Question about Frigidaire Freezers
Frigidaire freezer keeps tripping circuit breaker, freezer works fine, no noise from the compressor.what would make it trip the breaker?
jumptrout51
  • 3361 Answers
SOURCE: Once in awhile, Circuit Breaker Trips
Your compressor start relay contacts may be getting loose or worn, resulting in a delayed start on the compressor.
If the start device includes a capacitor, it could be getting weak.
GFCI are not good receptacles for devices with high starting torque.
Posted on Apr 22, 2009
jumptrout51
  • 3361 Answers
SOURCE: Tripping the breaker
Check the start relay. If it is OK the compressor is bad.
Posted on May 12, 2009
bobicehouse
  • 1524 Answers
SOURCE: Everything works fine, except when the compressor kicks in the panel breaker trips.
Most likely a short in the compressor electrical components (relay, overload,capacitor) Supco makes a 3 in 1 that you could use. If this works fine, if not "bad compressor".
Posted on May 28, 2009
  • 744 Answers
SOURCE: Frigidaire chest freezer- the compressor tries to
This sounds like a bad overload relay or locked up compressor. If you are very technical, you can do some troubleshooting by checking to see if the compressor pulls "locked rotor" amps when it tries to start. This information should be on the unit nameplate and will be listed under "LRA". This requires special testing equipment (an amprobe). Also check for any bad connections at the plug and the terminals where the cord terminates inside the electrical compartment on the freezer.
Something else to try is to plug the freezer into a different electrical outlet and see if the same problem occurs.
If the freezer is over 15 years old and the compressor is bad, it will not be worth the cost of repairs.
Posted on Dec 30, 2009
woodchuck789
  • 4059 Answers
SOURCE: Our Frigidaire freezer went off
Freezers and other big appliances don't do good on GFCI circuits. They pull too much voltage and amps. Try in on a regular plug and see how it does.
Posted on Apr 12, 2011
Frigidaire upright freezer ice forming in bottom and leaking not freezing ice cream
This does not sound good because the breakers tripping may indicate a compressor windings short. Have someone do the test below,
Unplug the refrigerator and remove the back panel that covers the compressor. There should be 3 wires going inside the cover of the compressor. Mark all 3 and mark their location so if compressor is OK you can put them back in same order. The plastic cover may snap on and you may need to squeeze the sides to unlock the cover and sometimes there is a metal clip holding the cover in place. Remove the cover. May look hard but it's simple. There will be three connections under the cover and 2 will go through the start relay. Unplug them leaving the three prongs exposed. They may be marked R =Run, S=Start and C=Common. Set your meter on continuity and then begin by testing 2 at a time until you have checked S to R and R to C an C to S and S to R again. You should get a reading all the way around. If no reading between any of the pairs as you go around you should get no reading between any two the compressor has an open winding and is defective. Then if it passes that test then touch one probe to R and the other to the copper pipes or clean metal on outside of compressor, then S to metal outside and C to metal outside. If you get a reading this way even just a little. The compressor is a burnout. Then let me know what you find. Thanks, Sea Breeze
Feb 07, 2013 | Frigidaire 20 cu. ft. / 566 liter Upright...
15 AMP breaker keeps tripping
do a amp check on the compressor and fans.That will tell you exactly what is overloading.
Apr 21, 2012 | Kenmore Freezers
Circuit breaker tripped and freezer off 24 hours. When reset, 8 shows on front of freezer and no sound from motor. Light doesn't work inside.
dear sir /madam
if your freezer,s electrical safety switch is tripped of it,s an electrical problem it can be possible your compressor getting extra load and there is some electrical trouble please contact to your freezer maintenance personnel for further action.
hope answer the question
thank you
please vote!
Aug 16, 2010 | Frigidaire 12 cu. ft. / 340 liter Upright...
Tripping electricity
HI, The reason for the over-pull is due to the unstable conditions located at the main PCB that controls this affected unit. The voltage is not stable, due to the damage located at the PCB(circuit instabilities). Just to be safe, have your local electrician inspect the breaker box for shorts and damage to the appropriate circuit block. If the electrician confirms that the breaker is in good condition; replace the main control board(PCB) that is mounted near the compressor or behind the rear access panel.
Jul 21, 2010 | Whirlpool Freezers
Frigidaire chest freezer- the compressor tries to start for three seconds or so and then the circuit breaker for the outlet trips.
Dec 30, 2009 | Frigidaire 13 cu. ft. / 368 liter Chest...
Kenmore upright freezer model 29238 keeps tripping switch
If the compressor actually runs for more than a second or two its likely the compressor is bad. Some models had a 5 year warranty and some ten years on the compressor only. The replacement of the compressor is likely beyond your abilities unless you are a service technician.
A typical cost for such a repair can be more than the freezer may have cost you if nothing is under warranty. Good Luck.
Aug 31, 2009 | Kenmore 14.8 cu. ft. / 419 liter Chest...
May 27, 2009 | Beverage-Air 44.9 cu. ft. / 1271 liter...
May 12, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Apr 22, 2009 | Frigidaire Freezers
Freezers Logo
210 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
