Question about MRC Throttlepack Ac 80w Transformer Power 0001301 1301
Voltage will not drop down to 0 volts.It runs beteen 14 thru 24 volts,not 0 thru 24 volts.
  • craig remboldt Mar 13, 2011
    The train takes off,like a bat out of hell,while the throttle lever is on 0.You have to use the on/off switch,to stop the train.The miltimeter shows a steady flow of volts.On 0,it reads 14 volts,turn it up to the max,she reads 24 volts.Hit the boost botton,she reads 25.5 volts.The train,I`m using is a 1957 thru 1961 Lionel 246 Scout.This pack should run this train,according to MRC.
    President:
  • 1,050 Answers
It is not supposed to drop to 0 volts. It is a pulse width modulated supply designed to limit speed by decreasing the "on time" of the voltage, not the level of voltage.
Posted on Mar 13, 2011
  • 1 more comment
  • Dave  C
    Dave C Mar 14, 2011
    There may be something about the older motor that is not compatible with the PWM output, but I would have also thought it should be fine. Do you have the option of returning the supply or trying it on a newer layout?
  • Dave  C
    Dave C Mar 14, 2011
    A pwm controller will not appear to go to 0 volts on a meter. You'll need an oscilloscope to see the changing pulse width.
  • Joe Addeo Dec 27, 2011
    Dave - I just had the same thing happen to my Throttlepack. I'm using a very new MTH Subway model engine. It was working fine, and then all of a sudden I turned on the power switch and the train took off with the Throttle at zero. Have you been able to solve the problem? - Joe
2009 451 Passion. Why a frequent dead battery?
That is definitely wrong, not normal. Voltage should stay at 14 volts or near that until the battery is close to fully charged, then will slide down to about 13.5 volts, and stay there while engine is running. Also, a fully charged battery should show about 12.6 volts at a minimum, especially a new battery.
I don't know what is going on with your system. Take it back to Merc- were they aware of how it is acting, voltage-wise? Doesn't sound like it. One small possibility: is your alternator belt not tight enough?
Jul 01, 2015 | Smart Cars & Trucks
Dodge ram starter clicks
Your battery is dead and alternator may not be charging. Try a jump start. If it starts, check voltage with engine running. If voltage is less than 13, remove the alternator and have it tested.
May 22, 2017 | Cars & Trucks
I have a 2002 ford ranger that got a lot of water in the gas. I have drained the tank and added heat as well as replaced the filter. When I try to start it the battery gauge goes down to 0 and all I hear...
The alternator isn't charging , check B+ voltage hook-ups on the alternator . The heavy gage wire on the back of the alternator should have B+ voltage , vehicle not running . The fuel pump has nothing to do with it > terminal 3 at the connector should also have B+ voltage , So should terminal 1 . Charge the battery an get the vehicle running , put a volt meter on the battery post's , if there is about 13 to 14 volts running it is not charging !
How to Test an Alternator Diagnose Charging Issues
Apr 19, 2017 | 2002 Ford Ranger Regular Cab
Car will start when it is being charged, after charger is removed car still runs, when car is shut off it will not restart
could be battery or alternator. Check voltage at battery with engine running. Should be at least 14 volts. If yes, alternator is working.
After charging, battery voltage should be over 12 volts, with engine off. When starting, battery voltage should not drop a lot. If battery voltage does not drop while trying to start, you may have a bad connection--loose terminals.
Sep 23, 2010 | Chevrolet Lumina Cars & Trucks
MAY NEW ALTERNATOR PUTS OUT 14 VOLTS WHEN I START THE DIESEL 5.9
the voltage regulator is in the computer,check you battery with volt meter with engine off it should say 12volts then check it again with engine running and it should say 14-15 volts. if not the you will have to take it to a dealer to check the computer,hope this will help you!!!
Apr 19, 2010 | 2002 Dodge Ram 3500 Truck
Ive brought a new gaming rig, as follows CPU: Athlon II X2 240, 2.8Ghz MBD: Biostar TA770E AM3 / DDR2 / SATA RAM: 2GB DDR2 800MHz Case: CoolerMaster Elite 330 PSU: WinPower 450w One 300gb Sata drive One...
These new graphics cards pull a lot of power from the power supply. I know you didn't start off having this issue but given the symptoms you are experiencing I'd take a closer look at the power supply and perhaps replace it with a 650 watt or better.
Nov 16, 2009 | Acer Aspire™ T180 PC Desktop
Amp not getting sufficent voltage
Does the car start with the voltage dropping like that? Sounds like a bad battery. A battery can show 12.6 volts and as soon as you put a load to the battery the voltage will drop. I would change the battery and see if that helps. Also check your alternator. Get a DMM set to DC volts connect it to the battery and see how far the voltage drops when the cars running. You should see something like 14 volts or so. If it drops below 11 volts you may need to upgrade the "big 3" wires...hope this helps
Mar 18, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Dimming lights and voltage drop
Its not unusual to have a sudden drop of volts. especially if you have something running like your a/c or heater that requires a lot of power to run. it will also do it when your fan kicks in. anything that requires power is going to kick down your voltage. i would not worry about it unless the battery starts to die overnight.
Mar 13, 2009 | 2000 Pontiac Bonneville
MRC Throttlepack Ac 80w Transformer Power 0001301 1301 Logo
183 people viewed this question
Top MRC Toys Experts
ray gallant
Are you a MRC Toy Expert? Answer questions, earn points and help others
