Question about Microsoft Windows 98 for PC
USB What happened to the USB that is write protect error?
  • Anonymous Aug 03, 2008
    sak
  • Thomas Christopher
    Thomas Christopher May 11, 2010
    Flash drive problem??
    Scholar:
  • 56 Answers
Write Protected USBs are protected by some software that provide passwords to get access to it. So that you wont be able to write anything on that drive.
Else,
or sometimes it is protected by the operating system itself that provides the USB Drive to writeprotect. that have some executable files in the pen drive.
Posted on Aug 03, 2008
Cannot format usb says write protected but there is no write protection for the usb
Reinhard, Check the attached links,instruction and guides on removing USB write protection, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2 ways to fix write protected USB drive or SD card
How To Fix Write Protection Errors On USB Stick
How To Disable Write Protection from USB Key
How to remove write protection on generic usb disk drive
Jun 16, 2016 | Electronics - Others
How to fix a write protect usb flash drive
make and model? usualy has a switch or jumper if it has write protect
Jun 03, 2015 | Electronics - Others
Pendrive Transcend 8GB JFV10 error message "Disk is Write Protected"
First
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
However if that does not solve your problem try this
Think this write protection error is due to some virus.
Steps to remove write protection for Transcend users
1) Go to download center of the transcend,here is the link
http://www.transcendusa.com/Support/DLCenter
Type the model no. or part of model number you are looking for.
example: JFV30(all alphabets in Caps )
2) Choose other details like product type etc. and search for your product
3)Then select the product which which is most similar to yours from search results
4)Then download the mFormat utility. You will asked for serial no. if you dont have..enter this no. 1456784523
5) Connect your pen drive
6) run the mformat utility and select full format after full format your write protection will be removed. try twice or thrice if you can't correct at first time.
Thats all...
Jun 24, 2011 | Transcend (589307) Media
Write production error
Jan 10, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
I have problem in my transcend usb 8gb pandrive that i can't copy or delete any ting from pandrive. error is drive is write protected or can't format. please give solution
Jan 07, 2011 | Transcend Electronics - Others
My Memorex USB flash drive is write protected
t seems that your flash drive has some bad sectors since normally that's the error message you get when that happens, try to format your drive under disk management.
Note: your files will be erased if you format your flash drive.
If formatting your flash drive does not solve your problem I will advise you to contact Memorex technical support for better assistance, you can contact them at 1-877-363-6673
May 19, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
WRITE PROTECT ERRORS IN PEN/FLASH DRIVE
Please open the link below and follow the instructions there to resolve the issue if the problem persist after following the instructions then pen drive is defective.
http://techsalsa.com/solution-to-remove-write-protection-from-usb-pen-drive/
Feb 08, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Write protection error
If you have a USB memory stick that has a small slide switch on the side, this switch is a copy protection switch, move this switch to allow you to copy onto the USB memory stick.
Dec 02, 2008 | Pli 003-9100-00 128MB 3.5" HH SCSI MO...
PNY 4 G USB DISK IS WRITE PROTECTED
Not sure what exactly is happening when you try to use the disk. Is it a used disk? Did you just purchase it? Do you get an error when trying to use it?
From the limited information, I would suggest going to the website and seeing if there is a solution from PNY: http://www2.pny.com/support/support_landing_cat.aspx?SectionID=1143 (their support page).
If it still doesn't work, post more details & I'll see if I can help.
Have a good day!
Jul 23, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Microsoft Windows 98 for PC Logo
93 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
