Question about Campbell Hausfeld Air Comp Basic Spray Gun By Campbellhausfeld Co Dh3800
I'm trying to use my Campbell Hausfeld DH-4200 spray gun. When I pull the trigger, air comes out but no paint until I release the trigger. I don't use it very often so is there something I'm doing wrong?
buffalonyman
  • 1865 Answers
SOURCE: how do you diagnose a Campbell Hausfeld Airless.
Try to fill it with water and spray. YOu may have paint buildup in the system, and will have to disassemble it to clean it
Posted on Nov 08, 2009
  • 98 Answers
SOURCE: Bought anCampbell Hausfeld airless paint sprayer,
no fluid gets to nozzle or comes from nozzle.
sounds like your fluid line is pluged or the gun is pluged at or before the tip
Posted on Feb 21, 2010
digritz
  • 530 Answers
SOURCE: MY CAMPBELL HAUSFELD DH5300 PAINT SPRAYER WILL NOT SPRAY PAINT.
there are several issues that can cause this problem.
I will assume you have used the sprayer before so that will eliminate an incorrect air cap. The only other issues are paint viscosity, worn parts and the number one cause improper cleaning.
Be prepared for a complete disassemble of your gun. Depending on what you spray any residue can become hard as cement and it only takes a small amount to cause problems.
Below is a link to the manual that gives an exploded view of your gun.
Hope this helps but if not please let me know and I will trouble shoot further.
http://www.cpocampbellhausfeld.com/static/manual/www.cpocampbellhausfeld.com-dh5300.pdf
Posted on Jun 01, 2010
  • 15 Answers
SOURCE: my binks 18 spray gun squarts paint from the hole
spray gun is cloged (clean it!) also check gaskets in gun and vent hole in cup lid ( could be cloged)
Posted on Feb 28, 2011
krb55
  • 604 Answers
SOURCE: We are using an a Campbell Hausfeld Airless Spray
the nozzle should last as long as it is cleaned properly when the day is finished. Walmart sells Campbell equipment and/or many hardware stores do as well, the tip may not need to be specifc to your brand to fit, take the tip with you when go shopping. Also, check with your Cities maintenance department and find out where they buy there tools and parts, most likely you will find the parts you need there.
Posted on Mar 22, 2011
Brand new and leaks all of the air our the top, no power to shoot brad.
hi Philip, if pressing the gun down on timber and pulling the trigger doesn't release the switch to close the valve spray a little lubricant down the inlet connector with the trigger pressed then release. apply air and keep trying and if all else fails I think its time to return for a replacement or refund.
Apr 26, 2015 | Campbell Hausfeld 2-in 18 Gauge Brad...
Spray gun for cambell hausfeld model.#al2305-02..where can i get one
http://www.searspartsdirect.com/partsdirect/part-model/Campbell-hausfeld-Parts/Painting-equipment-Parts/Model-AL2305/0166/0733055
Dec 14, 2014 | Air Tools & Compressors
Looking for campbell hausfeld airless spray gun ps220a 2/3 hp operators manual Please!
Go to the Campbell-Hausfeld website at http://www.chpower.com/, under the 'Service & Support" tab select 'Manuals/Parts Lists. Do a search for your model number and you'll be presented with the manuals and parts lists for that line of paint sprayers.
Feb 28, 2013 | Campbell Hausfeld Airless Spray Guns &...
We are having trouble getting the spray gun to pull the paint through. It will spray air but does not spray paint.
when you pull the trigger can u see the needle moving backward? if so, then it's either the paint is too thick compare to the nozzle size or the passage for paint is blocked. try to take the nozzle, needle and the cup off and give it a good clean!
Sep 05, 2011 | Campbell Hausfeld Husky Gravity Feed HVLP...
Air bubbling up in cup when air trigger is pulled this is a gravity fed hvlp spray gun
it means the air holes in the nozzle are blocked the air couldn't get out in the front so instead it went back to the cup makes it bubble
Aug 20, 2011 | Campbell Hausfeld Husky Gravity Feed HVLP...
May 22, 2010 | Campbell Hausfeld Air Comp Basic Spray Gun...
Dec 28, 2009 | Air Tools & Compressors
How do you diagnose a Campbell Hausfeld Airless. It will not prime nor spray?
Oct 25, 2009 | Campbell Hausfeld Airless Spray Guns &...
Campbell hausfeld paint sprayer has no suction
The same thing happened to me before if the paint is too thick. Another reason was when the gun toppled over and paint went into the spring and needle in which case you will have to take it apart and clean it.
Oct 18, 2008 | Campbell Hausfeld Air Tools & Compressors
Campbell Hausfeld Air Comp Basic Spray Gun By Campbellhausfeld Co Dh3800 Logo
174 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
