Question about Brother HL 2140 Laser Printer
When I turn on my printer, it automatically starts printing - nothing. The paper comes out blank and I have absolutely no idea. I checked the printing queue but nothing was there. I uninstalled and reinstalled the driver and the same problem happened. However, when I checked the printing queue a document was there titled - "Local Downlevel Document." The status was blank, pages is N/A and size 79bytes.
    Problem Solver:
  • 17 Answers
Unplug the printer cable... then unplug the printer from power.
While the printer is off remove that job from the queue.
Posted on Mar 12, 2011
HP LaserJet 1020 Printer, automatically pick-up paper as soon as it turn-on.
Hi.
I guess there is to much paper in the input-tray. Try lowering the paper-level in the tray and if it will act better..
Feb 18, 2014 | Office Equipment & Supplies
I have an HP 4345 MFP that's printing nothing but blank pages when copying, sending a print job to the printer. Im not even able to print the config page. All comes out blank. Does anyone have any idea...
if you are tec guy?
do half test page test find any image created on catridge drum, if no image found then
Check laser scanner assembly shutter fully operating or not while catride access unit closed, if unable to check, remove the shutter from laser scanner assm
Increase toner density
set factory settings,
If image on drum no print on paper, check transfer roller, contacts, if dirty replace T.roller, no result replace Power supply board..
Sep 09, 2011 | HP LaserJet 4345mfp Printer
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Fulll ink cartridges but paper blank after printing
I've tried many kinds of cleaning and nothing helps save the old printhead. The only repair is to replace the printhead which costs around $100.00 for the part alone. It's not easy and should be done by a shop but a new machine would be less than the repair and you start again with a one year warranty.
Jan 29, 2010 | Brother DCP 130C All-In-One InkJet Printer
Printer prints nothing - it's speaking to the pc, it sounds like its printing, the paper goes through but comes out blank. Any ideas?
Check for the inks. If they are still full, try taking them out and clean the printhead as some ink got dried and blocked the passage where the ink goes out. Also, it would be wise to shake the ink cartridges to distribute the ink evenly.
Oct 25, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Samsung ML-1610 Does not print after a paper jam
after checking no paper left on rollers etc, turn printer of for a while and then turn back on and press the paper release button
Oct 17, 2008 | Samsung ML 1610 Laser Printer
Blank paper syndrom
Can you do a simple color or b/w copy job? If yes, the ph is OK and you might have to reinstall the drivers (delete before that the old ones).
If you cant see any copy job (blank paper) you should change to original carts and run the manual cleaning procedure twice. Wait a few hours an try to do the printing again. You might have to run the cleaning procedure twice again!
May 12, 2008 | Brother DCP 130C All-In-One InkJet Printer
Not printing (paper comes out blank)
it is possible that is has problem on your printer's memory... try printing below 30 pages see if problems still persist.
Mar 07, 2008 | Samsung CLP 300 Laser Printer
Empty ms word printout
Hi, You can try: 1. go to Start, Printer and Faxes, right click on your 3745, click on Properties, Printing Preference; 2. Check to see if you have any Advanced tab or button; 3. Check if you can set the printer to text only; 4. Check if you can set the printer to use black ink only. 5. In MS Word, verify through the use of Print Preview that your document is as you would want to be printed; 6. In some instances you may have to set manually text color in MS Word. While your document is open, click Ctrl + A to select all, then choose font color to "Black". Alternately, in your MS Word, you can click on "Format", "Font", "Font Color" set to "Black" rather than "Automatic" and set this as the "Default" setting. Hope this be of some help/idea. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 29, 2007 | HP DeskJet 3740 InkJet Printer
No ink coming from cartridges.
Sounds like maybe the nozzles are clogged up. Try using the printer maintenance utility to "Clean Nozzles". I think for most Lexmark printers it is call the "Lexmark Solution Center" in your Windows Start Menu. If that doesn't work, try maybe wiping the cartridge with a damp paper towel at the place where the ink comes out.
Apr 15, 2007 | Lexmark X2250 All-In-One InkJet Printer
Brother HL 2140 Laser Printer Logo
942 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
