Question about Whirlpool LER6636PW Electric Dryer
Dryer gets hot but clothes come out wet. I cleaned the vent tube and outside and they are clear(there was a lot of stuff in dryer hose), is the clog internal to dryer? How do I get it clear?
    President:
  • 3,074 Answers
I would disconnect the vent tube and run the dryer, if it dries then the vent tube is still restricted. To clean the inside out you will need to remove the door, here is a website that will assist you, Tim:
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
Posted on Mar 13, 2011
The dryer is hot but clothes isn't dry.
plugged vent to out doors, either the vent louver outside, the tube is clogged, or the dryer itself nreeds to be talken apart an vacuumed out.... main source of fatal dryer FIRES, and house fires is a clogged vent tube / exhaust.
Nov 19, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer Model LER3624JQ0 tumbles clothes, has heat, but clothes are hot and damp. Cleaned lint filter & took of vent in back (thought maybe clogged wall vent) but didn't help. Don't think much (if any)...
If your cloths are "hot and damp" you are not getting proper ventilation. Since you cleaned the vent trap let's try a few things to narrow down where this vent restriction is coming from.
  1. Let's pull that vent trap up and start the dryer. Place your hand a few inches in there. Can you feel a light suction of air? (flowing into the dryer)? We will get back to this shortly. Next -
  2. Take the vent hose off the back and turn the dryer on? At this time you should get lots of warm air blowing. If you do not have this and the vent trap did not have any noticeable air flow (into the dryer) then thus far you have a clog between the vent trap and the vent in the back of the dryer. Unplug the dryer and from the rear of the dryer remove the back panel. Should be just a few 5/16 nut with a possible flathead screwdriver indention on them. If you have to do this let's still check the pathway for ventilation to the outside and make sure one did not trigger the other. And if all ventilation to this point is good then -
  3. You have a clogged vent restriction between the duck and the path it takes to outside. For this a duct cleaning service will have to come out and take a high pressured air hose and blow that pathway clear. Now if you have a fairly high powered compressor and can locate the exit for the dryer vent then -
  4. Charge that compressor and put an air gun adapter on it and (wearing eye protection) blow the heck out of it. This will make a huge mess no matter who does it. Make sure it is a good size shop compressor and not one many people carry in their trunk for inflating flat tires (this one will not work) This is how the duct service will do it also.
Mar 20, 2011 | Dryers
Dryer takes too long to dry clothes. Heating element is working because clothes are hot but it takes almost 2 dry cycles to dry clothes.
It sounds like you're lacking air flow. I'm sure you're cleaning the lint trap / filter - but have you clean the VENT HOSE / PIPE?
The 4 in vent hose is supposed to be cleaned annually. If you have the flexible vinyl hose, replace it with either steel, aluminum or flexible aluminum tubing instead. Once you've removed the vinyl hose, it will collect a lot less dust and can be cleaned without worry of puncture.
A typical dryer vent brush.
Make sure there's no obstruction to the flap outside, too. Once cleaned the dryer operation should be restored to new again.
I hope this helps & good luck! Please rate my reply - thank you.
Mar 09, 2011 | Dryers
Dryer is running longer than usual, it's tumbling,
no make listed here...I would pull the hose off the back of dryer and see if a lot of air is blowing out of vent. if not, heres your answer a clogged filter area ..if air blowing out leave vent hose off and dry clothes with vent off for one cycle. if clothes dry with vent hose off..you have a venting issue and need your vent cleaned out...
May 15, 2010 | Dryers
Cloths take way too long to dry. Heat is working in dryer. Timer works, counts down from 60 min, buttheremo drying timer takes way too long.
You will need to check the dryer venting system for a restriction. If there is a restriciton in the venting system the dryer will get hot but the clothes will stay wet due to the moisture never leaves the dryer. First check the air flow at the vent exit located outside. Verify that there is plenty of airflow. Make sure the vent screen is not plugged. Then remove the screen and visually inspect for excessive lint. Then go inside and check the moisture vent hose behind the dryer. Verify that the vent hose is not kinked or restricted. Then remove the hose and clear out any excessive lint. Then check the vent opening at the back of the dryer for any excessive lint build-up. There is a vent cleaning kit that you can purchase from any home improvement store that you can use to clean out the venting system also. When you are done airflow should be good and clothes should properly dry.
Jan 22, 2010 | Maytag Dryers
DRYER TAKES LONGER TO DRY
you could have restricted airflow from the lint screen not being cleaned, a bad blower wheel, or a bad thermostat. take the vent hose off the back and check to see if the air flows out the dryer with good force, if so your vent is probably clogged or not open in the wall. the vent hose may also be picned off from puching the dryer back to far.
Sep 17, 2009 | Whirlpool LER4634J Electric Dryer
Dryer gets hot and drum is turning clothes are not drying. cleaned lint tray and removed tubing venting outside and the dryer is making a whining noise. the dryer is only 14 months old
If the drum is turning and the dryer is getting hot, then this is good news, as it means that the dryer is mechanically sound.
First check to see if the internal workings of the dryer are not blocked by running the dryer with the vent tube detached. If there is lots of warm moist air coming out the hole in the back of the dryer where the tube should be, then your dryer is fine.
Next, if you've checked the tube that connects the dryer to the wall or floor and it is clear, then on to step 3.
Probably you have a blocked or severely restricted vent tube from the wall or floor to the outside. Over time, these always become clogged with wet lint that builds up into a crust on the walls of the tubing.
Find the exhaust exit on the outside of the house and run a sewer snake up into it to see if you can open a hole in the blockage. If that works to help the air flow, then you need to replace the tubing from your laundry room to the outside, as it is probably a solid crust of lint that has built up over years.
Again, the good news here is that your expensive new dryer is probably fine.
Jun 10, 2009 | GE Dryers
A lot of moisture in the exhaust line of dryer...
thats easy the moisture from your clothes ,,and the outside air,,where ever you live its a lot of moisture in the air,,now the cold air from outside is coming back in dryer and the hot moist air is trying to get out,,bingo condensation,,in your dryer exhaust vent tube ,,hince all the water,,,,now to fix that ,,we need to dump all the water from vent exhaust tube ,,you may need a new one because it will mostly rot...and check the flap or put a window exhaust kit on the house or window,,to stop air flow from coming back in the dryer ,,and where done..onthejob
Jan 28, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Dryer turns, heats up but won't dry
check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Jan 25, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Cleaned vent hose, dryer still taking forever to dry clothes.
you have a family of squirrels living in the rest of the vent tube which is leading outside...check vent outside. I once had flying squirrels come into my house through the dryer vent! My dog had a kitten.
Jun 04, 2007 | Whirlpool GCEM2990LQ Electric Commercial...
Whirlpool LER6636PW Electric Dryer Logo
234 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
