Question about Panasonic Cell Phones
I replace and still not working - Panasonic Cell Phones
  • 643 Answers
Not enough information please re submit your query.
Posted on Mar 12, 2011
Fan will not work in 1998 cadillac deville so no heat
1- check your fuses 2- if your thermostat needs to be replaced it can cause the fan to stop working because engine never gets hot enough to allow fan to come on. 3- your fan blower motor could be defective and needs to be replaced 4- your fan blower resister may need to be replaced. The fan will still work on high in most cars, but not work at all in others 5- if you have automatic temp control, the control panel may need to be replaced. These are expensive, so get a replacement at junk yard.
Feb 28, 2015 | 1998 Cadillac DeVille
I have a Kenmore 790.96224 electric range and the burners and oven do not work, but the clock is working. how do i fix?
Try replacing ONE stovetop burner and see if the new one works. If it does, replace more stovetop burners. If the new ones all work, replace the oven burners.
If that first replacement stovetop burner STILL doesn't work, don't replace any more. Instead, check (or have checked) the circuit breaker for the range. It may get power from a second source to power the clock.
Jul 26, 2014 | Kenmore 96222 / 96224 / 96229 Electric...
My 2000 dodge dakota blower moter not working replaced blower motor
first when it comes on is it only in the hi position? if so the resistor needs to be replaced again (just because its new does not mean it works) and the blower speed switch in the control panel needs to be replaced
Dec 17, 2012 | Cars & Trucks
Lights will not turn on
HEADLIGHTS NOT WORKING
It can be faulty headlight switch or issue with its wiring. Or its faulty head light fuse.
To troubleshoot the issue i suggest you few help links with appropriate solution. So you can follow the test and confirm what exact problem is there in your case of headlights not working:-----
Click the link below: -----
All headlights not working?
http://repairhelpcenter.blogspot.com/2012/01/all-headlights-not-working.html
Working of Headlight switch?
Both headlight bulbs blow together?
Car headlight bulbs don't last long?
2007 Dodge Caliber: Low Beam Headlight Not working
http://technoanswers.blogspot.in/2012/06/2007-dodge-caliber-low-beam-headlight.html
2003 Toyota Camry: Headlights Work Intermittently?
http://technoanswers.blogspot.in/2012/04/2003-toyota-camry-headlights-work.html
Chevy Tahoe: Low Beam Lamps are not working?
http://technoanswers.blogspot.in/2012/04/chevy-tahoe-low-beam-lamps-are-not.html
2001 Chevrolet Tahoe: Headlights not coming ON?
http://technoanswers.blogspot.in/2012/04/2001-chevrolet-tahoe-headlights-not.html
2004 Dodge Ram: High Beam Light is DIM?
http://technoanswers.blogspot.in/2012/04/2004-dodge-ram-high-beam-light-is-dim.html
2001 Chevrolet Tahoe: Both Low Beam Lamps Not Working?
http://technoanswers.blogspot.in/2012/04/2001-chevrolet-tahoe-both-low-beam.html
Low beam headlights Modification?
http://schematicsdiagram.blogspot.in/2012/04/low-beam-headlights-modification.html
How to Replace a Headlight
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight.html
How to Replace a Headlight Bulb
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-bulb.html
How to Replace a Headlight Switch
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-switch.html
How to Replace a Headlight Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-assembly.html
How to Replace a Park Light Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-park-light-assembly.html
Headlight Assembly Removal On Honda Accord
http://technoanswers.blogspot.in/2012/06/headlight-assembly-removal-on-honda.html
Honda Headlight Assembly Removal
http://schematicsdiagram.blogspot.in/2012/06/honda-headlight-assembly-removal.html
How to Replace a Headlight Door
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-door.html
How to replace HID headlight bulbs for lexus 400h?
http://schematicsdiagram.blogspot.com/2012/01/how-to-replace-hid-headlight-bulbs-for.html
These will help.
Thanks.
Nov 28, 2012 | 1986 GMC K1500
Thank yo for the schematic Ernesto. It says Nissan 1996, so is the 2008 still using the same schematic?
It can be issue with motor itself.If its not going up,then how its working down.But still it feels like weak window motor or is issue with power window switch.Get the voltage tested at switch and motor.Also try another working window motor at not working window side.
==========For more troubleshooting i suggest go through the help links mentioned below:-----
Its complete details with troubleshooting steps:------
Car windows will go down but come right back up
http://schematicsdiagram.blogspot.com/2011/06/car-windows-will-go-down-but-come-right.html
Power windows will not go up and relay clicks when switch is pressed?
http://technoanswers.blogspot.com/2012/01/power-windows-will-not-go-up-and-relay.html
Electric Window Motor REMOVAL and INSTALLATION on ford vehicles?
http://schematicsdiagram.blogspot.com/2011/06/electric-window-motor-removal-and.html
Driver side power window wont go up on ford expedition?
http://howtobyme.blogspot.com/2011/10/driver-side-power-window-wont-go-up-on.html
How to replace window motor and regulator on jaguar S-Type?
http://howtobyme.blogspot.com/2011/09/how-to-replace-window-motor-and.html
How to remove window motor and regulator on Volkswagen Car?
http://howtobyme.blogspot.com/2011/09/how-to-remove-window-motor-and.html
power locks, power window and power mirror on the passenger side not working on Ford Windstar
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
All power windows not working on 2003 Cadillac CTS?
