When I push the s-on button for my lg x130 netbook, it gives me an error message and then fully boots the computer! Where can I download the software?
adib
  • 450 Answers
SOURCE: "Connection failed" -- USB connection
The "Connection failed" error message indicates a communications problem in the USB connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue. Fortunately, the most common causes of this error message are also the most easily identified: * Make sure that the computer's operating system is USB compatible. Microsoft Windows 95 and NT operating systems are not compatible with USB technology. (In addition, PhotoMAX and PhotoImpression software cannot be installed on Windows NT systems.) If you have an incompatible operating system, you must upgrade to Windows 98, Me or 2000 to use a USB connection. Your computer must also have the appropriate USB connectors. NOTE: This camera cannot make a USB connection with a computer running Windows XP. * Make sure that the camera power is on. Follow the camera instructions to turn the camera on. Some cameras conserve battery power by turning off automatically after a few minutes of inactivity. If necessary, install new batteries or connect the camera to AC power (if it has an AC power adapter). * Make sure that the camera is correctly set to access images. Make sure the camera is turned on and that its mode dial (if it has one) is correctly set for transferring pictures to the computer. Refer to the camera user guide for more information. * Make sure that the camera cable has not been damaged or become disconnected from the computer. Confirm that both of the connectors are firmly attached. Check the cable for breaks, kinks or other defects, and check the connectors for bent or broken pins. If the cable is broken or kinked, obtain a new cable.
Posted on Sep 21, 2005
falspet
  • 438 Answers
SOURCE: Lg x130 netbook wont open after updates
if you did a bios update, not a good idea unless you know absolutely what you are doing and why, but i suggest you disconnect the cmos battery for 15 or so minuets this will reset any bios changes to default and you should be good to go
Posted on Jan 27, 2010
bigjohn007
  • 425 Answers
SOURCE: Hi I have a Lg Netbook x130. I have removed the
hi,
I will show you a video below on how to disassemble a netbook. Although it is not the same model like your but the principles are just basically the same. You can get some clue here on how to do it.
Hope you can do it for your netbook as well.
Don't forget to rate me ok! Thanks.
Regards,
John
Posted on Jan 10, 2011
parinasragde
  • 526 Answers
SOURCE: acer aspire one netbook when i
make sure the bios update you are flashing is compatible to your motherboard specs...and you should use uninterruptable power supply to avoid crashing bios due to power failure.and make sure to make back up files of your older bios...
Posted on Feb 21, 2011
  • 25 Answers
SOURCE: How to open the netbook case
Hey There
Yip i managed. It is a mission but not to bad.there are a ton of hidden screws all over the place. I will post you something to help you. firstly go buy a small multi use screw driver set e.g. for watches!
Chat soon
Posted on Mar 25, 2011
How do i fix SmartOn Problem on LG x130 notebook,i am not even access the bios setting kindly help me out
Smarton is the recovery partition on the hdd. If it has been corrupted, that could be why you are getting this message.
Use your install disc to boot from and reinstall it.
Jan 16, 2016 | LG X130 Netbook
WHAT IS THE F KEY TO BE USED IN MAKING A FACTORY RESETTING FOR LG X130 NOTEBOOK
The F11 key after POST will activate the system restore function.
Jul 24, 2014 | LG X130 Netbook
Non boot
Did it have an OS previously, or is this a new netbook. Also, is their any crackling sound when booting? If there is a crackling, it's possible the hard drive crashed. Without a hard drive, it wouldn't be able to boot the OS.
Apr 01, 2014 | LG X130 Netbook
REFORMAT LG X130
F11 whilst booting should get you into the Factory Restore program.
Mar 25, 2014 | LG X130 Netbook
LG Netbook X130 stuck at Logo screen
remove your hdd and replug check data cable and power cable
Feb 27, 2014 | LG X130 Netbook
Forgot password
If you created a Windows password reset disk you can use that to reset the password.
yhe other option you have is to boot from a Hirens CD and use the utility on that to reset or remove the password. just do a search on the Internet to get a copy of the Hirens CD which you will then need to burn to a CD and then insert in your CDROM dribe and restatr your laptop, press F12 whilst booting and then se;lect CDROM as the boot drive.
Jan 31, 2014 | LG X130 Netbook
There's a sound during startup
There is no problem with your computer. It's just natural to have a beeping sound during start up. If there is, then it will show an error message in the screen.
If it's just a short beep, then it's normal.
Carlo
Jan 23, 2013 | LG X130 Netbook
Lg x130 no audio device found
Here are the drivers. Choose OS and look for Realtek. Best of luck installing.
http://www.lg.com/ae/support-product/lg-X130-L.A7W1E
Sep 27, 2012 | LG X130 Netbook
To download smart cam in Lg X130 notebook PC for Free
lg x130 notebook laptop camera 1.3 mega pixel setup need
please send to me setup.
Sep 04, 2012 | LG X130 Netbook
Computers & Internet Logo
350 people viewed this question
David Payne
David Payne
