Question about Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV
My leaf blower starts great but takes a while to warm up thats ok too. but when i run it full throttle after warm up its runs for a few seconds and bogs down and runs very slow then after about 5 min. of this it dies. starting it back up is easy and it does the same thing.
    Master:
  • 403 Answers
Sounds like a plug problem, pull the plug and check the quality of it, also check the gap. also are you useing the correct gas oil mixture , with fresh gas.
Posted on Mar 12, 2011
Hello, I have a Poulan Pro BVM200 VS leaf blower that starts great. New s plug. Warms up great. Find great at any throttle position UNTIL I pick it up to actually use it. It floods bad, drenching...
Look at thd fuel lines. They may have come undone which is why its flooding the air filter. Take the air filter off and look to see where the fule is coming from, that will give you a better idea of how to fix it.
May 25, 2014 | Garden
New poulan pro 25cc chokes out after if I give it full throttle. Runs ok except it wont stay running on full throtle.
I find with my Poulan Pro that you need to let it warm-up abit before applying full throttle, I live in Upstate NY where the weather has bee great lately,however, it stalls easy ..I mix 1-pint of 3 stroke oil to 1-gallon of gas for my weed eater and have no problem
Nov 05, 2011 | Poulan 25CC Gas BlowerVac
I have an echo pb-250 blower. This is the second blower ive had issues with. I have had it for maybe three months and this is the second time that ive experienced this problem. I can easily start it but...
what you need to do is remove the white plastic plug just above the diaphram gskt in the base of the carb use a pick or drill bit (but only turn it by hand) till you get it out then you will see a screw which will take a small flat blade screwdriver, start and warm up the blower then turn that screw counterclockwise till your Blower runs right on full throttle. the new equipment made now a days is set so lean for emissions that one change in the weather will affect how they run..... 2StrokeJim
Jun 08, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
I have a huskavarna leaf blower 140 back pac i run it for 5 min then it srarves for gas let off on the throtle for 10 seconds put on full it gos to full rpms the starves agian
Carburetor may need adjusting or rebuilding. I would try mixing up some fresh fuel mixture and try that first. Use gas from the station not from the can sitting in the garage.
Good Day.
Oct 28, 2009 | Husqvarna Backpack Blower, Model No. 356bt
Loss of power leaf blower - gas
Had the similar problem- start with removing the exhaust intake plate 1st--- clogs with super fine dust initially then larger particles... Mine was completely clogged- cleaned er' out now she blows like the wind!
Mar 30, 2009 | ECHO, Inc. PB-251C Handheld Blower
Homelite 26bp backpack won't run up to full throttle
I have let my leaf blower run and warm up before throttling up and still it bogs down and shuts down. There is no air cleaner to clean should I just blow out the carb. and fuel lines?
It runs and idles just no high speed to blow.
Nov 16, 2008 | Homelite Consumer Products Backpack...
Craftsman gas leafblower
Hey Karl,
To me this sounds like its getting too much fuel after it has been warmed up so either there is too much gas flow to the unit or there is not enough. check your primer bulb once this happens if there is a full bulb when it shuts down chances are its getting too much gas, if its empty then its not getting enough and your fuel filter could be starting to plug up or is not in the tank properly.
Nov 16, 2008 | Garden
All small engines take a few minutes to warm up...especially so as they age.
You have to learn to 'feather' the throttle to very, very slowly increase the gas.
After it is warmed up, you are much more likely able to rev it up...release, etc.
I've had many over the years, and this is a very common problem...that you learn how to handle.
Nov 06, 2008 | Garden
Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV Logo
787 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
