Question about MTX JackHammer JH202 Car Audio Amplifier
My inline fuse blew...i replaced it and the amp fuse blew. i read that i could have the bridged wires wrong, but i disconnected the wires and put a new fuse in and it blew as well...it doesn't appear to have any bad power or ground wires?? any advise?
    Scholar:
  • 146 Answers
If you disconnected the amp from the power wires - and there was nothing conncted to power wires - and they werent touching anything including each other - and the fuse still blew then there is a short in the positive (+) wire. make sure you are connecting the wire with the fuse to a proper, switched connection and make sure you use a good clean spot on the car body to ground your amp.
If you meant that you disconnected the speaker wires from the amp then you should try to disconnect the amp from power and source and then that will show if you have blown the amp.
If you give me more specifics I can help you more if you need
good luck
Posted on Mar 12, 2011
  • 643 Answers
Could be the internal fuse on the amp or the fuse doesnt have enough for the amp.
As soon I turn on the car the fuses on the amp go out !!! What am I dealing with here
Disconnect the remote wire from the amp and bridge a wire to the remote port from the positive... if the fuse doesn't blow its most likely a corrupt remote wire from the head deck or the wrong wire...If it still blows when bridged, open up your amp and check the inside terminal look for thin strands of old wire crossing the +/- as its common in used amps...
Jan 27, 2014 | Car Audio & Video
Amp on but no sound
Double check all of your fuses and make sure they are the corrects AMP. Other than that it sounds like the speaker wires came loose somewhere along the line. check on the subs and behind the deck. hope this helps
Apr 22, 2013 | Pyle PLA2678 POWER SERIES BRIDGED MOSFET...
Caravan 12v tv/dvd units blown thru hard wiring to 12 volt battery why?
There will either be an internal fault or a short in the connecting wiring, disconnect them and put fuse in, if ok then fault is with tv/dvd unit
Mar 08, 2012 | Cars & Trucks
My kenwood KAC-7204--- the wiring is hooked up right, I just got a 2000 watt max sub 1000 watt rms, i was running the amp in bridge mode and it ran for 1 day than it turned off. I checked it and the fuse...
when i was running my sub off bridge mode this kept happening to me. I ended up just running two subs and for some reason the fuse stopped blowing. i think there is something wrong with these amps.
Jun 04, 2011 | Kenwood KAC-7204 Car Audio Amplifier
I was using bridge on a Rockford P300 and blew my cheap speakers but now my bridge doesnt work. Bought new speakers and want to run in bridge mode is there a fuse inside maybe or did I blow it up?
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Your amp is clipping.
No internal fuses. Your mosfets are toast. A thumbs up would be greatly appreciated if this answer is helpful to you. using-bridge-rockford-p300-blew-peeu4x5nsxvd53n2rwetiqa4-3-0.jpg
Apr 07, 2011 | Rockford Fosgate P3001 Car Audio Amplifier
Soon as i try to connect the power and ground starts sparking and my fuse blows by the battery. I changed the ground cause i thought that could be it plus i tryed installing it in another car that had an...
your inline fuse wouldn't blow if there was just something wrong with the amp. the amp fuse would blow if that was the case. something is faulty with your wiring. you probably have the wires touching somewhere or are in the wrong terminals at the amp or on the wrong battery terminal. or your power wire is grounding out somewhere. its not the amp. its your wiring
Mar 16, 2010 | Car Audio & Video
The Red & Black wires connected to my AMP touched
You blew the inline fuse on the AMP power wire. If it was not fused "inline" you may have blown a fuse internal to the amp. Look on the amp(or consult the manual) for the location of fuses "internal" to the amp.
May 01, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Keep blowing fuse under hood when i put power wire in to amp
disconnect the negative battery terminal, replace the fuse with all the wires hooked up to the amp and reconnect the battery terminal, that way the initial surge of power goes through the negative terminal and not your inline fuse. That should solve your problem.
Mar 29, 2009 | Pioneer GM-5200T Car Audio Amplifier
My 800 watt kenwood
Sounds like you shorted out the main power wire somewhere and killed the amp. Is the amp on the fuse intact or blown? Do you have 12 volts at the amp? check you connections and see if it helps.
Jun 03, 2008 | Kenwood KAC-7201 Car Audio Amplifier
MTX JackHammer JH202 Car Audio Amplifier Logo
132 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
