Question about Sigma Sport BC1106 Dts Wireless Bike Computer
My bike has been sitting all winter and I rode it for the first time today. I've never had a problem before, but I can't seem to get my computer to sync with the wheel. The mph is flashing, display appears strong. strong "chirp" from fork mounted piece.
    Brigadier General:
  • 8,546 Answers
Just the same it may not be receiving a usable interrupt from the transmitter.
http://www.sigmasport.com/en/allgemein/showdatei/?download=1&name=66_1_BC1106DTS.pdf
Check out the 10th page of 40 (Pairing)
Or just put new batteries in both units and try again
The 29th page discusses problems..
Posted on Mar 12, 2011
2 Suggested Answers
  • 186 Answers
SOURCE: mph is flashing, display appears strong. strong
is the computer set to auto or manual
Posted on Sep 21, 2010
It sat all winter and most of the summer&wouldn't start so I bought a new battery,spark plug&another fuel pump Bc the old one was corroded over
Try running sea foam through ur system take the gas hose off the tank make a funnel system to that hose fill it with straight sea foam crank the bike untill it sucks at least 1 cup full let it sit for 24 hrs then try to start the bike with gas by adding through the funnel still no luck check spark plug for spark if no spark check sensors a wire could have croded and not making good connection also check your fuse box changing fuel pump could have blowen a fuse
Dec 01, 2015 | Motorcycles
Won't start
Hi Anonymous, try the website below it may help:
http://donscycleware.com/hadaspercoan.html
Good luck
Apr 07, 2014 | 2009 Harley Davidson XL 1200N Sportster...
BRAKE FAILURE LIGHT STAY'S ON . 2007-RT1200R
Hi, Dan for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
http://forums.bmwmoa.org/showthread.php?61389-Got-the-Dreaded-ABS-Red-Brake-Failure-Light-2007-R1200RT
R1200RT ABS Brake Failure BMW Luxury Touring Community
Bmw r1200rt service manual pdf
BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
http://www.bmw-motorrad.com/us/en/index.html?content=http://www.bmw-motorrad.com/us/en/services/manuals/manuals_main.html¬rack=1
Jun 05, 2012 | 2008 BMW R 1200 RT
Bike running rough at lower revs
If the bike sat without being used over the winter It could be bad gas. if gas sits without being used for an extended period of time it destabilizes and gums up carborators and fuel injectors, you need to add a fuel stabilizer to gas when storing for winter. To fix the problem the gas has to be drained from tank, then refil with fresh gas and appropriate amount of carborator/fuel injector cleaner/treatment. Then start the bike and let it run it should clean itself out and start running smooth. If bike did not sit unused for winter its possible they installed the wrong plugs sometimes they talk you into spending more money on platinum or split fire/gimmick plugs (always use the exact same plug that came in the bike when it was new!!!!!)
Mar 17, 2012 | Triumph Rocket III Touring Motorcycles
I've changed my battery just last November. I did
Well, if the Batt don't hold charge then check the regulator on the bike with an Ohmmeter you can buy one at an Auto parts shop....motor running you should see 14.5 V if not then the Reg is out!!!
May 24, 2011 | 2001 Harley Davidson FXDWG Dyna Wide Glide
Why would rear brake fail on 07 tuono after winter storage? Rode bike about 2 weeks ago everything was good, today rear brake master cylinder is suspect and has no pressure why?
Hi, Erideree try bleeding it and I am sorry you can't find the first and best tool you ever bought for your Aprilia but despair not for a mere $10 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/2007+aprilia+tuono+1000+r
Feb 17, 2011 | 2007 Aprilia Tuono 1000 R
Engine wont turn over at start
Hi, Do you have an alarm & Immobiliser fitted on your bike as these drain the battery on your bike very quickly? If so i would recommend removing your battery and fully charging it with a decent amp-age charger. If you have your garage attached to your house then i would definitely recommend purchasing a trickle charger and when not using your bike keep this plugged into the mains and you should not have this problem again. all motorbike shops sell these chargers If after this the battery goes flat again i would suggest purchasing a new battery. This is a common fault as most motorbikes sit in the garage through the winter months and if not kept on charge will deteriorate. Hope this helps.
Apr 09, 2010 | 2006 Yamaha V Star 1100 Custom
Clutch seems to be seized because bike has been sitting for years
Is the clutch lever sized or is the plates sized?
Usually the plates inside sizes, all you have to do is select gear 2 or 3 without starting the bike's engine,operate the clutch lever and push the bike,it should release, the rear wheel should now rotate freely with clutch lever in operation and in gear.
Hope this helps!
Nov 28, 2009 | Yamaha YZ 250 Motorcycles
Carb problems
if & when you do get it running again, does the bike have a petcock at the gas tank? if it does, when the bike is running before you are about to park it for 2 weeks, turn the petcock off and let the bike die on its own (from fuel starvation). this will ensure there is (almost) no gas in the carb to cause any gumming. you can drain the little bit that is left with the carb bowl drain screw. then when you're ready to ride again, simply turn the petcock on, wait a few seconds for the carb bowl to fill, then hit the start button.
Jan 18, 2009 | 2008 Yamaha Royal Star Venture
Sigma Sport BC1106 Dts Wireless Bike Computer Logo
296 people viewed this question
Top Sigma Sport Cycling Experts
kirkjw
Level 1 Expert
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Sigma Sport Cycling Expert? Answer questions, earn points and help others
