Question about Bushnell Cameras
Put batteries in trail camera wont power up viewer wont come on little red light on front blinks then goes away
SOURCE: DSC-S500 Zoom goes out wont' stay Red light comes on in front
I had the same problem with my Sony DSC-S500, I called Sony for a solution and they told me to take the batteries out and hold down the power button for 10 seconds, after trying that the camera would turn on the off again. I decided to hold down the power button and the button that takes the picture for 10 seconds and after putting the batteries back in the camera, it worked fine. I think that the picture button was stuck. Hope this works for you.
Posted on May 05, 2008
t00nz
  • 4738 Answers
SOURCE: Canon powershot A510 all of a sudden no power??
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try. Recommend trying first the one listed that describes removing the memory card before powering on the camera:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Posted on May 14, 2008
  • 1019 Answers
SOURCE: wont turn on
you have one of 3 things wrong here.
1:) the battery is dead, and needs to be replaced ( suggest e-bay china seller for cheapest )
2:) the AC adaptor or dc socket on the motherboard is Faulty.
3:) motherboard fault, regarding charging circuit board.
Go for the most cost effective option First. New Battery. Then AC Adaptor. Finally would be motherboard replacement.
Mike @ compurepair.
Posted on Dec 18, 2008
  • 2976 Answers
SOURCE: camera wont turn on batteries are new
If your batteries are new, they could also be dead or too low. If they are rechargeable, give them a full 12-16 hour charge before using the camera. Rechargeable batteries have a lower voltage than regular batteries.
Posted on Jan 02, 2009
SOURCE: Put new batteries in camera,
you must use the right batteries
Posted on Jan 10, 2009
Trail Sentry 11-9200 Digital Camera: I bought this camera from a store that used it as ...
Bushnell recommends to only remove or insert cards with power off, or it can damage the SD card.
Borrow an SD card that fits in your camera and test it. If this solves the issue, buy a new SD Card here.
May 16, 2010 | Bushnell Trail Sentry 11-9200 Digital...
When i turn on my camera the red light won't stop blinking
change or charge your battery. The red light will blink to indicate the flash circuitry is charging.
Jan 08, 2010 | Bushnell Trail Sentry 11-9200 Digital...
Wont turn on, new batteries, green light just blinks.
Make sure you are using the correct batteries, and that they are installed correctly. Some cameras require more powerful kinds of batteries and will not work with the cheaper kinds.
A blinking light can mean something is wrong with the power, not enough or something else.
If you have a power adapter or can get one, you may try that, to see if the camera will work without batteries. If it does, then some problem exists in the battery circuit.
Oct 20, 2009 | Samsung S860 Digital Camera
The red light on my ps3 is blinking and wont stay on
Turn off the ps3. Try reseating the hard drive. Take the cables off and then hook them back up. After this turn the ps3 back on and see if the blinking red light goes away. If it doesn't then try another hard drive in the system. If the blinking light goes away then you know you have a bad hard drive. If the blinking light does not go away then you know either the power supply or main board is bad.
Jun 29, 2009 | Sony Playstation 3 (PS3) Console
My flip video camera froze.it wont turn on....
Have you tried resetting the camera? Hold down the power button and the red button simultaneously until the camera shuts off (takes about 10 seconds). Then, just press the power button again and the camera should turn back on. I had the same problem; when I pressed the red button to stop recording, the camera froze, and the red light remained on. I tried resetting it like this, and it seemed to work.
Jan 19, 2009 | Pure Digital Flip Video Ultra Camcorder
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Camera wont turn on.
Main power led to on/off switch is crushed and not enough power gets through.
you have disassemble the camera.
I would think first before tring this.
Remove 3 screws on bottom, 1 in battery compartment, and 1 at very top of usb flap (look good).
Now slide the side piece starting at the usb flap then apply pressure to top and away from unit.
now look for 1 silver and three black screws (facing back and front, look good).
See the big red wire leading to main on off switch if it crushed thats the problem.
I replaced it with a longer piece of wire.
Remember to replace battery door first if it fell off during process.
*TEST NOTE: You can place batteries in and place a penny across the bottom to test before you put it back together.
Oct 31, 2007 | HP Photosmart M425 Digital Camera
Camera just wont turn on...help please
I opened up mine today and found out that all you needed to do was put the plastic gear back into place and it's A ok. Open up the camera and when you're facing the front, check the little plastic compartment on the top right to see if the gears are in place. I fixed it and everything is A ok now. :)
Nov 19, 2006 | Casio Exilim EX-S600 Digital Camera
Cameras Logo
16 people viewed this question
Top Bushnell Cameras Experts
Johnny Massengill
Johnny Massengill
Are you a Bushnell Camera Expert? Answer questions, earn points and help others
