Question about Lexmark X1270 All-In-One InkJet Printer
Recently moved, lost cables to connect lexmark x5490 to comp. Leads missing. Bought 2 leads, but the power pack in the back of the printer is missing. Where can I purchase one of these please?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Lexmark Master
  • 544 Answers
You can contact Lexmark Technical Support at 1-800-539-6275.
You may need the serial number of your printer.
Posted on Mar 13, 2011
When i plug in my power pack nothing happens, the green light on the pack is light at first then fades off.There is no power and i cant turn the comp on. Is this a problem with m battery, pc, or power...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to fail to detect a hard drive continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
problems
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 14, 2010 | Computers & Internet
X5470 All-In-One InkJet Printer: i lost my cd for my printer lexmark x5490.my compu...
Download the software driver from the web link below and install it and check
98/Me/2000/XP
http://en.kioskea.net/telecharger/telecharger-895-driver-lexmark-x5470
If the issue still persists get back to me with the Operating system
May 18, 2010 | Lexmark X5470 All-In-One InkJet Printer
Power and computer connection wires for Z43?
You will need a Plug-In Power Unit marked
“Class 2” and rated 30 V dc at
500 mA. and dependant on the type of connection either a USB lead or a parallel printer lead(Centronics).
Oct 29, 2009 | Lexmark Color Z43 InkJet
When activating Lexmark X5490 it moves the cartriges violently
If it has been torn or has any signs of damage on it then it might not work by just putting it back.
The best might be to take it to Lexmark and see what they can do.
Aug 28, 2009 | Office Equipment & Supplies
Lexmark x5490 Right /left cartridge incorrect
If you brought new cartridges and printer detecting it empty ,then you get it
replaced as the Lexmark cartridges comes with a 6 months warranty ..
Good luck....
Feb 13, 2009 | Lexmark X4530 InkJet Printer
Lexmark z23 cartridge banging
The encoder strip may have become unseated. please follow the steps given below:
The embedded links in the table lead to specific troubleshooting steps.
1 Turn off the printer and disconnect the power cable from the back of the unit.
2 Open the printer's front cover.
Pinch the top of the carrier belt and gently move the cartridge carrier to the center of the printer.
3 On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Gently push the encoder strip down and back up to get it into the slot. NOTE: If the strip is completely out of the slot, it may be necessary to move it first forward and then back.
4 Move the cartridge carrier back to the left-hand side of the printer with the carrier belt.
5 Reconnect the power supply and turn the printer back on
If the issue persists after you have attempted the steps with a new color cartridge, continue to Contacting Lexmark.
Jan 31, 2009 | Lexmark Z2300 InkJet Printer
We recently bought a LexMark printer, but we noticed the USB cable was missing, can can we do?
You should immediately take your receipt back to the store from which you bought the LexMark and tall them your box did not contain the USB cable that should have been there. If you have a reputable dealer, they will give you a new cable and then they can go back to LexMark and obtain a replacement for their store.
I suppose if that doesn't work, go to LexMark's website and post a request to them. They will, in all probability, provide a cable to you at no cost.
Sep 13, 2008 | Lexmark Office Equipment & Supplies
I have a Lexmark All-in-one X5490. Color Cartridge replacement request
Printable Version print_friendly.gif null.gif null.gif null.gif null.gif How to Clear the Memory on the Lexmark X4250 / X4270 ID:ENUS13874 null.gif null.gif null.gif
  1. Disconnect the power cable from the back of the printer.
  2. Hold down the Stop/Clear button.
  3. While keeping the button pressed down, reconnect the power cable. A message on the LCD will display MEMORY CLEARING.
    Note: The Fax, Copy and Scan buttons will remain ON until the message disappears. Only the Fax button should be ON when the function is complete.
  4. Select the personal settings you require as follows:
    LANGUAGE? Press the right arrow key to select the language you want to use, and then press Select.
    COUNTRY CODE: Press the right arrow key to select the country you will be using the printer in, and press Select.
    ENTER DATE: Using the date format dd/mm/yy (in the USA, mm/dd/yy), press Select.
    ENTER TIME: Using the format hh:mm, press Select.
    Select Format: Press the appropriate number to choose between 1=12hr, 2=24hr.
PERSONALIZE FAX: Press Select.
Enter Name: Type in the name and press Select.
Enter Fax Number: Type in the number of the phone line to which the printer will be connected, and then press Select.
Apr 18, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
57 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
