Question about Kodak Easyshare M753 Digital Camera
What happen when it says lens error - Kodak Easyshare M753 Digital Camera
    President:
  • 287 Answers
Hello and welcome
The most common cause for a Lens error:
Misaligned Lens rings
Sand and grid wedged in between the lens and the barrel.
Dropping the camera
Ran down battery
The following solutions are there by which you may Fix the lens error
  • Firstly you can try removing the batteries and replacing it with a new set of fully charge ones
  • If the batteries ran down while you were taking photos with the lens extended, you might also get this error. Remove the the memory card and replace the batteries with a fresh recharged set. Try to power on the unit with the fresh set of batteries while the memory card is removed
  • Connect your camera to your computer using your USB DATA cable which came with the camera. Once the camera gets power in this mode, the screen should stay off, hence, supplying the lens with more power to push or pull out/in
  • Place the camera on a sturdy table with the lens pointing to the ceiling. With a fresh set of batteries installed(Do this without a memory card) hold down the shutter button while you power on the unit
  • Now, you can either use a compressed air canister to blow around the lens area. This will result in the sand or dust particles to be blown out of the area between the lens and the barrel. Or, you can use a vacuum and and carefully place the nozzle around the lens to out the particles
For more solution by which Lens error can Recover Here you Go. It will help you out more briefly
I hope this solution will helpful for u Your Rating as Four Thumbs which are given below to this solution will appreciate me
Thanks
Posted on Mar 12, 2011
Lens error
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its happens. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there is a system error. So please visit the service center for repair that. Its a very common & repairable problem. Thanks
Dec 19, 2010 | GE Cameras
My fujifilm s1000 keeps showing "zoom error." I don't know what happend. It's like one day it's working, the next not. I have a family member graduating Friday and can't afford a new camera. I've taken out...
Hi.
If you try turning on the camera with the lens cap on, you may get zoom error. Ensure that you are removing the lens cap before turning on the camera.
If the autofocus ring is held while taking the picture, or operating the lens this will also cause the Zoom error message coming up.
If that is not the problem, then the lens has troubles extending. This may happen because of dust stuck in lens mechanism, or because of a mechanical fault concerning the lens.
Any cause preventing lens from full extention or retraction will trigger zoom error.
Here a basic manual in PDF format.
Here Owners manual.
May 20, 2010 | Fuji FinePix S1000FD Digital Camera
After turning it on, it says lens error and shuts
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its happens. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there is a system error. So please visit the service center for repair that. Its a very common & repairable problem. Thanks.
Apr 11, 2010 | Vivitar ViviCam X327 Digital Camera
ERROR 99....WHAT THE MEANING....HELP ME/ model canon 1000 D
Error 99 means "other error", so there are may possible causes. However, in most cases it refers to a communication problem between camera body and lens.
Try the following:
  • Remove the lens.
  • Check the contacts at the lens mount and contact pads at the lens for damage and dirt. If necessary, carefully clean them.
  • Power on the camera, without a lens attached. Does the error recur?
  • If the error did not occur without a lens, re-attach the lens and try again.
  • If this did not solve the problem, try a different lens
If this didn't solve your problem, please report what happened when you performed these steps.
Mar 10, 2010 | Canon Cameras
Canon power shot sx100is LENS ERROR
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Don't want to get your hopes up too high, but here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 15, 2009 | Canon PowerShot SX100 IS Digital Camera
Hi-- my canon SX110 won't switch on properly. it keeps telling me there's a lens error and to restart. when this has happened in the past, i've just switched it off and then on again and it's worked. not...
Try removing and replacing batteries to reset the camera. Ensure that batteries are fully charged.
If that does not clear the problem, then the lens error is usually caused by mechanical faults concerning lens assembly. This happens because there is dirt inside the lens (sand dust), or one part in the lens assembly is bad or went out of place.
Because of this he lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
If if does not extend tapping gently the back of the camera, and if it does not retract helping lens back in while turning camera respectively on and off.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Jul 16, 2009 | Canon PowerShot SX110 IS Digital Camera
Lens error, restart camera
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 14, 2009 | Canon Cameras
Lens won't come out,lens error 14,kodak c330
same thing happened on my camera. think it got dropped. lens only comes out part way. pull out with fingers and then lens works fine.
Nov 27, 2007 | Kodak EasyShare C330 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
59 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