http://howtobyme.blogspot.com/2011/09/all-power-windows-not-working-on-2003.html
How to remove the door panel to install a new window regulator on Cadillac Deville?
http://howtobyme.blogspot.com/2011/08/how-to-remove-door-panel-to-install-new.html
--------------How to Remove Electric Window Motor on Acura Integra?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-electric-window-motor-on.html
How to replace power window motor in car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-power-window-motor-in.html
HOW TO REPLACE A POWER WINDOW SWITCH
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-power-window-switch.html
How to Replace a Window Motor
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-motor.html
HOW TO REPLACE A WINDOW REGULATOR WITH MOTOR
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-window-regulator-with.html
HOW TO REPLACE WINDOW RUN CHANNEL SEALS
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-run-channel-seals.html
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-regulator.html
How to replace power window regulator for 2006 Dodge Dakot
How to remove passenger side power window motor on Dodge Grand Caravan?
http://schematicsdiagram.blogspot.com/2011/09/how-to-remove-passenger-side-power.html
How to replace automatic window motor unit for the front passenger side on 2001 jeep grand cherokee
Laredo ?
http://schematicsdiagram.blogspot.com/2011/09/how-to-replace-automatic-window-motor.html
how to replace passenger side power window motor on 2001 Dodge van
All power windows not working on mercury sable?
http://technoanswers.blogspot.com/2011/09/all-power-windows-not-working-on.html
How to replace electric window regulator for mitsubishi 380 ?
http://technoanswers.blogspot.com/2011/09/how-to-replace-electric-window_05.html
how to remove window motor on driver side door panel on 1994 Oldsmobile Cutlass Ciera
http://technoanswers.blogspot.com/2011/08/how-to-remove-window-motor-on-driver.html
driver side window problem on Mercury Sable
http://technoanswers.blogspot.com/2011/06/driver-side-window-problem-on-mercury.html
How to remove door panel, door window motor and regulator on 1991 cavalier?
http://technoanswers.blogspot.com/2011/05/how-to-remove-door-panel-door-window.html
how to replace the power window switch on 2005 BMW 325i?
http://technoanswers.blogspot.com/2011/03/how-to-replace-power-window-switch-on.html
How to replace window switch on bmw?
http://technoanswers.blogspot.com/2011/03/how-to-replace-window-switch-on-bmw.html
ford explorer window motor, regulator and door panel removal?
http://technoanswers.blogspot.com/2011/02/ford-explorer-window-motor-regulator.html
How to Replace a Window Switch on a 2002 Ford Explorer ?
http://technoanswers.blogspot.com/2011/02/how-to-replace-window-switch-on-2002.html
Ford F-150 Power Windows Not Working?
http://schematicsdiagram.blogspot.com/2011/12/ford-f-150-power-windows-not-working.html
Power windows works intermittently?
http://schematicsdiagram.blogspot.com/2011/12/power-windows-works-intermittently.html
Pontiac grand am power window not working?
http://repairhelpcenter.blogspot.com/2012/01/pontiac-grand-am-power-window-not.html
Auto open close feature not working for Toyota Avalon?
http://technoanswers.blogspot.com/2012/01/auto-open-close-feature-not-working-for.html
Lexus ES300 Power window out of time?
http://repairhelpcenter.blogspot.com/2012/01/lexus-es300-power-window-out-of-time.html
Rear power windows not working on Ford Mustang?
http://technoanswers.blogspot.com/2012/01/rear-power-windows-not-working-on-ford.html
All power windows not working on Ford Explorer?
http://technoanswers.blogspot.com/2012/01/all-power-windows-not-working-on-ford.html
2003 Chevy impala power windows not working?
http://technoanswers.blogspot.in/2012/02/2003-chevy-impala-power-windows-not.html
Diagnosis & Testing Power Windows?
http://repairhelpcenter.blogspot.in/2012/02/diagnosis-testing-power-windows.html
All Power Windows Not Working
http://whatisbyme.blogspot.in/2012/07/all-power-windows-not-working.html
1977 Chevrolet Corvette Power Windows Not Working?
http://technoanswers.blogspot.in/2012/04/1977-chevrolet-corvette-power-windows.html
These details will help.Thanks.
Nov 27, 2012 | 2007 Nissan Frontier SE Crew Cab
2004 grand marquis fan quit working..replaced fan but still wont work
is this the blower motor fan for you heating and A/C or the cooling fan cooling fans have a relay blower fans are fused but controlled from switches inside as well as fuses
Aug 27, 2012 | 2004 Mercury Grand Marquis
2002 blinker light replaced works but sometimes
try replacing the tail lamp socket. it could be shorting out
Mar 15, 2010 | 2000 Chevrolet Cavalier
DS lite not working after replacing bottom screen
hi friend,i had the same problem....the small cable that you replaced is probably not placed in the connector properly .when you put it in you might have put it under the connector instead of upon it. retry it ,i'm sure it will work.. good luck
Jul 08, 2009 | Nintendo DS Console
IPhone touch screen not working
Have you tryed reseting and restoreing the iphone?
May 23, 2008 | Apple iPhone Smartphone
Cell Phones Logo
12 people viewed this question
Top Panasonic Cell Phones Experts
richie46
ray gallant
Are you a Panasonic Cell Phone Expert? Answer questions, earn points and help others
