Question about Westinghouse Refrigerators
Manual and wiring diagram for Westinghouse fridge /freezer 640lites model RS652m about 15 years old
  • 178 Answers
SOURCE: Westinghouse Virtuoso Fridge - Circuit Diagram
If it is kicking the circuit breaker out in defrost mode, then the defrost timer is faulty. It would be best to just replace the timer instead of checking the wiring schematic. Look at www.partstoday.com for helpful illustrations on parts and identifying pictures.
Posted on Mar 30, 2008
Healeyman
  • 1198 Answers
SOURCE: Need a wiring diagram for a Hotpoint fridge freezer
Check Repairclinic.com, it's a good site.
Posted on Apr 27, 2009
  • 5 Answers
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Posted on Nov 15, 2009
SOURCE: fridge heller model fdh21has motor running but does not get cold
i have just purchased a float with a kitchen in it the fridge is a heller bar fridge not sure on model and for the 2nd use it is running but not getting cold or icing up the freezer what do i do to fix it it wouldnt be 10 weeks old
Posted on Dec 20, 2009
SOURCE: Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Posted on Feb 20, 2010
I am requesting a wiring diagram please
then perhaps request it from the manufacturer who by the way you forgot to mention in this question
Aug 24, 2015 | Refrigerators
Model # bx2255w Amana Refridgerator bottom freezer works but refridge isn't cooling any more. Is it time to retire our approx 15 year old fridge or is there an easy fix?
If you have high humidity or the door gets opened a lot, the evaporator coil may need a good defrosting. There are defrosting devices in the unit like the timer, heating coils, thermostats that could be bad. There should also be a small fan in the freezer that transfers the air to the refrigerator section. If that's not spinning only the freezer will work.
If you find the fan and it's working you can do a thorough manual defrost by removing the food, unplugging the unit and letting it set for a day with the doors wide open. Have some big towels handy :)
After a day, plug it in and see what it does (don't add food, yet). If it cools down then you will know that the compressor is still good and it's worthwhile to fix.
Easy fixes: Timer and fan.
Moderate fix (cheap part - more labor) - Defrost thermosat
Pain in the **** fix: Defrost heaters.
Ed
May 22, 2011 | Amana Refrigerators
The strip down the middle between the the fidge and freezer doors is getting hot. So hot that it burns when you touch it. The sides of the fridge are also getting pretty not. I have just bought the fridge...
I have exactly the same problem with my Westinghouse side by side! And it only happens when it's hot in the house. Would love to hear what's wrong. And the fridge is 5 years old. Bought new.
Jan 12, 2011 | Westinghouse Refrigerators
HI. I HAVE PURCHASED A SECOND HAND WESTINGHOUSE FRIDGE FREEZER. I WAS TOLD IT WAS MADE IN 1986. THE MODEL NO IS RS 615EA. CAN I FIND OR DOWNLOAD A MANUAL FOR THIS MODEL.
Hi, I can send you the service manual if you give me your email address. Unfortunately, I don't think you'll find the user manual for this model anywhere, unless someone has an old one lying around. The service manual has technical information and exploded views of fridge parts, wiring diagrams etc, and may be of some use. The service manual also includes other models, so you need to find your model in the service manual- it's about 57 pages long. Let me know if you want the service manual.
Mar 10, 2010 | Westinghouse Refrigerators
Water in the bottom of the fridge this unit is 15 years old
the seals or door gaskets leaking will cause fuzzy ice to grow in freezer and water to collect in frige and run alot
Dec 27, 2009 | Westinghouse WWS833ES Super Capacity Top...
Freezer not working
Your refrigerator has a Control-defrost,adaptive timer ,PC board part number 241508001
This is providing your model is the one listed above your post WRS3R3EW. The model you listed in post does not come up. Until we can determine that the freezer is not defrosting you need to unplug and remove the back panel of freezer compartment to see if the evaporator coils are frozen or clear. If frozen this alone will cause a chain reaction that keeps vents to fresh food compartment open and cause freezing in that area. Go to link below and enter model number WRS3R3EW0 Then you will see a list of diagrams on left side, chose #11 this will show the control parts. Click link below Thanks, Sea Breeze
We offer free help and assistance also.
http://servicepartstec.blogspot.com/
Apr 27, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Mar 30, 2008 | Refrigerators
Refrigerators Logo
255 people viewed this question
Top Westinghouse Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
