clean out to get blue flame, and an example of yellow flames in gas heaters is flame effect fires where i know a certain company cover air mixture hole on burner to get the flame more yellow and realistic looking but on a service i remove the foil they stick over hole making flames blue again, as it can cause the heater to carbon up to the extent of black glass with yellow flames
Nov 25, 2010 | Empire BF-10 Mid-Size Heater
Williams 3003622 Wall Mounted 30,000 BTU The pilot light goes out when the main flame shuts down. The pilot light will stay lit for days when heat is not called for but when heat is called for the furnace...
I'm having the same exact problem... At first we thought was the vent... but the way the flames goes out... it seems that there is "not enough oxygen" more than "blown out by the wind"... right after both main & pilot goes out, I can't even light any external flame inside the chamber... and it doesn't feel like the outside cold air coming in... it just feel like there is some sort of gas in the chamber that's so strong, it prevents flame... and the only thing I can think of is that it doesn't have enough oxygen, but too much natural gas, and flame can't sustain.
Nov 02, 2010 | Williams 3003622 Ceramic Wall Mounted...
Pilot lights and flames start but, flames go outafter approx 15-20 minutes flames come back on
Depending on what gas appliance you are describing, this is normal...or not. Please tell us exactly what appliance, the manufacturer and the model so we can get you fixed up:) Farmerbear
Sep 30, 2010 | Vacuums
CBN30T,DESA, pilot lights, but flames out when the burner comes on.. burner stays on a few seconds and shuts off due to cold thermo-couple. pilot flame seems to jump up and disconnect from the jet, as if...
ONLY ONE OR TWO THINGS AT FAULT.YOU HAVE A BAD THERMOCOUPLE.THIS IS PROBLEM 90% OF TIME AND CHEAPEST REPAIR.IF THIS DOES NOT SOLVE PROBLEM GAS VALVE IS BAD.HOW IT WORKS:THERMOCOUPLE WHEN HEATED WITH PILOT FLAME CREATES ASMAAL ELECRTRCAL SOURCE THAT HOLDS A MGNET OPEN AFTER HOLDING THE PILOT DOWN FOR ABOUT A MIN..THEN TURN GAS VALVE TO OPEN POSITION AND MAGNET WILL HOLD GAS VALVE OPEN.IF GAS VALVE DOES NOT STAY OPEN IT USUALLY INDICATES BAD GAS VALVE
Oct 13, 2009 | Desa International GWP30T Heater
Dryer starts, heat up than the goes out
Faulty gas valve coils are the typical cause of this type of "cycling". These electrical coils are right above the gas valves and when energized, these solenoids open the gas valves and permit the burner to light. If any gas valve coils are suspected of being faulty, it is recommended that both (all) be replaced at the same time. Hope this helped and best wishes.
Sep 02, 2009 | Dryers
Fire will ignite showing flames but will not stay alight.
Turn off the gas. Remove the unit. Disconnect the thermocouple and pilot assembly. Clean the white powdery stuff out of the pilot assembly. Reconnect and try again.
If that does not do it you will have to replace the pilot/thermocouple assembly.
Mar 19, 2009 | Kitchen Appliances - Others
Flames burn then die down
it sounds like you may have a dirty pilot tube or a weak pressure regulator. I would try blowing out the pilot tube to make sure it is clear and if that does not work then replace the regulator.
Feb 14, 2009 | Dayton Gas Furnace Heater
Garland Range
You may need to hold the red button for a couple minutes...
Apr 23, 2008 | Garland H284-24G Kitchen Range
Imperial IFS40 Deep Fryer Logo
63 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
