Question about ASUS PG191 LCD Monitor
Monitor was working fine , now i suddenly get a white/blank screen
  • 2,229 Answers
Start the computer in safe mode if possible. If it works in safe mode, then you have a driver problem.
Also, if you can borrow another monitor I'd try that to see if your monitor is bad. If the second monitor works, you have a bad monitor.
If the second one doesn't work, your video card is bad.
Posted on Mar 12, 2011
Blank screen the screen has been working for over a year and all of a sudden went blank its not my pc as i plugged my pc into another screen and worked fine.... the standby flashing stops flashing when i...
Since you have tried another monitor with your computer, then we can only assume that your LCD monitor had gone bad.
If the light is green but you can't see anything on the screen, then most likely the backlight has gone bad. Unless you want to take the monitor apart, I would suggest buying a new monitor.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
Optiquest q9b-2 blank white screen (lights up when powered up) no video ??no problem with computer, video fine on another monitor, tried this monitor on several computers same problem, blank white...
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Feb 06, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
Hp vs17 has white screen at boot. I have eliminated the chord from the tower and the tower works fine. I have audio, no video. Only a white blank screen. It does not blink or flicker. It just stays white....
There are three choices here...bad screen, bad connection, or bad video card, if the card is integrated onto the motherboard, then that part of the motherboard could be bad. If you have access to another monitor or a TV with a vga input, try the computer with another monitor. If you get a signal on that other monitor then you know you either had a bad connection with the other monitor or you lost the screen on the old one. Go back and reseat your video connections with the computer off. Don't ever remove or move cables to the monitor and video with the computer running...the screen can suffer permanent damage. If there is no signal on any monitor, then either you have a bad vga cord or your video graphics card had died.
Nov 11, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Montor shows a blank white screen and is unresponsive
Please try to connect the monitor to another PC, if it continues to happen, then probably an internal electronic part/s of your monitor is cold soldered / defective which failed to send signal to other hardware parts of your monitor thus you only see white display. I suggest to bring the unit to an authorized service center fix / replace the cold soldered / defective part/s. regards
May 28, 2009 | Dell Computers & Internet
Display was working fine. Then the screen blanked
Used monitor controls to rotate through the connection options (e.g. VGA, DVI, etc). After second pass, the monitor cleared-up.
May 04, 2009 | Dell UltraSharp 2408WFP 24" LCD Monitor
Computer boots fine but the monitor is blank
if the monitor works fine on your laptop, the problem definitely is at the computer, possibly with the video card (if it is using one). it could have loose connection, or parts might have damages. it seems the problem is intermittent so electronic component of the video card could have parts partially damages or leaky components.
if your still using the motherboards built in video out put, try installing a new video card.
Oct 31, 2008 | Computers & Internet
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Suddenly blank
Did you know any subtle changes in monitor performance before you had this problem. Maybe a flicker or lines running down the screen?
Sep 18, 2007 | Fujitsu Siemens MCM 21P3 (White) 21" CRT...
Constant white screen
check the brightness and contrast from the menu on the monitor try increasing it ... the problem will get solved...
if same problem persists contact ur near by experrt technician he may tell that the tube is gone he must recharge it....
Sep 11, 2006 | Sony SDM-HS73P 17" LCD Monitor
ASUS PG191 LCD Monitor Logo
73 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
