Question about MicroBoards PF-2 Disc Printer
I have a PF 2 Microboards. The printer is not allowing the cd's to drop into the slot automatically to be printed. I have to drop it in manually. Please help!
  • Ed Citronnelli Mar 12, 2011
    Please simplify your solution a bit. I don't understand to "unzip cd cover" and the rest.
  • 310 Answers
Possible towing opne-close system is broken.Try to unzip and look at the cd cover,not be skipped by itself.
Posted on Mar 12, 2011
How do i clean the print heads
Get the manual here, and it will show you the clean function... http://www.manualslib.com/manual/103031/Microboards-Technology-Pf-2.html
Jun 28, 2014 | MicroBoards PF-2 InkJet Printer
DISC STOP FEEDING AUTO TO PF-2 PRINTER MICROBOARDS PRINT FACTORY..
Most likely the gravity fed disc cingulator needs to be replaced. My company can replace that Microboards Printer part for you. Call 952.944.0083 or visit.
Jan 24, 2011 | MicroBoards PF-2 InkJet Printer
Microboards pf pro refill cartridge
you can now get continuous inking systems for the microboards pf-pro machines
see here:
http://www.jpldisplays.com.au/catalog/product_info.php?products_id=4150
Mar 17, 2010 | Microboards PF-3 Print Factory Printer and...
PF-2 Won't detecd cd
First try re-installing the PF-2 print drivers. If that doesn't work, then try a different ink cartridge. If you have printed more than 5000 discs in the printer, it just may need a good cleaning as the sensors would be full of dried ink.
www.techwaredist.com
Nov 07, 2008 | MicroBoards PF-2 InkJet Printer
Microboards PFII just keeps rolling discs and will not print
Di arleady did the first thing that we advise of customers to do - reload the PF-2 print drivers. Since that did not work you a most likely looking at needing the print engine replaced. This typically costs $600+ depending on how full of ink the inside of your printer is. Hoefully your printer is still under warranty with Microboards. If not, you can call Microboards at 952.556.1639 or check ou this repair company
http://www.techwaredist.com/repairshop.asp
Oct 16, 2008 | MicroBoards PF-2 InkJet Printer
PRINTER NOT PRINTING CD/DVD JUSTV ROLLLIN
your front sensor is out ive got like 6 of these printers and its not cheap to fix microboards charges around $500 give me a email at csymackenzie@yahoo.com
Sep 09, 2008 | MicroBoards PF-2 InkJet Printer
PF-2 "singulator problem.
You need to replace that part. My company had to do it last year, and we need to do it again soon. It breaks down easily and will work like that.
Call Microboards. They'll send you a part (you'll probably have to pay for it - ours was under warranty) and show you how to install it.
Jun 02, 2008 | MicroBoards PF-2 InkJet Printer
Dvd feeding problem
The reason you are having trouble with DVD's and not CD's is that the DVD's are a little thicker or taller than the CD's. The area above the belt system has to be adjusted upward. this adjsutment is not in the manual, and is complicated. My company, Techware DIstribution, has had as many as 20 of the PF-1 and PF-2 printers running in our production and demo room. We can walk you through the steps to make the adjustment if you like.
Contact info: http://www.techwaredist.com/repairshop.asp
Mar 24, 2008 | MicroBoards PF-2 InkJet Printer
Only 1 copy at time
The previous poster is most likely correct. You have to use Microboards ink for the PF-2, PF-3 and PF-Pro printers. The part number you need is the PRF38ml. The PF-2 printer has a sensor for the barcode on the PRF38ml as well as a RFID chip for verification.
If this does not fix your issue, then the sensors that scan the barcode and the RFID chip may be broken, dirty or out of alignment. If so, you need to contact Microboards or an authorized Microboards repair center for repair services.
Dec 15, 2006 | MicroBoards PF-2 InkJet Printer
MicroBoards PF-2 Disc Printer Logo
138 people viewed this question
Top MicroBoards Office Equipment & Supplies Experts
Starnley Johnwells
Starnley Johnwells
Don  Farrell
Don Farrell
Are you a MicroBoards Office Equipment and Supply Expert? Answer questions, earn points and help others
