Question about Dreamcatcher Great War Nations The Spartans
I keep getting an error saying cant find game mod "IGAME_SPARTA" when i click ok it says press yes to lauch remote debug or no to ignore exception or cancel to terminate application no matter which one i choose it never works.
The error says "Application has generated an exception that could not be handled. Process id=0x (a series of numbers that change), Thread id=0x (numbers that change). Click OK to terminate the applica
did you add any new hardware or software just before this error started. If this is a Windows PC you can go into the safe mode and remove the bad software. You can also (if you can) remove or disable the hardware. Reboot into the PC as normal and see if you are still getting the error.
Jul 31, 2013 | Computers & Internet
When my laptop comes on i get an error message that says jitdebuggingis enabled what can i do to get rid of this error
To get rid of this error, open up "My Computer" and do the following.
    1. On the Tools menu, click Options.
    2. In the Options dialog box, select the Debugging folder.
    3. In the Debugging folder, select the Just-In-Time page.
    4. In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script.
      To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key.
    5. Click OK.
  • Oct 25, 2011 | Microsoft Windows XP Professional
    Trying to connect my WII council to the internet and it keeps coming up "Unable to connect to the internet Error code: 50230"
    Error code 50230 is thrown when the Wii's internet connection has not yet been configured. These instructions on configuring the connection settings come from Nintendo's website at:
    http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
    1. Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
    2. Now, select "Wii Settings" to access the "Wii System Settings" menu.
    3. Using the arrow on the right side of the screen, scroll to page two and select "Internet."
    4. Select "Connection 1: None"
        (Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
    5. Click on "Wireless Connection" and then "Search for an Access Point."
        (Are you using a wired Internet connection to your Wii console? If so, click here for specific help.)
    6. Select "OK" and the Wii will display all the wireless networks it finds.
    7. Select the wireless network that is yours.
        (If you're not sure which is yours, or you don't see any wireless networks, click here.)
    8. Asked to enter a security key? If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK." secureaccess.png Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands
    9. Select "OK," "Save Settings," and then "Yes."
      • The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:
          As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored
      • The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next!
      • The connection test was not successful - If the test was not successful, you will receive an error code.
        • Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information.
        • All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.)
    May 07, 2011 | Nintendo Wii Console
    Script problem in Explorer 8
    What should you do about Internet Explorer script errors?
    In most cases, you can ignore them. Script error messages are displayed by Internet Explorer when there is a problem with the JavaScript or VBScript code on the website you are viewing. Occasionally a script error can be caused by an error in downloading a webpage, but more often it is an error in the webpage itself.
    To be sure it isn't an error in downloading, click the Refresh button, or press F5.
    getcontent.aspx?assetid=6d65df30-1154-45a1-9855-1232c6b27475&documentset=en-us&prod=win700&market=usInternet Explorer refresh button
    If the error persists, and you are not a developer testing a website, you should click No to ignore the error.
    To avoid script errors in the future, you can turn off script debugging and notifications in Internet Explorer. Script error debugging and notifications are turned off by default. If they have been turned on, follow these steps to turn them off again.
    1. Click the Tools button, and then click Internet Options.
    2. Click the Advanced tab, select the Disable script debugging (Internet Explorer) and Disable script debugging (Other) check boxes.
    3. Clear the Display a notification about every script error check box, and then click OK.
    Apr 25, 2011 | Microsoft Internet Explorer 8
    Running script error
    Method 1: Disable script debugging loadTOCNode(3, 'whattotry'); If the only sign of a problem is the error message, and Web sites are working, you can probably ignore the error. Also, if the problem only happens on one or two Web pages, it might be a problem with those pages. If you decide to ignore the errors, you can disable script debugging.
    Note If this problem occurs on more than one or two sites, do not disable script debugging. Go to method 2 now.
    To turn off the Scripting Debugger in Internet Explorer 6, follow these steps:
    1. On the Tools menu, click Internet Options.
    2. On the Advanced tab, click to select the Disable script debugging check box. and then click OK .
    To turn off notification about every script error in Internet Explorer 7, follow these steps:
    2. On the Advanced tab, click to clear the Display a notification about every script error check box, and then click OK.
    Method 2: Test a Web page from another user account, another browser, and another computer loadTOCNode(3, 'whattotry'); Use another user account, another browser, or another computer to view the Web pages that triggered a script error to determine whether the problem persists. If the script error persists, there may be a problem with the way the Web page is written. You can probably ignore the error and disable script debugging as described in method 1.
    If the script error does not occur when you view the Web page from another user account, browser, or computer, the problem may be caused by files or by settings on your computer. Go to method 3 to continue to troubleshoot. Method 3: Verify that Active Scripting, ActiveX, and Java are not being blocked by Internet Explorer loadTOCNode(3, 'whattotry'); Active scripting, ActiveX, and Java are all involved in shaping the way information displays on a Web page. If these are blocked on your computer, it may disrupt the display of the Web page. Reset the Internet Explorer security settings to make sure these are not blocked. To do this, follow these steps:
    1. Start Internet Explorer.
    2. On the Tools menu, click Internet Options.
    3. In the Internet Options dialog box, click the Security tab.
    4. Click Default Level.
    5. Click OK.
    Note ActiveX controls and Java programs are turned off at the High security level in Internet Explorer.
