I understand that is there is a protective shut off. There is a patter of 4 blinks. Can this be fixed at minimal expense and where can I order a remote specifically for this TV should I be able to repair it?
  • 2 more comments
  • DeDe Mitchell Mar 12, 2011
    This is not a flat panel TV . It is a 32 inch Sony trinitron wega vision. The model # is KY32FS16
    Thanks,
    Danetta
    Ok kewl ! I'm not real handy, but a friend is. Where might I purchase this chip and what would it cost. I called a couple of TV guys and they told me to just throw it out, but money is tight. Thanks for all your help.
    Yes. My tech was very helpful and prompt with his responses. Thanks so much!!
    Thanks so much!!!
  • 10,594 Answers
Let me know model number and brand of tv to understand possible cause of problem, these info will help me to provide a solution.
Thanks.
Posted on Mar 12, 2011
  • Shahid Electronics
    Shahid Electronics Mar 12, 2011
    KV-32FS16 is tv model number and 4 times blinking red light shows problem with vertical deflection section and most probably vertical output chip got bad and causing this problem.
    If you are handy with electronics stuff repair and can replace parts in circuit board as it requires soldering work then can attempt to repair it OR local tv repairman will do this job for you.
    Substitute remote control for this tv is available in Remotes.com
    Please click on above link to view remote price.
    Thanks.
    OK, there is IC502 located on A Board of tv and IC number is TDA8172
    Available in PartStore.com for $14
    Please click above link to view IC image and price info.
    Thank you.
Why won't it power on .it just stays in standby mode .
Top 10 Mistakes When Hooking Up a Home Theater System
www.audiogurus.com > Learn: Home > Cables
You don't have to buy expensive cables to run wire for those surround sound ...Interconnect cables are important-in that your system won't work without them. .... If you use a rack or shelves for your AV gear, remember to put the amplifier or ... the projector remote; Power up the home theater system with the receiver remote ...
How to fix sony stereo protection - YouTube
? 1:31
https://www.youtube.com/watch?v=oG17QKiI_E8
Feb 28, 2014 - Uploaded by dallas1999fan
Step 1 take apart Step 2 spin the fan Step 3 unplug the powercable Step ... his fault that your system is not fixed. i have the same stereo system and it .... Sony MHC-EC909iP Shelf SystemFeatures & Review - Duration: ... Red Blinking Power Indicator Denon Receiver AVR-488 - shuts off - won't stay on etc.
Understanding Home Stereos, Amplifiers, Speakers, and ...
Dec 25, 2015 | Audio Players & Recorders
My Mitsubishi WS-65809 turns on and then off after 4 seconds. I have pressed the input/enter together and got 2 and then 4 blinks. What do I need to do to fix it?
First to be sure, unplug the set from power and then plug back--this clears the error buffer. Repeat the self check:
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
As you can see 2,4 is vertical problem----might want to remove speaker grill, inspection plate behind it and look up front--vertical is on middle board at right front as seen from front of set.
Look for ANY tiny drops of clear liquid which damages parts and is toxic-----glycol is what I would look for first.
Nov 04, 2012 | Mitsubishi WS-65809 65" Rear Projection...
How to set a Timex 1440 ports watch WR50M
Buttons are numbered as followed:
Start/Stop is button 1
Lap/Rst is button 2
Indiglo is button 3
Mode is button 4
a) Press 4 to select "TIME" mode
b) Press 2 and hold for 2 sec to select "SET" mode, second digits blink.
c) Press 1 to reset digits to 00.
d) Press 4. Minute digits blink
e) Press 1 to set minutes.
f) Press 4. Hour digits blink.
g) Press 1 to set hours.
h) Follow same patter to set day of month, month, etc...
i) Press 2 at any time to retain set values and exit procedureSource(s):Timex instruction manual
Oct 08, 2012 | Timex 1440 Digital Sports Watch - Green
Set time1440sports
Lap/Rst is button 2
Indiglo is button 3
Mode is button 4
Nov 16, 2011 | Watches
Our Mitsubishi projection tv went out one day. When we went to turn it back on all it does is blink the green light for a few seconds and then shuts off. What could it be? Where can we look to see where...
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu"buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
Aug 09, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Screen went black. Shut t.v. off and tried to turn it back on. Power comes on, front light is green, and in about 3 seconds the t.v. shuts off, green light goes off. Was playing dvd at the time. Shut off...
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix. SD TECH
Jul 15, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Tv will not turn on, green light comes on and then shut of
MOSTOF THESE SETS HAVE A SELF DIAGNOSTIC:
Jun 09, 2011 | Mitsubishi WS-65315 65" Rear Projection...
My split type 2.5hp carrier express ion shuts off (including the condenser) after five minutes of running, the indicator light blinks during this time...it restarts again after awhile, then shuts off again...
How many times is the light blinking? Also is the light red, yellow or green? The light blinking is telling you exactly what has failed.
(# of RED blinks first)
1 High Pressure Protect
2 Indoor coil freeze protect
3 Low pressure protect
4 Compressor discharge protect
5 Low pressure/Overcurrent protect
6 Indoor-outdoor communication error
8 Hi-Temp protect
10 AC Voltage Low
Each of these has maintenance required steps to resolve the errror. Let me know how many blinks your getting...
Kelly
Apr 25, 2011 | LG Heating & Cooling
How do i set up my watch correctly to the right time
Lap/Rst is button 2
Indiglo is button 3
Mode is button 4
Mar 09, 2011 | Timex 1440 Prizefighter 53032 Sports...
Tv turns on then off after a few seconds. No picture or sound in these few seconds.
Try this and let me know what you find:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
if this has helped you rate this solution as I do this here for free.
SD TECH
Dec 10, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
