Question about Brother MFC-290C Printer
My brothermfc-290c printer is not printing the black ink. i put new black in put still is not working. we have went through many cleanings. what eles can we try.
  • 1,218 Answers
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Thanks
Michel
Printer Repair
Posted on Mar 15, 2011
  • 310 Answers
99 % you need to replace the prin head,if you try to clean...obviously have to replace the prin head.If i have been useful pls give me a vote :)
Posted on Mar 12, 2011
I ran out of the other color cartridges, and just bought a new black ink cartridge only. So can it work without the other color cartridges, and only on the black ink cartridge, because every time I try to...
No many of the printers will need to have both the color and the black cartridges to work...
You will have to purchase and install a new cartridge to get it working correctly.
heatman101
May 17, 2011 | Brother MFC-290C Printer
Brother MFC-290c printer does not print black anymore. Test print page color ok but not black printing. What is the problem?
The problem is either:
* out of BLACK ink -- replace the ink-cartridge
* clogged ink-jets -- the ink is not spraying onto the paper, so run a few print-head-cleaning cycles
* dead electronics -- not triggering the jets to spray ink, so replace the printer
Feb 20, 2011 | Brother MFC-290C Multifunction Color...
Brother MFC-290C not printing black
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results.
Thank you!!
Jun 25, 2010 | Brother MFC 420CN All-In-One InkJet...
BLACK INK NOT WORKING
You don't say what kind of printer you have. If the cartridge is put into a print head, the print head may be plugged, and the ink that would otherwise flow is blocked (I had that happen with an older canon S450 printer). If the mfgr sells replacement print heads, as well as cartridges, I would suspect that. The replacement printhead can be quite expensive!!!
There should be a print head cleaning routine. Figure out how to run it, and try that.
Jun 18, 2010 | Brother MFC-290C Printer
The printer
You may need to clean the printhead: (make sure you have paper in the tray)
1) Press <Menu>
2) Press <Up> or <Down> arrow to select "Ink" then press <OK>
3) Press <Up> or <Down> arrow to select "Test print" then press <OK>
4) Press <Up> or <Down> arrow to select "Print quality" then press <OK>
5) Press the <Color Start> button. The quality test sheet will be printed. Check this printout for gaps in any of the colors or black in the pattern across the page.
6) The display on the printer will ask if the print quality is OK:
- If all lines are clear and visible, select "Yes"
- If gaps appear in the pattern, select "No"
7) If you select "No" the display asks (in turn) if the print quality is OK for black, and the three colors.
Respond "Yes" or "No" accordingly. (In this manner you may clean just the black or color nozzle that is giving you the problem)
8) The display asks if you want to start cleaning - choose "Yes"
9) After cleaning is finished press the <Color Start> button - the print quality sheet will print again.
At this point you may determine that another cleaning cycle is necessary. You may need to repeat cleanings (up to five times) to resolve the problem. Any more than that indicates a problem that may need brother customer support.
10) When the print quality test sheet meets with your approval, you may exit by pressing <Stop/Exit>
Jan 21, 2010 | Brother MFC-290C Printer
New black ink cartridge won't print for Brother MFC-290C
run software cleaning function for the heads and run the alignment, make sure that you move all the stickers from the cartridges and the vent hole is clear, clean the inside housing from any dry ink...let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Sep 20, 2009 | Brother MFC-290C Printer
My Brother Printer (model MFC-290c) and ink
On your printer take a look on the "ink management button"press it then look for cleaning using the arrows up and down then press ok or set or what ever the command the printer will display just try to perform head cleaning.try for several times lets say 4x don't clean too much it might ruin all other color if it has no changes try to bring it to a service center,they can soak it to a chemical solution,the head is clog.
Sep 10, 2009 | Brother MFC-290C Printer
Black not printing on a Brother MFC-290C
in the printer display try head cleaning option, there must be something blocking the cartridge. hope this helps
Jul 17, 2009 | Brother Multi-Function Center MFC-240C...
Printer won't print in black
This could be to several reasons:
1#  The black cart contains blue ink-> Change to a brand new cart.
2# The cart assy has a bottom that is a foil. Sometimes this foil leaks.
Ink will mingle: You need a new cart assy.
Run the cleaning cycle twice after inserting a brand new bk ink cart and print out a test print. If you still see blue instead of bk the assy is leaking.
BTW the bk is darker than blue (or better cyan). You must see bk! So it seems to be the prob with the right ink....
Nov 11, 2007 | Brother Multi-Function Center® MFC-215C...
Brother MFC-290C Printer Logo
372 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
