Question about RCA R52WH73 Projection Television
R52WH73 convergence HELP!!!
I have the 3d picture and i dont know what or how to fix it. i have read in the other forums but i dont know how to locate anything everyone is talking about! i need descriptive answers or pictures. please help
  • garrison1080 Aug 01, 2008
    i have the 3d picture and i dont know what or how to fix it. i have read in the other forums but i dont know how to locate anything everyone is talking about! i need descriptive answers or pictures. please help
  • 1,894 Answers
If the convergence adjustment is not moving the beam chances are theconvergence IC(s) are defective. If you know how to solder andunderstand TV safety you may be able to fix it. With power disconnectedremove the back. You should see two large heat sinks with large ICs (3by 6 inches) with about 30 leads going through the circuit board.Numbers on the ICs should usually be something like STKxxx-xxx or somevariation with x being a number. These ICs control the position of thethree beams. If they go bad you can't adjust one or more beams. Replacethem both as you don't want to get in there again in 3 months. Cost isnot that much. or http://www.partstore.comshould have them at a reasonable price. Before replaceing the ICs lookat the circuit board closly for cracked solder joints. Resoldering anybad joints might just solve your problems and avoid replacing the ICs.Good luck and remember safety.
Posted on Aug 01, 2008
  • dewan nafees ahmed Aug 05, 2008
    these ICs can be found in the power board itself sir.
    they are very easy to locate with a service manual. and i would suggest you to buy a service manual for better assistance and it would be safe.
Were is the convergence board located on my tv
The convergence is split between 4 different boards on the rca itc222 model. depending on the symptoms of the picture will determine which one is at fault. What does your picture look like? is it bowed in at top and bottom? Is the picture 3d can you see red blue and geen? When you go into customer setup menu do you see the convergence options. if you see these what effect do they have. Let me know and i will help you isolate the problem....DOnt know but it could be the common fl231 fuse problem. read this to see if you do and let me know how i can help
Feb 03, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Ghost on tv looks like 3d
You have bad convergence ICs. I have a tip at which explains the problem, how to correct it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the great rating!!!
Apr 27, 2010 | RCA R52WH73 Projection Television
It seems the picture has gone bad on our our RCA 52" Model No. R52WH73 projection television. It is only 3 years old. The picture is bowed in at the top and bottom and the color is off. Will it be cost...
Your convergence ICs or convergence board is bad. More than likely it is the convergence ICs. About a $100 fix from a reputable repair shop. Hope this helps. If you need more info let me know.
Jan 25, 2010 | RCA R52WH73 Projection Television
The screen is showing a ghost or double picture
Does the picture look 3d? colors out of place and or skewed?
If it does, go into the customer menu with the Sony remote and select convergence----if red or blue are warped and will not move in some direction--you have a common problem---CONVERGENCE.
Confirm model number and tell me if it is 3D like picture.
I can if it is tell you what is needed to fix it--I am here to help people and I do this here for free.
Regards, SD TECH
Oct 30, 2009 | Televison & Video
The picture suddenly looks 3d and a reset did not work
Ur convergence it dead,need it replaced,know how to solders?Tries these websites for parts.Tv repair,Tv repair kits.
Oct 25, 2009 | RCA R52WH73 Projection Television
Convergence box is out - the picture is like looking at a 3D movie without the glasses.
There are two common problems with these sets.
Problem #1) Convergence
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Oct 23, 2009 | RCA R52WH73 Projection Television
3d looking screen
If the auto convergence didnt adjust the picture back to normal, you will need a new convergence power supply board.
Jun 19, 2009 | RCA R52WH73 Projection Television
Bow tie looking picture with 3d color mis-alignment
you have lost convergence. First thing to check is to see if you are missing the convergence option in the customer setup menu. if you do not have this option then i suggest reading the article in the tips and tricks section entiltled "the fl231 fuse problem" this is a common and sometime easy repair if you do have it then you might need a convergence power board
Mar 09, 2009 | RCA R52WH73 Projection Television
Auto Convergence Problem, no menu option, 3d looking picture
yes the board components are out.not to replace whole board only two convergence ic on the board needs replacement. they are not at all costly this link which is mentioned belkow has all the instructions to replace the ic on the board just click it and follow the instructions
Mar 07, 2009 | RCA R52WH73 Projection Television
RCA R52WH73 Projection Television Logo
51 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
