When I try to print something, there are lines in the color printing. I've changed all the color ink and have run the cleaning process. The pictures look very yellow, and there are stripes everywhere. Any suggestions?
    Novelist:
  • 170 Answers
If it is an HP printer, your inkjet nozzles may be failing. Replacement is the only answer. Look on-line for your make and model and buy generic substitutes for a better price. I would need to know the specific make and model # of the printer.
Posted on Mar 12, 2011
I have installed a new ink cartridge and gone through the cleaning process serval times but I can not get anything to print in black. If a document is in all black, all I get is a blank sheet. If I change...
The first thing to check would be your print utility. Make sure that it is aware that there is a black cartridge installed. If you've gone through the cleaning process, try printing a test page and see if that will print the black. If not, it is either a setting in your utility telling it not to print in black and white, or a hardware issue with your printer. I will look up some documentation for your make and model printer to see what else the problem might be. Please advise with any changes when you check the print utility.
Nov 05, 2011 | Brother MFC-5860CN InkJet Printer
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
Canon PIXMA MP510 : When I print something in colour, I get alternating dark and light 3mm lines printed horizontally down the page. I've tried cleaning, deep cleaning and realigning the print...
Hello
what you need is to clean, you need to clean the prnt head and ink cell, you open the top part let the ink carrier move to the center then UNPLUG the power cord ,now you can easily clean ink cell.
Jun 29, 2011 | Canon PIXMA MP510 All-In-One InkJet...
When you change the ink cartraige and clean printer and test the colours the quality of colour is not good on the test! what do you segested i try beacaue the machine has been on its 100th clean and...
    1. Print a Print Quality Check Sheet.
    2. Press the Ink or Ink Management key on the control panel.
    3. Press the up or down arrow key to choose Test Print and press OK.
    4. Press the up or down arrow key to choose Print Quality and press OK.
    5. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
      (A) One or more complete blocks of colors are missing:
      (B) Most of the short diagonal lines are missing from one or more color blocks:
      (C)Some parts of the short diagonal lines are missing from one or more color blocks:
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press the down arrow key or 2 or "-" to choose No for color with the problem.
    5. The display will then show Start Cleaning? Yes No.
      Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
    6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
    7. Repeat the cleaning and the quality check process following the Step 4-7.
    Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
    Canon MP980 prints horizontal pink lines across
    try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
    Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
    HP 7410 has lines through photo prints. How do we fix it?
    Two probable causes. If the lines are evenly spaced and show up just when printing photos you may just not have enough computer resources. Your computer may be low on ram or have a lot of processes running that load up the cpu. Trying printing at a lower quality and see if it goes away. Try turning off everything you are not using in the computer and then only do printing. For example doing email or or looking at web pages while printing is generally not a good idea. Some anitvirus programs will slow things enough to cause this but can be temporally turned off while printing.
    If this is a line that doesn't seem to change or goes away even a slight amount after printing a few pages then you probably need to replace the ink cartridge that is making the line color. It can also be a dirty print head so before you change cartridge run a bunch of cleaning routines. 5-10 before you try something else.
    Jul 09, 2009 | HP Office Equipment & Supplies
    Problems with color prining
    hi!!!!
    perform maintenance and
    try to clean up nozzles may be the ink
    clog
    or removed the cartriged and clean with alcohol
    use cotton buds then placed it back properly
    Oct 31, 2008 | Canon BJC 2100 InkJet Printer
    My copy prints come out blurry after changing ink cartiges
    Try this:
    Checking the print quality:
    1. Press the Ink or Ink Management key on the control panel.
    2. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set.
    3. Press the up or down navigation key to select PRINT QUALITY and press Menu/Set or Set.
    4. Press Color (Colour) Start. The MFC/DCP begins printing the Print Quality Test Sheet.
    5. By reviewing this Test Sheet, you can determine if the print quality needs improvement.
    6. Closely examine the print quality of the four color blocks that are formed by short diagonal lines on the Test Sheet.
      If all lines are clear and visible, press 1 (YES) and press Stop/Exit.
      If you can see missing short lines, press 2 (NO) and go to Step 7.
    7. The display will then ask you if the print quality is OK for black and three colors. Press 2 (NO) for black or three colors with the problem.
    8. The display will then show START CLEANING? 1.YES 2. NO.
      Press 1 (YES) and the MFC will start cleaning the color ink cartridges.
    9. After the cleaning is finished, press Color (Colour) Start. The MFC/DCP will print another Print Quality Test Sheet.
    10. If you can see missing short lines in any of the four color blocks press 2 (NO) and repeat the quality check and cleaning process. Repeat this procedure at least 5 times if print quality remains a problem. If short lines are still missing after the fifth cleaning and test print, replace the necessary ink cartridges. If the print quality of the 4 color blocks is OK, press 1 (YES).
    Setting the Alignment:
    3. Press the up or down navigation key to select ALIGNMENT and press Menu/Set or Set.
    4. Press Black (Mono) Start or Color (Colour) Start. The MFC/DCP begins printing the Alignment Check Sheet.
    5. By reviewing this Test Sheet, you can determine if the alignment needs adjustment.
    6. Examine the 600 DPI and 1200 DPI test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1 (YES).
      If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
    7. Press Stop/Exit.
      If I could be of further assistance, let me know. If this helps or solves the issue, please RATE it.
      Thanks, Joe
    Oct 11, 2008 | Brother MFC 420CN All-In-One InkJet...
    Print quality is poor
    if you replace the black ink cart with an original one then it's the print head
    Solution: Cleaning the Print Head - C555 / C560 / C635 / C530 / C545
    Untitled Document Follow this procedure to clean the BJ cartridge print head:
    1. Press c755funckey.gif 2. Press c755cleankey.gif 3. Use c755down.gif or c755up.gif to select the [HEAD CLEANING]..
    4. Press c755set.gif.
    The MultiPASS cleans the print head.
    Feb 12, 2008 | Cannon MULTIPASS C530 Printer
    jasbo
    jasbo
