Just bought the kodak ESP 3, i put the software cd in and follow instructions everything seems to be going good until the end. A screen pops up sayin the instalation has been interrupted. Please try restarting the installer and trying again. but i already did that like 5 times and it's getting old. pease help..... thank you
  • Pavel Gutu Mar 12, 2011
    Could you please specify your operating system?
    Scholar:
  • 74 Answers
Go to Kodak's website and download the software. Here is the link: http://support.en.kodak.ca/app/answers/detail/a_id/32108/session/L3RpbWUvMTI5OTk2NzA1Ni9zaWQvT3ozbEpNb2s%3D%2Fselected%2Ftrue/selected/true
It looks like the software supports Windows 7, Windows XP, and Windows Vista but it does not support Windows XP 64-bit.
If you have Windows XP but don't know if it is 32- or 64-bit then do the following.
1) Right-click on My Computer
2) Left-click Properties
3) The top half of the resulting window will show Windows XP then 64-bit. If you do not see 64-bit anywhere then you are using the 32-bit version.
Posted on Mar 12, 2011
KODAK ESP 3200 SERIES WILL NOT SCAN
I had the same problems; missing Icon and 100-2105.
This solution on the Kodak web site solved my problem.
http://support.en.kodak.com/app/answers/detail/a_id/1276/kw/ERROR:%20100-2105/selected/true
From your computer desktop, select Start > Run.
Type %windir%, then click OK.
Double-click the twain_32 folder.
Right-click the kodak folder, then select Delete.
Insert the KODAK All-in-One Printer Software CD into the CD drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
Double-click aioscannr.msi, then follow the instructions to remove it.
Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
Start Home Center Software.
Select Scan Documents and Pictures.
Scan a document.
If the error continues using a Wi-Fi connection, make sure you select the correct printer in Home Center Software.
If the error continues using a USB connection, see the following section to reinstall the printer.
Jan 13, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
Keep getting error message 100-2105 when I try to scan
I had the same problem. The icon disappeared. Then the 100-2105 error message came up.
The solution on the kodak web site worked for me.
From
Scan a document.
Sep 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Can I install a Kodak ESP 3200 Series printer with Windows XP
yes, but you should look for the cd that came with your printer (if you have it) and install that first before you hook up the printer or turn it on. Also, if you already have this printer in your system, delete it and its software before you do a reinstall.
Mar 11, 2011 | Computers & Internet
I need to reinstall my printer, I don't have the disc.
You need to reinstall the drivers for the printer.
Go to: http://support.en.kodak.com/app/answers/detail/a_id/17438/session/L3RpbWUvMTI5NjE1MTc1Ny9zaWQvaUJtUVI3bGs%3D to download the drivers fro the Kodak ESP 3. Once downloaded, open and install. Follow the instructions on the screen for further setup.
Jan 27, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have bought a notebook computer and it does not have a cd rom so how do I install my kodac esp 3 printer into my new notebook have tried several times without any sucsess
Hi Thanks for your question
If you have an access to another PC and a memory stick, flash drive this shouldn't be a hard task.
Put your cd in PC and also put memory stick in USB port. Copy all of the content of CD on to the memory stick. Once copying is completed remove both CD and memory stick form pc.
Place memory stick in your netboot and go to it's content. Once your in main folder click setup and follow instructions.
I hope this helps. Please do not hesitate to ask more questions if still in doubt. Good Luck
May 14, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak 3250 printer (brand new) wont scan, issues an error 2005 warning??? Help. I've followed Kodaks troubleshooting instructions to no avail. I've also uninstalled and reloaded...nada, nothing...ziltch...
From Kodak's website:
Answer : To resolve error code 2005, 2006, 2007, 2008, 2009, 2036, 2105, or 2106:
1. Go to www.kodak.com/go/2005 to run SSEUtility.exe.
2. Do one of the following depending on your browser:
- WINDOWS Internet Explorer: Click Run, then click Fix.
- MOZILLA Firefox: Click Save, then double-click SSEUtility.exe.
3. Try to install the KODAK All-in-One Printer Software.
4. If the following message window appears, your processor supports SSE and the utility will not be able to help.
Click the X in the upper-right corner to close window.
5. If the problem continues or you were not able to use the utility, contact Kodak (1-800-421-6699)
Dec 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do i install a Kodak esp series 3 printer to a dell computer
Take the CD-ROM that came with the printer, and install the software.
When prompted, connect the printer to your computer.
If you have lost the CD-ROM disk, you can download the software from Kodak's web-site.
Oct 29, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I cannot install the ESP 5 printer I have tried everything, even tried to download direct for Kodak website and my lap top does'nt seem to have the correct driver, or I need a password it is a nightmare...
Kindly take the Software cd out of the c-d tray.Go to Conrol panel, and go to add or remove programs
1.remove bonjour
2.remove Kodak all in one printer software
3.remove microsoft.net framework2.0 if you have windows xp.
4.go to www.kodak.com/go/clear and download the clear utility for kodak printer software.
run it and then restart your computer.
5.go to start,click on run,type in services.msc in the run box and press OK.
In services local,start the following five services
print spooler,windows installer,background intelligent transfer service ,remote procedure call locator and cryptographic service.
Make sure that these services are automatic and not manual.if they are manual,right click on the service,choose properties and change start yp type to automatic.
go to www.kodak.com/go/downloads and download the latest version of Kodak software from there.Your issue will be fully resolved..
Oct 14, 2009 | Kodak ESP 5 Printer
Kodak esp 3 all in one
I Have one of these printers and it hasent been nothing but trouble
I wont buy another Kodak anything,
My solution, take it back and get a HP,
Sep 01, 2008 | Kodak ESP 3 Multifunction Printer/ Copier/...
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
