Question about Casio Boss Business Organizer
Data error check your owner's manual for procedure
I turn on my casio SF-5580 organizer and I get the above error message, when I attempt to do the all reset procedure I am still unable to reset the unit. i
  • roccit Dec 19, 2008
    When I turn on my BOSS SF 5580 I get the DATA ERROR Message. When I reset it I get Are You Using this Unit For the First Time (Y/N)? message, to which I press N and get the Data Error Message Again.
  • spuki May 22, 2009
    I also have the same problem with the Casio SF-5580. when i installed new bataries in the unit i got the massage "DATA ERROR please see manual for procedure" . In the manual said,i have to make RESET and erase all the DATA stored in it. PLEASE, if someone knows any other way to solve the problem or to get the data from the unit, i will
    Appreciate. I DONT WANT TO LOSE THE DATA. THANKS
5 Suggested Answers
tom19511
  • 1601 Answers
SOURCE: casio sf-5580 128kb
Here is the manual. It will show you how to change it..
http://ftp.casio.co.jp/pub/world_manual/cal/en/SF5580_5780_5980_E.pdf
Posted on Jan 14, 2008
otacon
  • 1944 Answers
SOURCE: Broken Screen on sf-5580
I am guessing that you are trying to send your data from one sf-5580 to another sf-5580. You can see what is shown on the screen in your user manual on page 69 and 70 (including full instructions and what buttons to press). If you don't have the manual then you can download it here.
SOURCE: I have a problem with the Casio SF-5580. when i
After you change the main batteries it will tell you to press the reset button. Go ahead and do this. You will then get a message asking if you are using a new unit for the first time (Y/N)? Be sure to press N in response to this message (pressing Y will delete all the data in memory). You will then be prompted to rest the Home Time.
Posted on Feb 19, 2010
SOURCE: casio SF 4600
You have to press the reset button on the underside.
Note, You will lose all data!
Posted on Nov 24, 2010
How do i fix a data error
Go to Casio Support webpage:
http://support.casio.com/en/manual/manuallist.php?cid=013
download the user manual that seems closest to your model. You might be able to rectify the problem this way.
Jul 24, 2014 | Casio B.O.S.S. SF-5300b: Business...
Jan 14, 2008 | Casio Boss Business Organizer
It says consult owners manual fo data error
For Digital Diary Owners Manuals:
Oct 01, 2013 | Casio B.O.S.S. SF-5300b: Business...
How to solve the problem of data error in casio digital diary sf-3990 128kb
it sounds like your batteries died out ..if you are getting the data error message, pres the clear button( the on button) to review all old data and transcribe any important info(telephone numbers etc.) then you replace the batteries and hope it keeps all old stuff... if not after the change you need top press the reset button on the back and replace any lost info....good luck
May 13, 2010 | Casio Boss Business Organizer
I have a problem with the Casio SF-5580. when i installed new bataries in the unit i got the massage "DATA ERROR please see manual for procedure" . In the manual said,i have to make RESET which means erase...
Jan 28, 2010 | Casio Boss Business Organizer
Casio SF 4600
Jun 23, 2009 | Casio Boss Business Organizer
Casio BOSS 5300
I would suggest doing a "Reset". You will loose all your data, but at least you will be able to use it. You do a Reset by removing the bottom case, turning on the BOSS, them pressing the Reset button located inside.
Jul 21, 2008 | Casio Boss Business Organizer
Casio BOSS SF-5300
Once the DATA ERROR DISPLAY appears,You will not be able to INPUT or EDIT DATA, though you will be able to recall Data after pressing CLEAR to clear the error message.**YOU WILL
WANT TO SAVE ALL YOUR DATA OR WRITE EVERYTHING DOWN AT THIS POINT, BECAUSE THE ONLY WAY TO GET
THIS DEVICE BACK TO NORMAL OPERATION IS TO PRES RESET IN THE BACK -IF YOU PRESS RESET YOU WILL LOSE ALL INFORMATION PERMANENTLY.
In order to return the memory to normal (allowing further input and editing of data), you must perform the RESET OPERATION to clear the memory of all data-Make sure you have backed up or taken a hardcopy of this information before Resetting or it will be gone and there is nothing you can do to get it back.Once you have RESET you can re-input the data you have written down.
WHAT CAUSES THE ERROR MESSAGE?Interruption of battery power.Severe electrostatic charge,impact,change in temperature
or humidity.Hardware Problem.
Recommendations:Replace batteries every 2 years, regardless of use.Use only CR2032 Lithium batteries.Replace all batteries-Never mix old ones with new ones!
Caution: All data stored is lost if you remove more than 1 battery at a time. The following Info is per the instruction manual-WHICH ALSO SAYS :Be sure you keep a separate copy of all important data that you store in the SF-5100/SF-5300.Hope this helps.
May 28, 2008 | Casio Boss Business Organizer
172 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
