Question about AEG Dryers
It starts then it sounds like the drum is not turning
Open the Tumble dryer up if your past your warranty
Sounds like the rubber band has come off the motor which turns the drum
Posted on Mar 12, 2011
Drum not turning
unfortunately your motor is locked up. Try this, with the door open depress the door switch and have some one push the start button while you turn the drum by hand if it starts then you'll know the start winding on the motor is failing
Mar 13, 2012 | Frigidaire GLGR1042FS Dryer
MY NEPTUNE WASHER IS MAKING NOISE DURING SPIN CYCLE WHAT PART DO NEED TO REPLACE? MODEL # MAH4000AWW
If the noise starts before the drum starts to turn it might be the pump is obstructed. If it starts soon as the drum starts to turn then might be the drum bearing. If it is a knocking vibrating sound open the door and grasp inner drum try moving up and down and side to side . If there is any movement aside from the whole mechanism then the spider that holds the shaft to the drum is broken . Need a tech
Nov 23, 2010 | Maytag Washing Machines
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
My dryer drum will no longer turn easily...and dryer won't start.
sounds like the motor is going bad,did you remove the top to see if the belt broke or if it jumped the track?mike
Feb 19, 2010 | Kenmore 62802 Electric Dryer
Dryer does not start. Drum does not turn by hand. Only makes a sound when switch is turned on.
If it is a sound like a loud hum, the motor is either fried or something is jammed preventing the drum from turning. It could be something like a sock. You just have to open things up and look around carefully, especially around the outside of the drum.
If the noise is a more normal one but the drum is not turning, check that the belt is around the drum and not broken. Some drums are just fairly hard to turn by hand, partcularly if the belt is still around the drum.
Sep 19, 2009 | Dryers
When turning the knob to start dryer, buzzing sounds but drum doesn't start to turn unless you gently push atart the inside drum
The problem is either a faulty start winding in the motor, or the circuit which energizes the start winding is failing.
A dryer motor has two windings: start & run. The start winding gets it going and a centrifugal switch disconnects the start winding when the motor gets up to speed.
Check the dryer start switch -- then the motor connections and the centrifugal switch inside the motor.
May 05, 2009 | Dryers
My maytag neptune gas dryer model #MDG3000AWW When I push the start button on my maytag neptune dryer it sounds like it wants to start but doesn't and then it gets this smell like something is burning?...
It sounds like the drum bearings are seizing up preventing the drum from rolling easily, and when the motor runs, it can't pull the drum belt around the drum that won't turn, so starts squealing and burning the belt.
You need to lubricate/replace the drum bearings, and replace the belt.
Jan 29, 2009 | Dryers
Dryer wont start, drum hard to turn-revised
get a new drumm it might be bent if your putting stuff that weight alot in your dryer if its making a skeeking rusing soung get a new drum about 400 dollers
Dec 21, 2008 | Dryers
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
Dryers Logo
110 people viewed this question
Top AEG Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Gaark
Are you an AEG Dryer Expert? Answer questions, earn points and help others
