Question about Dryers
Model #97581210 Drum does not rotate. Dryer was working properly until 1 hour ago.
    President:
  • 3,074 Answers
Belt is broken:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Posted on Mar 13, 2011
What do we do to address thumping noise in Kenmore Elite HE4 Dryer?
It is probably one of the idler wheels it rotates on. Look for a flat spot and if you didn't replace the drum your self ask for your money back.
Dec 11, 2014 | Kenmore Elite HE4 Electric Dryer
Amana electric dryer whining when started
Is ther anything caught between the drum and the back of the dryer. run you finger around the back edge of the drum inside do you feel anything caught
Feb 02, 2014 | Amana Dryers
Maytag ensignia
follow this steps and fix it. God bless you
Drive Motor
The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer stops the motor might be defective. If the dryer stops and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. Also try rotating the drum by hand with the belt off, it should rotate freely. If the drum doesn't turn freely, determine what is causing it to bind. The dryer motor can't be tested easily. If the drum turns freely and the blower wheel is clear, and yet the dryer still keeps stopping mid-cycle the motor may be defective. it will need to be replaced. It is not serviceable.
Enter your model number to see parts for your dryer.
Help me find my model number
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
Drum Roller
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If they are worn out or start binding the motor can get overloaded and the dryer stops. If the dryer stops mid-cycle, check to be sure the drum turns freely with the belt removed. If not, check the rollers. Do not lubricate the rollers or roller shaft, lubrication will attract lint and cause the roller bearings to wear out faster. If the rollers don't turn freely, replace them. The roller shaft can often be reused, unless it has worn down. Clean the shaft thoroughly before installing the new rollers.
Drum Support Roller & Axle
This dryer has drum support rollers.There will always be two supporting the rear of the drum and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely. If not, check the rollers and rollers shafts. If they are worn or do not turn freely they will need to be replaced.
Drum Slide, Glide, or Pad
The front of the dryer drum is supported by small pieces of plastic-like material. As the drum rotates, it slides on these plastic pieces. If the dryer stops mid-cycle, it may be that one or more of these plastic slides or glides has worn out. When they wear out the drum can start binding and put strain on the motor. The motor then shuts down and the dryer stops. Check the glides for wear and replace as needed.
Drum Bearing
The drum bearing supports the rear of the dryer drum. Over time this bearing will wear out and may cause several different problems. If the dryer stops during the cycle it may be that this drum bearing has worn out and is putting too much strain on the motor. If the belt is removed and the drum spins freely, the drum bearing is probably not worn out. If the drum bearing is worn out, there may be some grinding or squealing, and the drum will be hard to turn.
Drum Support Bearing
Dryness Control Board
The dryness control board shuts off the dryer when the clothes have reached the level of dryness selected by the user. If the dryer stops too early, the dryness control board might be defective. This is not very common and other possibilities should be checked first.
Jul 21, 2013 | Maytag Dryers
I changed the belt, it sounds like it works now but drum does not roll????
Hi and welcome to FixYa. I am Kelly.
Things to check..
1. Belt and ilder pulley properly positioned?
Use this link to make sure you have it correct:
http://www.repairclinic.com/Dryer-Belt-Diagrams
2. Make sure the drum felt seals are not rolled / folded over. If it is folded / rolled slide the shanke of a screwdriver under the felt and rotate the drum 360 deg until it straightens out. (Front and rear seals.)
3. Make sure the drum rollers are resting in the drum groove and not behind the drum
These manuals will be a big help: (page 25)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794
and
(Page 10 below link)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/3ffad75038c96fe4852571ca006cb80a/$FILE/L-58.pdf
Thanks for choosing FixYa,
Kelly
Apr 01, 2011 | Whirlpool Dryers
Humming Noise When Start Button Pressed
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 10, 2010 | Dryers
Dryer modle Tc7102w/t5c7102s was working ok but drum won't rotate
Theres two things to look at, the brushes on the motor, replaceable and cheap, if they are are healthy then there is one or sometimes two large capacitors, these give the motor the ooomf to get it rotating, these fail which is a common problem with washing machines and dryers, again about £5= on ebay.
Mar 25, 2010 | Zanussi TC7102W Electric Dryer
DRUM IS NOT ROTATING, BLOWER IS WORKING AND IS PRODUCING HEAT could i have blown a belt?
Try this first:
Unplug the dryer, reach inside and try to rotate the drum 1/4-1/2 turn, sometimes motors get dead zones in them and this will rotate it out of the zone if that is your problem.
If that did not work then chances are that you have a broken belt.
If you have a front loading machine:
If you remove the front of the dryer, it will expose the drum and the belt, if you remove the drum it will expose the drum rollers, motor, and idler pulley.
I hope this helps
Oct 04, 2009 | Whirlpool Dryers
Drum will not spin. The belt is not broken but is hanging lose
If the motor is working...Shut off the power to the dryer, reach inside the drum and try to rotate the drum 1/4-1/2 turn. Sometimes the motors get dead zones in them and this will help move it out of the dead zone
It could also be the drum rollers that need lubrication or replacement, if they are not rotating it would not allow the drum to spin.
I hope this helps
Oct 02, 2009 | Kenmore 73952 Gas Dryer
Money (change) caught inside interior drum plastic pieces.
Remove the top lid.
Rotate the drum until a vane is at the 12 o'clock position.
Remove the screws from the drum holding the vane in place.
May 10, 2009 | Kenmore 63942 Dryer
Dryer Drum not rotating
If warm air is still coming from the unit, but the drum is not rotating, it sounds like your drive motor is fine, but your drive belt is broken. Depending on you dryer model, these can be fairly easy to check, or may take a little creativity to get the dryer apart. Knowing your dryer model number would go a long way towards assisting further.
May 06, 2007 | Whirlpool LSW9750 Front Load Washer
Dryers Logo
20 people viewed this question
Top Dryers Experts
