Question about Philips Refurbished MAGNAVOX MAGNAVOX PROFESSIONAL PC MONITOR 80 MONO COMPOSITE MAGNAVOX
WHEN I PUT IN A VIDEO TAPE THE TV WILL TURN OFF. WHEN I TURN IT BACK ON IT WILL SAY EJECT C AT THE TOP LEFT CORNER OF THE SCREEN. WHAT DO I HAVE TO DO?
    Sergeant:
  • 347 Answers
Seems like the tape mechanic has a problem. it might not load the tape properly. there is not much to fix by your own. but a local electronics service would help to solve this problem.
regards
Posted on Mar 12, 2011
Model is Sylvania DVC 840G, DVD/CD player with VCR. Have limited space. VCR on seperate shelf in cabinet, had to put two TV converters on top of VCR (top each side) so we could watch TV and tape a...
The tape mechanism belts have stretched and the unit is not running properly. When this happens, microprocessor is programmed to eject tape and shut down unit.
Apr 11, 2017 | Sylvania Televison & Video
My camera won't turn on, and I dong know what to do it charges both buttons turn red but it won't eject my disc the screen won't come on or anything
I have a DCR-HC32. I left mine out in the rain. It would not power on. There is a reset button on the side of the eject tape door. I held this in for 5-10 seconds, the camera beeped and I was then able to eject the tape. This was after I put the camera in the freezer over night since I left it out and it got wet. My touch screen doesn't work. I already bought a new camera.
Dec 20, 2010 | Canon DC100 DVD Camcorder
Tape will not play and will not eject from my Magnavox VCR plus. I can't get any message to come up on the screen. The little video cassette in the upper left hand corner flashes, I have four dashes across...
Try first to unplug and replug after a few minutes. If this fails disassembly and physical removal is the only way. The tape may also be dammaged. In order to disassemble unplug and remove back cover, Remove (label)all connectors between vcr assembly - bottom section - and TV ***'y unscrew the two deep seated screws holding the VCR to the front chassis, remove the top lid with boards, Check to see if the tape is wound around the head (aluminum cylinder) and remove any obstacles or unwind if tape is bunched up. On the right side back there is a gear (wormwheel) that can be moved in a direction that unloads the tape from the head and cassete basket.
This is a big job even for an experienced tech and if you want to salvage the tape would be best left to proffesional. If you feel comfortable going as far as suggested post back here and I'll help along the way.
Oct 14, 2009 | Sanyo DS31590 31" TV
Camcorder not working
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Oct 27, 2007 | Sony Handycam DCR-TRV250E Digital...
While playing back a recorded programme picture is lost and AV2 appears on the tv, sound can be heard on recorded programme playing back.The t.v screen goes black av2 appears in the left hand top corner,...
Does it do so on all tapes? It sounds like you are experiencing a tracking or tape path problem. You might try taking the top cover off, then cleaning the video head. Info is available on the 'net on how to do this. If problem remains, play a tape and see it is wandering up/down across video head. See if any of the tape guides are broken or bent, causing tape wandering. you may also have a problem in the electronics, perhaps in the servo circuitry, which has to do with careful control of tape speed, video head rotational speed, and certain other parameters. If electronics are bad, then VCR is likely a tosser, unless it is a high $ rig. Most electronics are disposable these days, unfortunately.
Mar 08, 2007 | Sony SLV-SE730 VHS VCR
TV shuts off when VCR tries to eject cassette
This is a hard call man. Some combos have to be laid down when taking the back off or it will collapse when you do take off the back, falling over backwards as they are top heavy. These units are so tight inside by means of no room to work so alot of maufacturers have extension cables to attach to componets ie vcr deck and main chassis. After they take them apart. If you really feel confident then lay the set down on its face and take off the back and after the back is off look to see in the deck part if the tape has come out of the cassette or if it all looks normal. If you see the tape out of the cassette ,cut off the tape on both sides and see if the tape will eject. It it does then go back in after and remove the remainder of the old tape. Now it could have been a bad tape but most likly something is wrong with the mechanism. If you cant see anything out of norm, dont try to force the tape out as you WILL cause more damage and most likely unrepairable. Really there are no user serviceable parts inside these buggers so the best advise I can give ya is to disconnect the thing and take it into your repair shop for an estimate!! Good Luck
May 23, 2006 | Samsung CXJ1964 19 in. TV/VCR Combo
Computers & Internet Logo
142 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
