Question about OfficeMax Office Equipment & Supplies
My office Max OM01287 Shredder will only run in reverse. There appeared to be a jam in the cutters and with tiny tools and very careful grabbing I seem to have cleared the jam from tiny pieces of paper. What else can I do to clear this. I have tried covering the window and it continues to read full. It is empty.
    Novelist:
  • 170 Answers
There is still a shred of paper jamming the microswitch that sets the shredder into reverse to avoid an even worse jam. Find that microswitch, usual;ly on the left or right side, activated by a plastic flap on the basket side of the shredder. Clear it. As you move the plastic flap up and down you should hear it click. No click, the switch is jammed.
Posted on Mar 12, 2011
Embassy shredder keeps running after it's done shredding. It won't stop running.
Hi Brenda:
My shredder, different make, occasionally has the same problem, especially when I try to put too many sheets of paper through at one time.
It happens because the paper jams in the cutter wheels and holds
a switch lever in the on position.
Step 1) Use the reverse switch (mine has one) to back the paper up a bit, then switch it to forward. Repeat this a few times and it might clear itself.
Step 2) If step 1 did not work, unplug the machine and use needle nose pliers, a small swrew driver, or any other handy tool, and remove all of the paper bits from the cutter assemble. Once this is done, it should work fine.
Jun 28, 2015 | Shredder Office Equipment & Supplies
Its not working and shredder wont turn on
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and place upside down. Use a small screwdriver and poke at any compressed paper wrapped around the blades - can take a while. Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
If all else fails, contact the maker
Feb 27, 2014 | Aurora Electronics AS1010TX Cross-cut...
My fellowes p 48c is jammed
Feb 26, 2014 | Fellowes P48C Cross Cut Shredder with...
Jammed paper shredder royal 80x
Feb 17, 2014 | Royal Office Equipment & Supplies
My office max OM01287 Shredder has no power to it is there a rest button it worked just fine the last time I used it and now there's no power?
Double check the safety that stops the shredder when it is full sometimes that switch gets jammed with cut paper. Also make sure the top of the shredder is level and properly seated back on the base unit. The shredder feed area may also need to be cleared there may be a staple or just paper jammed into this area as well, make sure the unit is unplugged before trying to inspect and clear and part of the shredder
Jan 16, 2013 | Office Equipment & Supplies
I need new cutters
Hi, Please tell me the details that you need. I can not get which cutter you need.
Aug 26, 2011 | Office Equipment & Supplies
My shredder stopped working in the middle of a shred. I have cleaned all shredding from it, but it still refuses to run. Is there a thermo cut off switch, and if so, where?
  • Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
  • 2
    Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
  • 3
    Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
  • 4
    Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
  • 5
    Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
  • Jan 02, 2011 | Office Equipment & Supplies
    My fellows jbo1 jamed and then stopped running is there a reset buton?
    Chances are it's over heated.
    Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
    From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
    Dec 15, 2010 | Fellowes Office Equipment & Supplies
    JAMMED SHREDDER
    if you have reverse, run reverse.
    if you don't have reverse, you will have to disassemble the drive shaft/cutters and clear manually
    Apr 05, 2010 | Aurora Electronics AS662C Shredder
    Aurora AS1010TX Will run forward for 1/3 of paper then into reverse.
    I'm going to say it needs oiling. Try oiling the gears and cutting blades. You can buy paper shredder oil at Office Depot or Office Max.
    Jul 10, 2007 | Aurora Electronics AS1010TX Cross-cut...
    681 people viewed this question
    Top OfficeMax Office Equipment & Supplies Experts
    Colin Stickland
    Colin Stickland
    Steve
    ka4iup
    ka4iup
    Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
