Question about Garden
Hi, I believe I have a fuel problem with my Landa pressure washer - model ZG2-15421 - with a Briggs & Stratton 3.5 HP model 91212, type 1022 E1, code 971205FA. It is for home use like washing the vinyl siding and the deck and similar stuff - about 20 hours of operation a year. I use fuel stabilizers because of the infrequent use. Late last Fall, the engine would only stay running if the choke was applied half way. If there was less than half a tank of gas, the engine would not start or stay running. Over the winter, I took things apart to clean and check. I found a little bit of grit in the tank; cleaned that no problem. I removed the small cover (4 torx screws) on the side of the carb facing the muffler and its gasket and then tried to clean out the fuel pickup tubes that extend down into the tank with compressed air and carb cleaner. I thought that would do it. Now, the engine only runs for about a minute before stalling. If I rock the unit back and forth to swash the fuel around in the tank, it will start right back up but again only run for about a minute. To start the engine, throttle is at full and choke is applied 100%. Once it starts, choke has to remain at 50 - 75% to keep it running. When it stalls, if I again rock the unit back and forth to splash some gas around, it will start right back up but again only run for about a minute. So, obviously I missed something. I wanted to remove the 2 plastic pick up tubes and reverse flush them (thinking the screen were clogged) but I did not want to break them. Fluid and air moved through the tubes when I had things apart to clean before. Any suggestions would be helpful. Thank-you.
2 Suggested Answers
Biggdex35
  • 333 Answers
SOURCE: Engine wont stay running
It is a diaphram carb. Doe's the primer **** straight gas or does it have air bubbles in it? If it has bubbles in it then it is a leak in the fuel line.
If not then Unhook the intake fuel line and pump the bulb until all of the gas is out of it. Then pour the gas out of the tank and rinse it out with new gas. Pour in new gas and it should be ok.
Posted on May 24, 2010
Small engine problem. I have a 3.5 hp Briggs and Stratton engine that runs very roughly. The fuel mixture screw makes no difference, all the way open or all the way off. The model is 91212 0196 01.
Are you running the correct fuel and when was the last time the spark plug was replaced? I think that engine could be a Two Stroke so it's a fuel AND oil mixture. A local lawnmower repair man would be a good person to ask about that. Get the mixture screws back to where they should be and refill it with the correct fuel. Running the wrong fuel will kill the engine.
Oct 25, 2017 | HP Measuring Tools & Sensors
Briggs and stratton model # 91212 type 0219-01 code 93110403 throttle and linkage diagram
go buy a manual. theres different configurations for that model and spec. also put a "0" in front of the "9". should be 091212. briggs needs 6 digits for look up.
May 21, 2016 | Garden
I have a 3.5 horsepower B&S push lawn mower. It is easy enough to start, but once started it fluctuates. Runs high and then low almost as if it will cut off and then it runs high again. What can I...
I have a Briggs & Stratton 3.5HP Model 91212 type 1319E1 engine that I'm having trouble keeping running. Once it starts it will run about ten minutes, then die, and then is impossible to get re-started. Is this a carburetor problem, or possibly a coil?
Kent
Aug 31, 2011 | Briggs Stratton IC Horizontal OHV Engine ...
I have a white mower with a 18 hp intek v-twin briggs & stratton motor. I was cutting the lawn and it loss power all of the sudden, then it died. Now it won't start. I changed the plugs, which looked...
back pressure is from a blocked muffler ( carbon build up)
if it is that old then it could be overheating from grass and dirt build up around the cylinder fins and not cooling properly
Apr 06, 2017 | Briggs & Stratton Briggs Stratton Intek V...
I have an old briggs stratton 2001 power washer its hard to read model number it looks like EXYRB2321 or EXVRB2321 its 6 hp when i put in ether number at B&S sit they say no results i need a...
Excell pressure washers used a series of numbers such as yours. I believe that that number will be for pump or pressure washer as a whole unit. Check Excell web site for a match. If you are looking for the engine model number check the fan shroud or valve cover or tag on engine itself. Good luck
Sep 06, 2010 | Briggs & Stratton 020324 3700 PSI Pro...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
