Question about Timex Watches
I HAVE A SAIRLY NEW TIMEX TRIATHALON WATCH AND DONT KNOW HOW TO SET IT FOR DST.. THANKS
  • 39 Answers
SOURCE: TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Posted on Oct 27, 2008
SOURCE: i don't know how to set my timex 1440 sports watch
1. it is easy all you have to do is hit mode
2.then you will se all zeros
3.hit mode again
4.then you will see a number blinking then press start/stop button and it will change to the next number
5.then just set it to your clock time and your done!!!!!!
hope this will help you
Posted on Dec 29, 2008
VOTIT
  • 2071 Answers
SOURCE: how do you set Timex Triathlon Ironman watch?
First look for the set button then press it ,a long press and If it is blinking that's the time you to select the hour ,the minutes,the day/date,the alarms and the special features of your watch.The right button the up and down or for scrolling.Try all of this so your time will set.
Hope it may help you;
Regards;
VOTIT
Posted on Jun 08, 2009
SOURCE: Random display resets of TIMEX Ironman Triathalon(100 lap memory)
Hello RLOWE803,
While I was looking for pictures specific to resetting this watch, I came across your post and thought to reply. I recently replaced the batteries on my watch, which I have owned for nearly 7 years. It is an Ironman Triathlon 100 Lap watch. When I replaced the batteries this time, I forgot to reset, in essence reboot the system, by using a metal needle point tweezers to briefly connect the positive side of the battery to the "AC" pad on the small circuit board for at least 2 seconds. I remembered to do this with at all the other times I had replaced the battery and did not have any troubles after it. This time I forgot and now have the same issue you described. I am not sure where the "AC" pad is on the back of the module. But, it should be apparent if I did it correctly in the past.
Give that a try before sending it off to be repair and wasting time, money and trouble.
Good luck,
CAZ
Posted on Aug 30, 2009
cmcduncand
  • 714 Answers
SOURCE: how to set my timex watch
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 10, 2010
Times iron man triathalon watch: the digital works but can not get analog working. It was a new watch.
send it back, it's broken. Hang on though, if it is like these, there is no analogue! 'Analogue' in a watch is hands that turn mechanically. This watch is digital only. It is like a G-Shock.
Times iron man triathalon watch Google Search
Timex 5E901 Ironman Triathlon 30 Lap Watch
Feb 17, 2018 | The Watches
Do you have a manual for a timex indiglo ironman triathalon digital watch?
Try Googling (timex)(model)(manual) without parens.
May 19, 2017 | Timex Watches
Timex ironman triathalon 100 lap 5F011- need user manual and way to purchase lost gps
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Mar 10, 2011 | Timex Ironman 100 Lap Triathlon...
Looking for Timex Ironman triathalon shock (analog face) manual
manual download"
Nov 25, 2010 | Watches
Setting a 1440
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals. Rate me, please
Mar 15, 2010 | Timex 1440 watch
Watch will not programe to England Time
If it is 1 hour out it could be on daylight saving time setting (DST).
If you haven't got any instructions you can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on manuals/downloads", then on "product
manual download"
Feb 15, 2010 | Timex T5G341 Sports Radio Control Watch
Watch Band Loop Missing
here ya go.
http://www.cdwplus.com/singleotherP.html
Jim
Jan 11, 2008 | Watches
Watches Logo
24 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
