Question about Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
We have a 4d22 code showing on the screen and the bottom oven spontainously shuts off.
  • Jenn-Air Master
  • 3,053 Answers
Hello, thefish
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and fartherback, It appeared that no one answered some of them, So, I thought Iwould take some of my personal time to see if I can help. Even though this sitemay not have your exact model or brand, this link will help you tons. Here is alink to about everything you want to know about your oven, from
repairto trouble shooting it. Even pictures and video's. Just scroll around and youwill see tons of information to almost any question you might have on yourOven. If you go to this link and click around, I am sure you will find out somuch about your oven, you will know more than the company that made it. Thegood thing about this link is, then you can make the decision of DIY or hiringa pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help andsome kind words written would be appreciated for my free help , I wouldappreciate it. Here is also my direct link to my own pages of other areas of myexpertise for other problems you might have in Automotive,Appliance, andElectronics. Drop In anytime for my help. Thanks, Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
Jenn-air oven error code 4d22
Hi. Erorr 4d22 indicates that the control board isn't seeing the fan speed signal from the fan on that oven. It's the lower oven, right?
Check the connection to the Fan and Control board, and if that's not it replace the fan.
HTH.
Jul 25, 2011 | Jenn-Air Electric Double Oven
No flame
when this happens it is usually because of a faulty flame/gas safety valve.
Sep 08, 2008 | Amana AOGD2750 Gas Double Oven
Tip
Jenn-Air Oven 4D22 Fan Error
I was troubleshooting one of these error codes on a Jenn-Air oven and followed all the repair recommendations. Most service techs recommend replacing the fan, speed sensor and making sure everything is clean. I did all this and it made no difference. After a bit more troubleshooting I found the temperature sensor to be bad. I replaced the temperature sensor and the fan fault code disappeared and the oven worked normally.
on Dec 09, 2016 | Jenn-Air Ovens
I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
"This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
Mar 14, 2011 | Ovens
Bottom element is not heating to temp an shuts off during heat up - without error code showing in the display. IE. - Press Bake, 350 degrees defaults on screen; Press Start. YOu hear the Click as it...
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 05, 2011 | GE JTP15 Electric Single Oven
I have double oven my lower oven is not working appears a code in the screen that is not allowing to work the lower oven i restart unit in the code disappears but letter around cameback the code to the...
The exact same thing just happened with my lower oven and the code 4d22 appears in the upper right part of the display panel by the the timer. There is no explanation for the code in the instruction manual. Hope someone can help us with this. Upper oven works fine.
Dec 20, 2010 | Jenn-Air JJW8230D Electric Double Oven
Dual wall ovens shut off
Would need the codes to be sure,but sounds like the control is out the part will run you around $200.00 And don't wait till two weeks before Thanksgiving  cause you won't find one till after New Years by then.lol Hope this helped you ou.t
Aug 31, 2009 | Whirlpool RBS245PDS Electric Single Oven
The upper oven has faulty code 4d22 every time i try to clean
I just tried the suggestion to cut the power to the oven from the box for 1 minutes, and it worked! I feel like I just earned a day's pay!
Dec 29, 2008 | Jenn-Air JJW8230D Electric Double Oven
Lower oven
hi
shut off power to the unit, let it sit for a while then turn the power back on. test the oven again, if the code comes back call 1-800-Jenn-Air and ask them what the code means.
Apr 02, 2008 | Jenn-Air JJW8430D Electric Double Oven
JJW9830DDS
THE SOLUTION WAS TO CALL FOR SERVICE. IF YOU CONTINUE TO USE THE UPPER OVEN , THEN THERE IS A POSSIBILTY IT CAN CAUSE A FIRE IF THE BLOWER IS NOT WORKING. THE COST OF THE REPAIR FOR REPLACING THE BLOWER WAS ABOUT $390.00. THEY NEED TO REMOVE THE OVEN FROM THE WALL CAVITY TO PERFORM THE REPAIR.
Mar 21, 2008 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
113 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
