Question about Brother MFC-8460N All-In-One Printer
My Brother MFC 8460 will not feed pages through straight and therefore jams. If you lift the cover on the feeder the paper feeds straight and comes up on top but when it is down and the paper follows the correct route, it always twists the paper. The front edge goes thru faster than the back. Or perhaps the back just stops while the front side keeps going.
Photocopy unable
Sir/ Madam
Hear Is The Soluction which Help You To Fix Your Brother MFC 210C Photo Copy Problem,
Description: Issues with the paper feed could include:
  • Feeding multiple pages.
  • Misfeeds the paper.
  • Printed pages are not stacked neatly.
  • "No Paper Fed" or "Paper Jam" messages appear on the LCD.
To prevent these issues, try the following recommendations:
  1. Verify the paper is loaded properly in the paper tray and the paper support flap is unfolded.
  1. Pull the paper tray out of the machine and remove the output paper tray.
  1. Remove the paper from the paper tray.
  2. Pull the paper support out and unfold the paper support flap.
  1. Fan the stack of paper well to avoid paper jams and misfeeds.
  1. Gently insert the paper into the paper tray print side face down and the leading edge (top of the paper) in first. The paper should be flat in the tray and below the maximum paper mark. Be sure you do not push the paper in too far as it may lift at the end of the tray and cause feed problems.
  1. Press and slide the paper guides on the sides of the paper to fit the paper width.
  1. Clean the paper pick-up roller
    NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
    1. Pull the paper tray completely out of the machine.
    2. Unplug the machine from the AC power outlet and remove the Jam Clear Cover (1).
    Note DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
    1. Clean the Paper Pick-up Roller (1) with isopropyl alcohol on a cotton swab.
    2. Put the Jam Clear Cover back on. Make sure the cover is set properly.
    3. Put the paper tray firmly back in the machine.
    4. Re-connect the power cord.
  2. Verify there is only ONE type of paper loaded in the paper tray.
  3. Make sure that you use paper that meets our specifications.
    To see the detail of the specifications, refer to the User's Guide. The latest User's Guide is available in the Manuals section.
  4. Do not use paper that is damaged, curled, wrinkled, or irregularly shaped.
  5. We recommend using Brother paper to ensure the paper meets the proper specifications.
If your question was not answered, please Tell Us More Information About Your Brother MFC 210C Photo Copy Problem Issue And Errors
Jan 03, 2014 | Brother MFC 210C All-In-One InkJet Printer
MFC 8820D ADF Will Not Feed Document
The ADF in my Brother MFC 8820D will not feed a page through
Feb 23, 2013 | Brother MFC 8820D All-In-One Laser Printer
The belt inside my scanjet 4200c has come off. How do I reattach it? I have opened the scanner. It looks to be relatively easy but I don't know how to attach the belt to the motor etc
Instructions
1 Lift the hatch on the feed tray and pull up the large green tab to the left of the roller. Remove any jammed or torn paper from under the roller and around the feed tray.
2 Pull the input feed tray out of the automatic document feeder. Grasp the feed tray with both hands and pull it straight out.
3 Check the interior of the automatic document feeder for jammed paper. Remove any jammed paper, then reinsert the feed tray into the automatic document feeder. Push down the feeder cover until you hear a click.
Mar 08, 2011 | HP Scanjet 4200c Flatbed Scanner
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
Paper feeder is not straight
Push the copy button with the cover up and no paper on the glass. Is the light bar straight up and down, or is it crooked? I can't imagine how paper could go thru the machine crooked, but check it out if you can. If the paper is too thin, it may not be getting grabbed by the rollers right.
Mar 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
Document Feeder jams
I got adventurous and removed the screws holding the document feeder. I then used a can of air and blew into the gears and then reassembled the feeder. It works perfectly.
Feb 05, 2009 | Brother MFC-7820N Laser Printer
DOCUMENT FEEDER IS JAMMING
Try and clean the rubber rollers with Isopropyl alcohol. Do not use any solvents.
S. Mohan, Chennai, India
Dec 30, 2008 | HP Scanjet 5590 Flatbed Scanner
Envelopes keep jamming
hello! try cleaning the paper feed roller where you feed the envelope in with denatured alcahol good luck
Dec 29, 2008 | Brother MFC-8460N All-In-One Printer
Brother MFC 8460
Hi
There must still be a piece of paper in the machine check the fuser section at the rear of the machine maybe be piece there or check at the paper cassette area remove cassette and check that the paper hasn't got jammed as it feeds through.
Thanks
Document Jam Error Message on Brother MFC-8660DN
I had the same problem with a Brother MFC-8460 and called Brother's support line. The solution that worked for me was to lift the top cover where the sheets of paper go through when you fax. On the right of the black rectangluar piece with grey roller there is a slot in the tray with a black lever inside. The black piece was stuck down inside the slot and had to be popped back out. Once it was out I hit the stop button and it was fixed!!
Mar 03, 2008 | Brother MFC-8660DN 5-in-1 Laser...
Brother MFC-8460N All-In-One Printer Logo
76 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
