Can't initialize sound engine error code 23 I already have so, it was two years ago, reinstalled windows, now began again ((( please help
  • David Petry Mar 12, 2011
    What sound cards do you have?
  • Tony Mar 12, 2011
    what kind of sound card do you have?
    if its built it what is the motherboard/model #
    what OS are u using?
  • 27,725 Answers
The loaders for this device cannot load the required drivers. (Code 23
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps don
Posted on Mar 12, 2011
Code error 00-00-00 30-00-28
If the lens got stuck, you have a problem. It can be caused by many things. A broken sprocket, a broken gear, just a little dent in the lens barrel, dried out grease and many other things. Even a defective motor or just a bad contact or a broken connection can be the cause. Non of them can be repaired by yourself. Sometimes, tapping the camera on the palm of your hand, could solve the problem (temporarily), but don't bump it to hard, or you could damage it beyond repair. Tap it with the lens barrel down ward, asif you want to tap it out. But only in a few occasions it really would work. If the battery has enough power, to switch the camera on, pulling it through a setup and displaying the error message, the battery should not be the cause. Getting out the battery and replacing it after a few moments, could reset the error, so i tries again to switch on normal. But if the error keeps coming back, I think it is wise to start saving for a new camera. Most camera's on the market now, perform better and will cost a fraction of what you paid a couple of years ago.
Oct 28, 2014 | Cameras
Its D51s. it gives one long beep and two short ones with no display. Initially it was working but when i removed RAM and on reinstalling it, it started giving me this beeps
Beep codes vary but 1 long and 2 short usually indicate a video problem. Since your problem began with removing the ram try this. Remove the memory modules again and re-seat firmly. If you notice the memory channels are dusty blow them out before re-seating. Hope this solves your problem.
Apr 12, 2011 | HP Compaq d530c PC Desktop
When I plug in seagate free agent I get error code 23 what does this mean?
Code 23 is a Windows code for corrupt file. Uninstall the drivers restart the computer and reinstall the drivers and reboot again before you plug in the drive. Here is a manual.
http://www.seagate.com/staticfiles/support/freeagent/fa_win_ug_en.pdf
Feb 24, 2011 | Pioneer DEH-P4000UB CD Player
F1 Error code
Hello, here is link to F&P repair video. This video explains how to repair a F1 error code and replace the rotor
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
Dec 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I bought my Harrier 2.4 yr2001 two months ago for a used car dealer. During the few initial test drives my friend and I did not suspect anything wrong with the engine and everthing seems just fine. After...
The initial thing that i see is your vehicle is too young to show that type os code.the two digit code 23 has not been used since 1995.It's an obd1 code.Your vehicle has obd2 class diagnostics on board.The code would be po171 or po172 for example. I would get a second opinion if i were you .Try running a few tanks of premium fuel. This can often wake up an o2 sensor by cleaning it up a bit.Hope this information helps,
Ken
Oct 08, 2010 | 2001 Lexus RX 300
I have installed Windows XP on my PC. However, after initializing the PC, I have found that there is no sound coming & an error is encountered while Bad DirectSound Driver, please install proper...
so, you should install your sound driver  follow the step below to reinstall it.
start/ right click my computer/ choose Properties in system properties, choose Hardware tab. Click Device Manager check if there's yellow question mark in it. If so, that's where the driver perform not normal. Delete it, and restart your windows to reinstall that driver.
May 14, 2009 | Computers & Internet
Futura CE-200 Software fails to initialize on XP sp2
Maybe you should try to contact singer south africa and ask them whats wrong, my laptop did the excact same thing switch over to home pc and no problem ever again.
Mar 02, 2009 | Singer CE-200 Quantum Futura Computerized...
Dcr-trv520 error code C:31:23
For those that said to reset your camera, thanks.
DCR-trv520 handycam. Left power on, took out battery. Waited a minute.
Put battery back in. Worked liked before.
Thanks.
Jul 24, 2008 | Sony Handycam DCR-TRV520 Digital Camcorder
Computers & Internet Logo
5,659 people viewed this question
David Payne
David Payne
