Question about Moen Home
How do I get the drain plug off to clear a clog?
    Genius:
  • 1,739 Answers
This videos will show you how to loosen the drain plug and remove.
Newer Models:
Posted on Mar 12, 2011
I have a problem with my Samsung model no. Sr-L628EV water gathers under the chiller drawer, any idea?
Not familiar with this particular model, however it sounds like a plugged drain. Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged with gunk, resulting in standing water at the bottom of the refrigerator. (A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer).
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Try c
learing the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
Jun 12, 2017 | Samsung Refrigerators
Drain plug on a 2002saab a\c unit.
All A/C units drain water and need a clear path to drain water. If window unit the unit MUST lean to the outside so the condensation water can drain that direction and insure the drain hole is clear of debree. If an indoor central a/c unit the drain must be clogged the unit is leaning away from drain or the pipe going to the drain is clogged somewhere as it exits house. Cant drain if doesn't have a clear path to do it's job. Doubt it's a problem with the brand.
Show Less I hope this info helps Russell.
Jul 12, 2016 | Cars & Trucks
How do i drain my airconditioning unit from excess water?
There is either a plug at the rear bottom portion of the unit or a hose which very possibly could be clogged.Many have a screw in type cap. You unscrew the cap and will find a black rubber plug. Pull that baby out and it will drain.
Aug 03, 2011 | Samsung AW1203B Air Conditioner
How do I clear a plugged defrost coil drain line?
You will need to Clear the drain by forcing a solution of water and bleach or water and baking soda into the drain line with a basting syringe. If the solution will not flow through, slide a length of 1/4 inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog. This will correct the issue.
Jun 20, 2010 | Roper RT14DKX Top Freezer Refrigerator
Is my drain plug clogged on my 2006 ford f150
same problem as??? is it water or coolant??? does it have any smell?usually if drain is clogged you may have water on the passenger floor board. you may take a wire or compressed air and clear the drain, if a LOT of water comes out, you have fixed it.
Sep 21, 2009 | 2005 Ford F-150
My Air conditioner leaks water
Aug 02, 2009 | Kenmore Heating & Cooling
Have whirpool gold with clogged freezer drain plug to drip pan
Hello, You will be unable to remove the drip pan since it is built in, use a curtain wire, push it down the hole..theres not alot of space but can be done until you feel the clog clear...if it's still iced up use some hot water to defrost the ice before you get to the clog..once you think you got it pour some water down the drain to test it's clear. Hope this helps. Good Luck!!!!
Jul 16, 2009 | Whirlpool GD2SHGX Refrigerator
4.0L 6cyl doesn't have a rubber plug in drain housing
clear the ac condensation drain under the car on the bottm of the passenger side eng firewall.
Jun 29, 2009 | 1998 Jeep Grand Cherokee
Home Logo
76 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
