Question about Jandy Laars Lt 400,000 Btu Heater
Heater will run when the front door is removed. When door is reinstalled, heater will cut off and pressure switch warning light flashes.
  • 310 Answers
Replace the pressure switch and look for a disconnected ground
Posted on Mar 17, 2011
Where is the signal light relay that makes signal lights flash located on 2000 ols intrigue 3.5 liter
Important: The hazard warning switch includes the turn signal and hazard warning flashers.
Removal Procedure
Remove the center air deflector. Refer to Instrument Panel Center Air Outlet Deflector Replacement .
Squeeze the retainer on the backside of hazard warning and cruise control switch.
Pull the hazard warning and cruise control switch from the retainer in the instrument panel.
Disconnect the electrical connectors from the hazard warning and cruise control switch.
Remove the hazard warning and cruise control switch from instrument panel.
Remove the hazard warning and cruise control switch bezel from the instrument panel trim pad by using a small flat-bladed tool to the release retainers.
Remove the radio. Refer to Radio Replacement in Entertainment.
Reach through the radio opening and push the retainers up towards the roof of the vehicle. When the retainers release, slide the instrument panel (I/P) center air outlet deflector out of the I/P opening
Remove the air outlet deflector
Remove the instrument panel accessory trim plate. Refer to Instrument Panel Accessory Trim Plate Replacement in Instrument Panel, Gauges, and Console.
Remove the bolts from the radio.
Pull the radio toward you.
Remove the front floor console trim plate. Refer to Front Floor Console Trim Plate Replacement .
Pull the instrument panel (IP) accessory trim plate away from the IP trim pad.
Disconnect the IP harness seat heater leads, if equipped.
Remove the seat heater switches from the IP accessory trim plate, if equipped.
Remove the IP accessory trim plate.
Nov 09, 2016 | Cars & Trucks
No Heat
3 flashes indicate an issue with either the inducer, pressure switch, plugged condensate drain or a venting restriction.
Clear all debris from the exhaust and intake air piping. Make sure they are not drooping anywhere.
Check the pressure switch and the rubber hoses for blockage.
Blow out the drain line that evacuates the condensation.
On the inducer motor housing, un- plug the rubber hose going to the pressure switch and check to see if there is suction when the motor is running.
Make sure your air filter is clean.
Listen to the inducer motor as it turns for gurgling or any other abnormal sounds.
To make the heater run while you have the cabinet open, tape down the door safety switch. Remove the tape after diagnosos.
Dec 19, 2007 | Goodman GMS90703BXA Heater
Blowing cold air is there a pilot to light
No pilot on this model. If the room air blower is constantly running it is telling you that there is an error code stored on the circuit board. Look for a small viewing port in the lower section of the furnace. Look in it for a flashing light. Count the number of blinks. Now remove the front panel and on the reverse side there will be a wiring diagram. Also on the wiring diagram there will be a Diagnostic Chart that will explain the blinks. If you remove the panel that opens the door safety switch, it will cut power to the unit and erase the code so find the viewing port first.
Jan 22, 2011 | Goodman GMS90703BXA Heater
Indesit wd12 (old) timer just goes round without stopping. door light flashes 9 times, help!
Hi, this is the list of the Indesit wd12 error codes...
Error codes and their meaning..
f01 light 4, motor triac f02 light 3 motor, jammed/ tacho f03 lights 3&4 Ntc fault f04 light 2. pressure sw stuck on empty f05 lights 2&4, pressure sw stuck on full f06 lights 2&3, N/A? f07 lights 2&3&4 heater relay f08 light 1. heater relay f09 lights 1&4 eprom/setup error f10 lights 1&3, pressure switch not sensing f11 lights 1&3&4, pump/draining error f12 lights 1&2, communication error f13 lights 1&2&4, dryer ntc/ fan motor f14 lights 1&2&3, dryer heater f15 lights 1&2&3&4, dryer heater relay f16 N/A f17 light 4, door lock f18 light 3 comms error (3 phase motor) power board
Door flashing 9 times means 1&4 eprom/setup error
Dec 20, 2010 | Washing Machines
My zanussi zwf12070 washing machine will not do anything. The start button flashes red three times and then turns green. The door opens but the machine does nothing. Please help. This machine is only...
If I am correct and 3 red flashes and 1 green then that is E31 which is normally a heater fault but can also be a faulty pressure switch or main programmer.This machine is covered by the 5 year major parts warranty.Does not cover the heater and it is normally the heater for that code.You can either get an Electrolux engineer to call out or your local service guy but be warned that only genuine heaters can be used on these machines they have safe fail fuse links in these elements.
Hope this was helpful.
Apr 22, 2010 | Zanussi ZWF12070 Front Load Washer
Washer starts then stopps a few minutes in and the delicate and fast and dry lights flash,please help
this sounds like a heating circuit failure, two most likely are failed heater
or pressure switch. Heater is access fro bottom of unit after base tray has been removed base tray will have safety flot switch attached to it,
pressure switch located in frame right front inside right hand panel
Apr 19, 2010 | Hotpoint Dishwashers
My Colman forced air heater is cycling acording to the thrmastat but wont heat up. The trouble shooting light flashes three times.What part do you think is failing?
3 flashes is the combustion pressure switch . Mounted on the front mid high. Two silicone hoses run to it along with blue two wires. By now you have probaly got this fixed though.
Nov 16, 2009 | Coleman Propane Forced Air Heater...
Hotpoint Aquarius cycle not finishing with f02 error
Dont think its pressure switch.if sticks one way machine overfills the other brings on heater with empty drum..Could be fauly rinse solonoid valve...Check with multimeter coil should read around3k ohms..good luck
Sep 29, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Heater does not stay running shuts down may or may not come back on
I hope your pool heater is still running! Anyway you mentioned that when you reinstall the heater door the heater turns off.
This is my personal experience with this; there is no switch on the door, keep that in mind; so ask yourself: when you remove the door are there any wires touching or resting against the inside door panel?
if so its possible that one of the wires in a connector is broken, the crazy thing is you cant see the broken wire that is causing your intermittent issue.
What I did was cut off all of the wire connectors and installed new ones, now the heater is running like a champ.
Good luck
May 15, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
MHU45LP won't fire
The pressure switch to which you are referring is the switch connected to the suction side of your induced draft fan. This pressure switch will have a hose connected between the switch and the induced draft fan. Please let me know if you need any more assistance.
Feb 17, 2009 | Mr. Heater MHU45LP
Jandy Laars Lt 400,000 Btu Heater Logo
105 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