    Try to open a Web page where you previously received a scripting error. If you do not receive the error, the issue is resolved. If the issue persists, go to Method 4. Method 4: Remove all the temporary Internet-related files loadTOCNode(3, 'whattotry'); Every time that you open a browser to view a Web page, your computer stores a local copy of that Web page in a temporary file. If the size of the temporary Internet files folder becomes too large, some display problems may occur when you open Web pages. Periodically clearing the folder might help resolve the issue.
    To remove all the temporary Internet-related files from your computer when you use Internet Explorer 6, follow these steps:
    3. Click the General tab.
    4. Under Temporary Internet files, click Settings.
    5. Click Delete Files, and then click OK.
    6. Click Delete Cookies, and then click OK.
    7. Under History, click Clear History, and then click Yes.
    8. Click OK.
    To remove all the temporary Internet-related files from your computer when you use Internet Explorer 7, follow these steps:
    4. Under Browsing History, click Delete, and when you are prompted, click Yes to confirm.
    5. In the Delete Browsing History dialog box, under Temporary Internet Files, click Delete Files, and when you are prompted, click Yes to confirm.
    6. Under Cookies, click Delete Cookies, and when you are prompted, click Yes to confirm.
    7. Under History, click Delete History, and when you are prompted, click Yes to confirm.
    8. Click Close, and then click OK to close the Internet Options dialog box.
    Try to open a Web page where you previously received a scripting error. If you do not receive the error, the issue is resolved. If the issue persists, go to method 5. Method 5: Install the latest service pack and software updates for Internet Explorer 6 or Internet Explorer 7 loadTOCNode(3, 'whattotry'); If you do not have the latest service pack or software upgrades for Internet Explorer 6 or 7, download and install them. They may contain updates that can help resolve the issue.
    Jul 06, 2010 | Computers & Internet
    Windows int. explorer keeps closing saying java script error
    This article offers five methods that you can try to resolve the issue, and also presents some advanced troubleshooting tips that you can try. Try each method in the order presented until you resolve the issue. If one method does not work, try the next.
    This article is intended for a beginning to intermediate computer user. You may find it easier to follow the steps if you print this article first.
    5. Click OK.
    8. Click OK.
    To install Internet Explorer 6 Service Pack 1, visit the following Microsoft Web site:
    http://www.microsoft.com/downloads/details.aspx?FamilyID=1e1550cb-5e5d-48f5-b02b-20b602228de6&displaylang=en (http://www.microsoft.com/downloads/details.aspx?FamilyID=1e1550cb-5e5d-48f5-b02b-20b602228de6&displaylang=en) Note Internet Explorer 6 Service Pack 1 is recommended for systems that are running versions of Windows earlier than Windows XP.
    To install the most current software updates for Internet Explorer 6 or for Internet Explorer 7, visit the following Microsoft Web site:
    http://windowsupdate.microsoft.com (http://windowsupdate.microsoft.com) Please leave me comment, if you need further assistance Thanks for using Fixya Please rate this solution Rnj VinodKumar
    Dec 15, 2009 | Sun Java Desktop System
    Http://db2.t.msn.com/en-gb/home.aspx?ver=8.5.1302&did=1
    First let me explain. Each browser handles scripts (the stuff that make up web pages and stuff) differently. You have Notify Me of Script Errors turned "ON" on your computer, so you will be notified of every error or warning - even if it works fine.
    FIX: To fix this, Go to your Control Panel (START > Control Panel) and, in Classic View (you can find that on the left panel), click Internet Options. In the tabs on the top, click "Advanced", and then find the category "Browsing". CHECK "Disable Script Debugging (Internet Explorer), and "Disable Script Debugging (Other)". UNCHECK "Display a notification about every script error".
    Click OK, and then messenger should work fine. If it does it again, restart your computer, then it will work fine.
    Nov 26, 2008 | Microsoft Windows Vista Home Premium with...
    Age of empires 3 wont download
    May be that particular file is corrupt and this happens rarely.You said you are being given a ignore option.So keep pressing ignore untill all the corrupted files are skipped.Indeed this may effect the game play in any of the levels but something is better than nothing. Or else, if yours is a legitimate copy,Then you will have the manufacturers warranty, so you can replace it. Also try if its having the same problem when installing on to a different computer.
    Nov 10, 2008 | Microsoft Age of Empires III: The Asian...
    Dreamcatcher Great War Nations The Spartans Logo
    209 people viewed this question
    Top Dreamcatcher Video Game Consoles & Games Experts
    James Wishart
    Are you a Dreamcatcher Video Game Console and Game Expert? Answer questions, earn points and help others
